Old 09-10-2015, 03:22 AM   #71
Bergen23
Drives: '15 Halo FR-S
Originally Posted by FRSBRZGT86FAN View Post
Will do problem is I don't see the car for several weeks, I still haven't installed that TCM unit I bought off eBay either and I see no one has one installed or had it replaced either. The last several weeks I drove it before leaving for college there were no issues whatsoever took it on some really good roads and drove it quite hard and the issue never appeared once. I will try the cruise control trick however does the issue occur after holding the throttle in auto mode above 50 mph without cruise control as well?
In my experience, it's only WITH cruise on. I did some highway driving without cruise control, and everything was ok
Bergen23 is offline   Reply With Quote
Old 09-10-2015, 11:50 AM   #72
redmoon
Drives: 2015 LR Subaru BRZ
I've been experiencing the same issue for a while now as well. I tried the cruise control and after a while it started to have this hard shift issue. I also noticed that the issue becomes more predominant when I have about 30-40% of engine oil. I wonder if there is any correlation between fluids and the hard shifting and lack of rev matching. I been to the dealership and was told that this issue is part of the character of the car which I refuse to believe.
redmoon is offline   Reply With Quote
The Following User Says Thank You to redmoon For This Useful Post:
MechEGR (09-10-2015)
Old 10-02-2015, 02:00 PM   #73
OpteronO3
Drives: 2013 Scion FRS
I keep getting these rough shift and all the dealer keeps saying is normal operation of the vehicle. I've been 4 times with no luck.
I've had a tech sit with me while I replicated the problem and he even recommended to change the transmission. But because no codes show up, there is nothing Toyota can replace. This is what the Sevice Manager told me. Honestly, theyy they dont even want to loan me a vehicle anymore because this is "normal" for the vehicle. Ive talked to corporate customer service and they are worthless waste of time.
OpteronO3 is offline   Reply With Quote
The Following User Says Thank You to OpteronO3 For This Useful Post:
MechEGR (10-02-2015)
Old 10-03-2015, 04:34 AM   #74
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
There's a TSB that came out for our cars with a new TCM logic have them do it and see if its fixed.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
OpteronO3 (10-03-2015)
Old 10-03-2015, 11:06 AM   #75
MechEGR
Drives: 2015 Scion FR-S AT
Can you link it to me? I can't find it. Thanks
MechEGR is offline   Reply With Quote
The Following User Says Thank You to MechEGR For This Useful Post:
Old 10-03-2015, 02:17 PM   #76
OpteronO3
Yes, please send us link to this. Toyota keeps telling me there are no pending TSB for my car.
Old 10-03-2015, 04:20 PM   #77
FRSBRZGT86FAN
http://www.ft86club.com/forums/attac...1&d=1443640063
I downloaded it and sent it to sigh on rice who uploaded it to the TSB/Recalls section of the forum, you have to beg them to update the TCM logic
Old 10-03-2015, 05:53 PM   #78
OpteronO3
Awesome find. Might go there on Monday and beg for it. I'm guessing you were able to get it uploaded? Are you getting any results?
Mine is a 2013
Old 10-03-2015, 10:32 PM   #79
FRSBRZGT86FAN
Mine is a 2013
Not yet,I won't see my car till around thanksgiving and also won't take it to the dealer till the first oil change anyway, so that's holding me back. Also I have another issue with my winjets thats got screwed up doing a DRL mod and will need to fix that up as well I did however have toyota techstream for a while so I downloaded that mystery tsb
Old 10-04-2015, 12:22 PM   #80
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
What dealer is this? If you don't mind driving out to Grapevine, give them a try. They have been good to me with fixing stuff I had. Ask for JP the service advisor and see he can help you out. CEL or not, it's not normal and shouldn't happen. Fortunately I have not had any of these issues a lot of you are having recently with the auto *knock on wood*.
