Old 09-22-2015, 05:08 AM   #29
steve99
Drives: FT86
Originally Posted by JonAvalon View Post
Cool I'll try that
Just disable p050b code it happens with usa rom when you adjust cold start timing it normal does not happen with aussie roms though
I think you can get away with -10 or -8 but if you go to like -4 it post start timing it will throw a code on USA roms, just disable the P050B code its just a emmissions thing.
JonAvalon (09-22-2015)
Old 09-22-2015, 11:18 AM   #30
phrosty
Yep, this.
I get that code even with much less aggressive cold start timing reduction on E85. You need to disable the code.
phrosty is offline   Reply With Quote
Old 09-22-2015, 02:54 PM   #31
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by phrosty View Post
I know it'd be a lot of work, not trolling at all, just the programmer in me seeing user error and trying to prevent it before it happens. A suggestion, is all.
You can just open his roms in RomRaider and use the 'copy table' function.
Almost no user error.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
JB86'd (09-22-2015)
Old 09-24-2015, 11:31 AM   #32
jonesy
jonesy's Avatar
Drives: 2010 Corvette GS
I was walking through the steps and when I got to the load limits section, it looks like I don't even have the tables in romraider to make any changes. The only tables I have under Mass Airflow / Engine Load are MAF Limit (Maximum), MAF Sensor Scaling, MAF Compensation (IAT), Engine Load Limit (Maximum), and Engine Load Compensation (MP). I can't find the tables for Engine Load Limit B and C like the screenshots show. I do not have the MAF Correction After Start tables either. Have they been moved somewhere else in the later OTS files from Open Flash? Tried looking at older versions and different ECU definitions but none of those have the correct tables either.
Matt
#73 GS Focus ST/#82 STX BRZ
jonesy is offline   Reply With Quote
Old 09-24-2015, 11:48 AM   #33
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Have to use Wayno's definitions in Romraider for your car. They are in one or two of his posts. Once you do, the tables will be there. I had to download them too.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 09-24-2015, 01:23 PM   #34
jonesy
jonesy's Avatar
Awesome, thanks. I knew it was something simple.
Matt
Old 09-25-2015, 10:11 PM   #35
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
@Wayno
Firstly thank you for all your hard and useful work Wayno!
Second. I am trying to improve E85 drivability and fuel economy on my '14 Auto BRZ.
I'm copying tables from the "Example maps....." post of yours and have hit a snag.
Using your definitions, I can't seem to permanently copy "Cranking Fuel Injector Pulse Width F (ECT)"
It always shows (When in compare mode) That the file is not the same as yours.???
Any ideas?
Thanks in advance.
Pax
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
MGPAX is offline   Reply With Quote
Old 09-25-2015, 10:42 PM   #36
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Wanted to add a post here, a wealth of information. Definitely impressive to compile as much as you did. That much have been a pain in the ass to edit inside the forum if you ever needed to LOL
I've used several things like the cold start fix and maf correction for the perrin intake already, but this helped me understand the knocking and how to remedy/what to look for
Cheers!
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 09-26-2015, 12:00 AM   #37
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
thats a good refresher, but i dont have those load limit tables. I only have max engine load which is 1 box.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 09-26-2015, 01:33 AM   #38
MGPAX
Still 17!
MGPAX's Avatar
You have to use Wayno's tables in Romraider to get the other tables.
Old 09-26-2015, 05:53 AM   #39
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've gone through and updated all my OFT Defs:
Manual
US C Series OFT
ADM/EUDM G Series OFT
Auto
US D Series OFT
ADM/EUDM I Series OFT
.: Stealth 86 :.
Kodename 47 DJ:
phobos512 (09-26-2015)
Old 09-26-2015, 06:15 PM   #40
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you turn the compare mode off (Table > Compare > Off) do the values look the same? It seems some ROM types store values differently, I've seen slight variations before so I wouldn't worry about it. The compare tool will pick up any differences even if they aren't visible. I also think that Romraider will only copy to the same decimal point that it displays, so if the hex value is different it will show as different, but the display might not show any difference.
.: Stealth 86 :.
Kodename 47 DJ:
MGPAX (09-26-2015)
Old 09-26-2015, 11:15 PM   #41
Grip Ronin
The Mechanic
Grip Ronin's Avatar
where do i find his tables?
IG-Joey_Soul
Old 09-27-2015, 02:20 AM   #42
MGPAX
Still 17!
MGPAX's Avatar
http://www.ft86club.com/forums/showthread.php?t=83945 At the end of this post.
The Following User Says Thank You to MGPAX For This Useful Post:
Grip Ronin (09-27-2015)
Maximum weight in the trunk? djmm Scion FR-S / Toyota 86 GT86 General Forum 20 08-13-2015 11:40 AM
“Maximum Attack” Scion FR-S stugray Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 08:45 PM
PA: Rays Gram Light 57 Maximum 5x100, 17x8, +43 (Price Reduced!) Needs more cowbell Wheels and Tires 20 02-22-2013 10:03 AM
MAXIMUM you would pay for a TRD Supercharger installed? FRiSson Forced Induction 24 11-04-2012 01:08 AM
MR-S Effect... Dimman CANADA 11 09-06-2011 11:49 AM
