Old 09-26-2015, 11:42 PM   #15
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
When the gear grinds you need a new transmission fluid! And since you are going to chabe the tranny fluid change the differential fluid too!
Dr. BRZ is offline   Reply With Quote
Old 09-27-2015, 01:21 AM   #16
swarb
DANG, @swarb ....... are you off your meds ..... again .... ?? .....
I ran out. You have?
Look at the previous threads, you are in there off topic also lol.
http://www.ft86club.com/forums/showthread.php?t=59053
http://www.ft86club.com/forums/showthread.php?t=56014
New manual driver. Lots of crunched gears and a year and a half later...
OP Take it to the dealer. Or A mechanic. Or a Transmission specialist.
Do Something.
Old 09-27-2015, 01:55 AM   #17
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
Make sure you have the right fluid in the Trans it takes 75w, not 75w90 or 80w90
Sent from my D6708 using Tapatalk
StegaDragon is offline   Reply With Quote
Old 09-27-2015, 02:00 AM   #18
Yes, swarb, I have meds ...... and I NEED them ALL ......
If you start listing threads, that I'm off topic in ...... it will be a looooog list ......
Old 09-27-2015, 02:35 AM   #19
Do you have a reference? Here's mine.
JEDI (10-01-2015)
Old 09-27-2015, 02:40 AM   #20
StegaDragon
Ya the repair manual is wrong, I'm a tech for Toyota and that's what I was going to put in when they stopped me and handed me Toyota's special 75w
Old 09-27-2015, 02:41 AM   #21
StegaDragon
It fixed that problem right away, though truthfully you need a transmission
Old 09-27-2015, 03:16 AM   #22
Please post the reference you have that supersedes the one I posted.
"They" can sound awfully convincing but that doesn't mean they are correct.
Old 09-27-2015, 03:37 AM   #23
StegaDragon
Sorry don't have any just telling you what Toyota technical assistance told me and had me do. Only thing I can tell you is to go straight to a dealer and ask the parts department, we deal with it all the time
The Following User Says Thank You to StegaDragon For This Useful Post:
Ultramaroon (09-27-2015)
Old 09-27-2015, 03:44 AM   #24
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
slight grind. Normal very small. Tested 5 twins.
Old 09-27-2015, 02:27 PM   #25
Here you will find endless debate over pretty much everything including lubricants. As an insider, should you stumble across any updated factory infonuggets, please do share.
Welcome to the forum.
Old 09-27-2015, 02:34 PM   #26
StegaDragon
Yup will do my best to share and help out, but Ya if it makes anything other than a small clunk type noise when engaging gears you probably need a new one
Old 09-27-2015, 08:00 PM   #27
Cam31
Drives: Pearl White BRZ
Take it to dealership if under warranty they most likely will replace it. Mine got replaced at 30000 miles
Cam31 is offline   Reply With Quote
Old 09-28-2015, 07:45 PM   #28
Pat
Pat's Avatar
Drives: 2023 BRZ
Sounds like a warranty issue to me
*UPDATE FROM TOYOTA REP*: Regarding 4th and 5th gear grinding issues... husker741 Issues | Warranty | Recalls / TSB 97 08-27-2015 10:46 AM
5th gear grinding Bernie Issues | Warranty | Recalls / TSB 1 05-15-2015 07:10 AM
6th gear grinding D-VO Issues | Warranty | Recalls / TSB 59 04-07-2015 01:26 PM
Grinding in 3rd gear...what's going on?! hozouria Engine, Exhaust, Transmission 3 08-13-2014 01:31 PM
6th Gear Grinding KpAtch3s Issues | Warranty | Recalls / TSB 0 06-18-2013 07:07 PM
