#29 |
Drives: 16' WRX
thanks guys, I've been changing the way I shift, and it definitely has improved by me revving up to 3-4k rpms before upshifting to 2nd. I think the tranny doesn't like it when you grandpa upshift around 2k rpm.
#30 | |
I keep it below 2.5K when it's cold. The reason it's tough to shift into second is because you're pausing too long in neutral. When the transmission is still cold the oil is like molasses. Normally, a short pause between gears is no biggie. When it's cold the input section stalls really quickly. Then you're fighting the molasses to spool it back up with the synchros. If you miss the shift to second, while in neutral, try letting out the clutch and blip the throttle. Then, before it slows back down, in one motion, push in the clutch and gently apply pressure towards second gear. When the input and output match speed it will drop in like butter. The double clutch will become second nature and is an excellent technique to prolong the life of the synchros by allowing them to do less work. It is absolutely essential should you choose to skip gears on a downshift, for instance, a sixth-to-third-gear shift for a pass.
#31 | |
Drives: Black Raven
I have also had the same grinding when going into 5th from 4th or 6th. I did a trans fluid change to Amsoil 75W-90 Synthetic at 4,000 miles, and problem did not change. I will try Toyota 75W, and see if that changes anything Why do you say a new transmission is needed tho? |
#32 |
Drives: 13 Sc10n FR-S
When looking at the color of the fluid, if you shine a light on it and get a lot of gold glitter usually means Trans, if you are still under warranty it's best to push for one last thing you want is a bad Trans when you are out of warranty
Sent from my D6708 using Tapatalk |
| The Following User Says Thank You to StegaDragon For This Useful Post: | Ultramaroon (09-29-2015) |
#33 |
But the main thing you have to consider is the level of grind, if the clutch pedal is to the floor and it grinds and won't let you put it in gear then you have a problem, if it's just hard engagement with a little noise then (depending on the level) normal or old fluid
What one person considers a grind might be something different to someone else |
#34 | |
#35 |
The whole car was built as cheap as possible, a couple of little mistakes, don't do your maintenance like you're supposed to and you run into problems. If you compare maintenance on them compared to other Toyota vehicles you find that it's a lot more demanding
#36 |
I would say it is the owners and not the build. Anytime someone has a transmission problem, I always ask if it is their first manual transmission car. More often than not, it is.
#37 | |
It's a communicative little gearbox and expects you to have your shit together.
#38 |
Drives: 2023 BRZ
A friend and I both had our 'boxes replaced. Both of us know how to drive. Yeah, it's a small sample size, but really....what are the odds? I've never heard of that with another model.
#39 |
Mentat
Drives: 2013 Scion FRS 6MT
Mine got better over time.
#40 |
Drives: 2023 BRZ
#41 |
That's what I'm afraid of. The synchros going through a sweet period after they break in but they keep on wearing.
Mine finally broke in around 9K. I'm at 17K now.
#42 |
Mentat
Well i already went to the dealership when the car was less than a month old and they basically told me they will not do anything to it till the transmission blows up.
| *UPDATE FROM TOYOTA REP*: Regarding 4th and 5th gear grinding issues... | husker741 | Issues | Warranty | Recalls / TSB | 97 | 08-27-2015 10:46 AM |
| 5th gear grinding | Bernie | Issues | Warranty | Recalls / TSB | 1 | 05-15-2015 07:10 AM |
| 6th gear grinding | D-VO | Issues | Warranty | Recalls / TSB | 59 | 04-07-2015 01:26 PM |
| Grinding in 3rd gear...what's going on?! | hozouria | Engine, Exhaust, Transmission | 3 | 08-13-2014 01:31 PM |
| 6th Gear Grinding | KpAtch3s | Issues | Warranty | Recalls / TSB | 0 | 06-18-2013 07:07 PM |
