Old 09-28-2015, 01:57 PM   #15
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
Cost effective?
Two camber/crash bolts, maximize that front camber, fix the front toe, and run some "extreme summer performance" tires somewhere in the 140-200 TW range.
The primary cause of your chunking is a lack of camber.
The theory behind a street car and your formula car is identical. Anything you learn here will carry over there, and vice versa. The difference is that you have to do everything yourself with this car, whereas with the formula car all the R&D has already been done for you.
Thanks for the input. Actually it was a Formula SAE project so we designed the car from the ground up and built it ourselves. My specialty was vehicle dynamics, designing the suspension system around the tire data we had available to us, choosing our dampers, springs, bars, and running the data acquisition/testing.
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 09-28-2015, 02:11 PM   #16
CSG Mike
CSG Mike's Avatar
Lets transition what you learned in college over to the car, and you'll do quite well
SkiRideDrive (09-28-2015), wparsons (10-02-2015)
Old 09-28-2015, 02:30 PM   #17
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Am I weird for not considering formula sae as real formula cars?
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 09-28-2015, 03:14 PM   #18
SkiRideDrive
Drives: 2015 FRS
Classify them however you like.
Old 09-28-2015, 11:38 PM   #19
EAGLE5
Dismember
EAGLE5's Avatar
Wasn't an insult. Just never thought of them as formula cars.
Old 09-28-2015, 11:40 PM   #20
SkiRideDrive
Drives: 2015 FRS
I've interpreted formula as an open wheel car designed to a set of rules and assumed that FSAE fit within that envelope.
Old 09-30-2015, 01:19 AM   #21
SkiRideDrive
Drives: 2015 FRS
Alright, solving the camber issue.
From my research. I can take the bottom strut bolt and put it in the top hole, and put the SPC 81260 14mm camber bolt in the lower hole to achieve about 2 degrees of negative camber.
It also seems that each degree of negative camber seems to add about 1/16" of toe in per tire. Can anyone confirm?
Also, does anyone know the ratio of tie rod turns per 1/16" of toe?
This would speed up my alignment considerably.
Thanks!
Old 09-30-2015, 03:22 AM   #22
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yes that the correct way to install crash bolts.
As for the toe setting. You really can't guess it with out having proper measuring tools.
Unless you have a toe setting plate and doing the the whole string and plumb deal, your best and fastest way is to take it to a shop. Sure it may cost a few dollars but it's a lot better than a DIY route. Unless you have alignment tools.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
SkiRideDrive (09-30-2015), wparsons (10-02-2015)
Old 09-30-2015, 10:14 AM   #23
SkiRideDrive
Drives: 2015 FRS
I was going to max out camber and then string it. For toe. Done it maybe 100 times before on an fsae car. Problem with a street car is you have to jack it up, put it down, jack it up, put it down. So I figured doing a little research beforehand would limit the number of iterations.
Old 09-30-2015, 01:20 PM   #24
dustmann
Drives: '14 WRB BRZ Limited
Thanks for the input. There seems to be a lot of "you need to check your tires at the track" responses. Some of them condescending. What pressures do you guys aim for at the track hot?
Not sure if you'll be back on stock tires, but I was most comfortable with about 35 psi front / 34 psi rear "hot" (as soon as I parked after I came off of the track) on a 100* day on stock tires. Set "cold" before my next session (about 2hrs between sessions) here in New Orleans, I was at about 31 in the rear, and 32 in the front. The following day I forgot to put air in the tires after leaving the track and my dummy lights were on for the tires (all <25psi) at about 75* in the morning. I felt like the rear starts to slide a little bit and the front understeers with 2psi more air than that. With 2psi too little air, the car feels more "squishy" like it doesn't want to settle when I was transitioning through "S" curves.
That could just be me though, I'm still pretty new to all of this track day business (only 4 days on the NOLA track). And this was on bone stock suspension/camber/tires.
dustmann is offline   Reply With Quote
The Following 2 Users Say Thank You to dustmann For This Useful Post:
DocWalt (10-05-2015), SkiRideDrive (09-30-2015)
Old 10-01-2015, 12:54 PM   #25
SkiRideDrive
Drives: 2015 FRS
I actually found a deal on a few used stock tires so I am going to swap out the chunked tire for now in the canyons and work on a solution for track days. I also ordered the camber bolts and will install them soon.
Old 10-05-2015, 04:03 PM   #26
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Thanks for the input on tire pressures for stock tires. I've got my first track day coming up in the BRZ and I don't feel like buying real tires for one track day then leaving them sit all winter. That said, maybe chunking the stock tires will let me justify better rubber sooner
Widest Track tires for stock wheels?? track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 10-11-2015 11:01 AM
WTB Stock Tires or Tires that would fit on stock rims. DrawingWaves Want-To-Buy Requests 2 09-11-2015 09:03 PM
Anyone running stock rims with good tires for open track? suaveflooder Tracking / Autocross / HPDE / Drifting 36 09-10-2014 08:49 AM
Track-only Race Compound Tires recommendations & Q's. On stock wheels. fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 03-26-2014 11:47 PM
good track tyres for the track? stock rims Rejor11 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-22-2013 12:35 AM