JonAvalon is offline   Reply With Quote
The Following User Says Thank You to JonAvalon For This Useful Post:
OpteronO3 (10-05-2015)
Old 10-05-2015, 02:16 PM   #81
OpteronO3
Thanks Jon. I will definitely give them a try. I will go sometime next week when I'm off
Old 10-22-2015, 09:53 PM   #82
FRSBRZGT86FAN
Sorry in advance for the long post. I've been a long time lurker and love all the information on here, I'm hoping some of you may be able to shed some light on my transmission issues.
I bought my auto 2015 FR-S in late May. At about 1K miles, I noticed that occasionally when I was in sport mode (Edit: or manual mode), I would get hard, notchy shifting, particularly going into 2nd or 3rd gear. The most interesting thing, is that if I'm getting the hard shifting, and I pull over, turn the car off, and turn it back on, it starts shifting smoothly again. Exactly as described in this previous post:
http://www.ft86club.com/forums/showthread.php?t=80500
I tried everything I could to consistently recreate the problem to no avail. It happens probably every 3 times I drive the car. Sometimes it will happen when I put it into sport mode(Edit: or Manual Mode) with a cold engine in the morning, and sometimes it will happen after I've been going 80MPH on the highway for half an hour. Seems totally random. I tried all the obvious things like making sure I wasn't letting off the gas during acceleration or doing anything weird. I tried resetting my computer as well by disconnecting the battery for 20 mins.
If it is happening in normal auto mode, it's much more subtle.
I took it into Toyota a couple weeks ago, and was unable to recreate the problem for their tech since I turned the car off. They said that next time it happens and you're in the area, stop by and keep the car on so I can show them the issue. Sure enough, 1 week later I was in and the tech agreed right away that something was wrong. Multiple techs and service managers drove it that night and they all agreed that something wasn't right.
So I left my car there last Tuesday night and just picked it up last night (Monday). They took OBD data, sent it to Toyota, and their response was to check the transmission fluid and reset the computer. They were unable to recreate the hard shifting during the four days and putting close to 80 miles on the car. They ended up adding half a quart of transmission fluid. They still couldn't recreate the problem so they gave it back to me and told me to drive it and see if it comes back. Sure enough, as soon as I pulled out of my work parking lot today, the hard shifting was back.
I did some datalogging comparisons with and without the hard shifting with my Bluetooth OBD reader and have it all in excel if anyone wants to PM me and take a look at it (I'm an engineer who loves data). I wasn't able to really see anything. I also took videos of it happening:
***Watch the tachometer, you can see it stumble going into second gear.
Sorry for the bad quality, youtube wouldn't let me have them in HD.
So here I am. Anyone have any experience with this or ideas on what might be going on? I'm pretty frustrated and don't want to have to drive a rental for another week while they putz around figuring out what's wrong.
Thanks in advance!
http://www.ft86club.com/forums/showthread.php?t=96615
Made a little polling thread for this issue if everyone goes to the dealer to complain a TSB will eventually be created directly addressing it and not the idle issue
Old 12-09-2015, 10:15 AM   #83
about94ninjas
Drives: 2015 WRB BRZ Limited 6AT
So I finally went to the dealership and had them take a look at it. The tech went with me on a test drive, but we were unable to recreate the problem. They still took it in and preformed a reflash. Then on the way home it started acting up again, so I drove it back and left the car on. After going on a drive with the tech, he tried to argue that it was the way I was driving, and I should not be shifting at 7 and told the service manager that I was shifting into first at 40MPH, which isn't even possible... Luckily, an engineer from Subaru happened to be there, and I took him for a test drive as well. He immediately noticed the problem and said he would look into it and call me back.
about94ninjas is offline   Reply With Quote
Old 12-09-2015, 10:25 AM   #84
MechEGR
This is solved! Have them do the TSB. We have had multiple confirm the tsb solves all these issues. Check out this post:
about94ninjas (12-18-2015)
automatic, hard, issues, shifting, transmission
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 10:57 PM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 07:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 01:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 04:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
