Old 08-12-2015, 01:17 PM   #15
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
I have updated post 2 to include a more conventional canyon road for more data points for those that are interested.
Originally Posted by SkiRideDrive View Post
The canyon run temperatures above were absolute worst case scenario, driving the car very hard on a very steep and very tight road. I have included two more comparison graphs below. They are on a more typical canyon road, predominantly third gear. These runs however, also utilize everything the car has to give. A more casual canyon run will likely have different results.
These runs (east grade) were also done very soon after running the very demanding road above (south grade). You may notice that the oil temperatures on the WITH cooler logs are decreasing. This is the cooler doing its job and dropping the oil temperature which were elevated by the very aggressive road driven prior. In the logs above, you will notice approximately a 11 degree max difference in oil temperature. In the more conventional canyon road below, you will notice after the cooler stabilizes the oil temperature, a more significant 20 degree drop or more. I think this is more representative of what a typical canyon driver will see, if not more, since this road is still being driven quite aggressively.
More Typical Canyon Run without Cooler
More Typical Canyon Run WITH Cooler
I hope this helps, please let me know if you have any questions.
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
The Following 2 Users Say Thank You to SkiRideDrive For This Useful Post:
CxG (04-25-2016), Wayno (08-12-2015)
Old 08-12-2015, 10:39 PM   #16
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
It's definitely more indicative of real world. 99.99% of people will never hit > 200F water in a moving car.
Traffic does not count because you fix that with software.
The Following User Says Thank You to Wayno For This Useful Post:
CxG (04-25-2016)
Old 08-12-2015, 10:52 PM   #17
SkiRideDrive
Drives: 2015 FRS
Glad to be part of the .01%!
The Following User Says Thank You to SkiRideDrive For This Useful Post:
Fastbrew (08-12-2015)
Old 08-12-2015, 11:12 PM   #18
Fastbrew
Drives: 2014 Pearl White BRZ
Good write up and well documented.
When I make the leap - I am putting in the AVO system but this looks suitable for a pretty straightforward install.
Fastbrew is offline   Reply With Quote
Old 08-12-2015, 11:12 PM   #19
jflogerzi
jflogerzi's Avatar
Thanks for the post. I am looking at adding this if I do decide to keep the my FRS. BTW Was this on Palomar the temps you were getting in post 1?
Old 08-13-2015, 12:08 AM   #20
SkiRideDrive
Drives: 2015 FRS
First logs are palomar south grade uphill. Second logs were east grade.
jflogerzi (08-13-2015)
Old 08-21-2015, 06:47 PM   #21
MaxedOutRS2.5
Bump.
MaxedOutRS2.5 is offline   Reply With Quote
Old 09-23-2015, 08:49 AM   #22
MaxedOutRS2.5
Bump.
Old 09-23-2015, 11:58 PM   #23
Kckc1
Drives: White brz series blue
Would this work in turbo applications or should I just get a standard oil cooler?
Kckc1 is offline   Reply With Quote
Old 09-24-2015, 12:14 AM   #24
SkiRideDrive
Drives: 2015 FRS
I think that depends if the turbo utilizes the lines I tapped for cooling the turbo.
Old 09-24-2015, 01:03 AM   #25
Wayno
Wayno's Avatar
It will be fine if you never plan on going on track. Kind of defeats the purpose of adding more power if you don't go somewhere you can drive hard, so the answer is no. Get some kind of proper laminova setup or air cooler with thermostat.
Old 09-24-2015, 01:33 AM   #26
Cole
Not a troll
Cole's Avatar
Is this ok to use in climates that have winters that get to around -30*C?
Cole is offline   Reply With Quote
The Following 2 Users Say Thank You to Cole For This Useful Post:
SkiRideDrive (09-24-2015), Wayno (09-24-2015)
Old 09-24-2015, 01:34 AM   #27
Wayno
Wayno's Avatar
Either this or a block heater or an external oil warmer!
Cole (09-24-2015)
Old 09-24-2015, 01:36 AM   #28
Cole
Not a troll
Cole's Avatar
Originally Posted by Wayno View Post
Either this or a block heater!!
It's not usually that bad, but it isn't uncommon to have one or two week long cold spells. I'd say it averages around -15 for the most part. Windchill excluded of course. Maybe I'll place an order for one of these.
Perrin Oil Cooler Kit Installation and Review!!! Sony Engine, Exhaust, Transmission 29 03-27-2017 02:03 PM
Texas Heat Sale- Perrin Oil Cooler 10% Off with Installation! GSpeed Southwest 0 07-30-2015 02:47 PM
Beat the Texas Summer Heat! Perrin Oil Cooler 10% Off with Installation! GSpeed Engine, Exhaust, Bolt-Ons 0 07-30-2015 02:44 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Oil Cooler usability: Changing oil, installation, etc post_break Engine, Exhaust, Transmission 20 06-12-2013 02:36 AM
