Old 09-26-2015, 07:56 PM   #15
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
I used single filament bulbs, but they still will light up. You will need to remove the green wire to disable the DRL function of the signals.
thatfilipinoguy is offline   Reply With Quote
Old 10-03-2015, 04:50 PM   #16
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Thanks for that tip! Worked like a charm without having to replace my bulbs!
Avo1789 is offline   Reply With Quote
The Following User Says Thank You to Avo1789 For This Useful Post:
thatfilipinoguy (10-04-2015)
Old 10-09-2015, 08:17 PM   #17
johnbradshow
Drives: Audi
If I change to LED bulbs, will they hyperflash without using resistors??
johnbradshow is offline   Reply With Quote
Old 10-09-2015, 08:18 PM   #18
thatfilipinoguy
Yes
Old 10-09-2015, 08:43 PM   #19
ryoma
ryoma's Avatar
you can buy an LED flasher module for like $10 and it will solve all your problems. it's an easy swap.
Old 10-09-2015, 08:46 PM   #20
KI_ZN6
KI_ZN6's Avatar
You can install an upgraded flasher unit and it would correct the hyperblink. This is the easiest method.
Alternatively, you can splice inline resistors but that would involve cutting into your factory wiring.
Sent from my SM-N910W8 using Tapatalk
KI_ZN6 is offline   Reply With Quote
Integrated turn signal and puddle light mirror cap MemphisR Cosmetic Modification (Interior/Exterior/Lighting) 52 09-19-2020 06:25 AM
FS: OEM Fog Light Bezel, OEM Turn Signal Housings, and OEM Reverse Light Assembly zeal86 Exterior Parts (Aero, Lighting, Etc.) 15 05-29-2016 10:01 PM
Turn Signal / Corner Light DRL Question J_McElwee Scion FR-S / Toyota 86 GT86 General Forum 1 06-18-2015 11:25 AM
Disable Turn Signal DRL? 636 Cosmetic Modification (Interior/Exterior/Lighting) 10 09-14-2014 08:09 AM
Front turn signal and Parking Light Help! Cal3000 Cosmetic Modification (Interior/Exterior/Lighting) 2 10-31-2013 02:30 AM
