Old 10-01-2015, 07:20 AM   #631
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Spartarus View Post
I see your misunderstanding. It's a gear type pump. If you look up positive displacement gear pump you can find a few helpful animations to explain it. The gear doesn't turn the pump, the gear IS the pump. Well, it is the guts of the pump. The gear and outer ring are the part that actually moves the oil. These gears form a bigger pocket, moving more oil per rev.
The real confusion was that their product description only mentions stronger gears for reliability. It makes no note of higher flow rates or improved pressure. I actually wanted to "dominate all" and got "overnight parts from Japan." They arrived at Moto-East yesterday for installation while they rebuild my engine.
Luckrider is offline   Reply With Quote
Old 10-01-2015, 02:49 PM   #632
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
HA
I know it doesn't. That was figured out mathematically after purchasing it and finding that the tooth profile and count did not match stock. The assertion still hasn't been tested or documented. These engines don't hold anywhere near sufficient oil pressure to shatter a sintered gear. If they did, that would be a valid concern. The old Nissan RB and SR motors had problems shattering their sintered oil pumps. Even in the FA though, the outer ring stretches measurably over time.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 10-06-2015, 04:02 PM   #633
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
When I spoke with element a few months ago, they said they didn't see favorable results with the reimax gear/pump. I'm surprised Phil hasn't posted about it yet.
crazyfrenchbiker is offline   Reply With Quote
Old 10-06-2015, 05:10 PM   #634
350matt
Drives: toyota mr2/ Toyota GT86
Originally Posted by Calum View Post
You wouldn't happen to have the part number for the correct part? I'd like to order a set so I can update the one side when I pull the engine to adjust the valve lash. It would also be really good info to have available.
Thanks by the way.
Also, is it just me, or are those holes huge for the given purpose?
do you have the actual hole sizes between the two parts? as I wonder how much of the oil pressure loss at high rpm is down to leakage ?
I'm assuming that the later part has the smaller hole ?
350matt is offline   Reply With Quote
Old 10-08-2015, 10:11 PM   #635
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
I only read the first page of 86... But has anyone mentioned an oil accumulator? I like them for my street cars due to having oil pressure before the crank start to turn. But I know they are in use heavily in drag cars. (ie extreme g force causing oil to go away from the pickup)... Just my 2 cents.
Sent from my LG-D850 using Tapatalk
Respect BRZ is offline   Reply With Quote
Old 10-08-2015, 10:29 PM   #636
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Search this thread >> "accumulator" >> 32 hits. Nope, no one's thought of that.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
Spartarus (10-09-2015)
Old 10-09-2015, 12:34 AM   #637
Spartarus
...Just add nauseum
Spartarus's Avatar
Please.
Read.
The.
Whole.
Thread.
Before.
Posting.
OR AT LEAST SEARCH IT, NOT THAT MUCH TO ASK THANKS.
THIS NEEDS TO BE A RULE (mods, I'm talking to you.)
-Spartarus
The Following 4 Users Say Thank You to Spartarus For This Useful Post:
CxG (10-09-2015), johan (10-11-2015), Ultramaroon (10-09-2015), Wayno (10-09-2015)
Old 10-09-2015, 01:29 AM   #638
Hawk77FT
Drives: GTS 86
So, is it worth getting the Reimax oil pump? Read somewhere (it might've been here, I cant remember) that it pumps 1.5 more oil (due to bigger pockets??). I am tempted to change it to this and while I am at it maybe smooth out couple of galleries angle.
Hawk77FT is offline   Reply With Quote
Old 10-09-2015, 10:49 AM   #639
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Please.
Read.
The.
Whole.
Thread.
Before.
Posting.
638 post is a lot to read.
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 10-09-2015, 10:55 AM   #640
Please.
Read.
The.
Whole.
Thread.
Before.
Posting.
It is (see bottom)
2) Search. These forums tend to accumulate knowledge, and so when you have a question do a simple search first. Alot of times, the best answers will be found in old threads that have gone over the topic in detail. If you can't find your answer or are still unclear, then by all means don't be afraid and post your question.
---PLEASE READ BEFORE POSTING---
cjd (10-09-2015), Spartarus (10-09-2015), Ultramaroon (10-09-2015)
Old 10-09-2015, 01:30 PM   #641
Spartarus
...Just add nauseum
Spartarus's Avatar
It is (see bottom)
“To every rule there is an exception—and an idiot ready to demonstrate it.”
― Vera Nazarian
If they don't enforce them, they hardly constitute rules.
Also thank you. That damn thanks button went away before I could click it a few more times.
-Spartarus
The Following User Says Thank You to Spartarus For This Useful Post:
sato (10-09-2015)
Old 10-09-2015, 09:12 PM   #642
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Nigelr32 View Post
No way. I have no idea when the change was made, I just noticed the difference on a rebuild of my 2012 engine. I believe there were issues with the cam timing? This may be something to do with it??
I have a 2012 and a 2014, this is how I found the difference. The earlier engines have a different part no for left and right rocker posts, later they're the same.
Heres a pic of the left and right next to each other..
Good catch.
A few tidbits here as we're tearing down into a 3rd FA20 just in the last 4 weeks...
2014/07 appears to be the cutoff for when subaru had a field day and made some major changes to the FA20. Valves, valve stem seals, rocker oilers, rockers all appear to have changes right around there (though could have been in steps). We still have to measure the 3rd fa20 (15 wrx) to see where they left off there, but clearly subaru had enough reason to change around the whole head specification. While we can't speculate exactly what the reasons may be, I think it is fair to say that the later motors have had some additional input in regards to what the engineers think is a better approach.
FYI for those doing this themselves, the VIN based parts lookup is not accurate here. Valve lenghts, stem seal bore, and rocker specs need to be measured.
Xero-Limit is offline   Reply With Quote
The Following 7 Users Say Thank You to Xero-Limit For This Useful Post:
Calum (10-10-2015), chaoskaze (10-20-2015), civicdrivr (10-10-2015), EAGLE5 (10-09-2015), Lonewolf (10-11-2015), nikitopo (10-11-2015), Tcoat (10-09-2015)
Old 10-09-2015, 10:06 PM   #643
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
That's it.. I'm going to trade my '13 FRS in for a '15 BRZ.
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
Guillaume (10-10-2015), sato (10-10-2015)
Old 10-10-2015, 08:54 AM   #644
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by moto-mike View Post
Good catch.
I take it the installed tip hieghts have changed along with the rest of the changes?
Any chance you could post pics of the different parts so us mere mortals can see how things have changed?
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
