#15 | |
Drives: 2015 FRS
I have updated post 2 to include a more conventional canyon road for more data points for those that are interested.
2015 FRS Ultramarine.
#16 | |
Drives: Toyota 86 GTS
Traffic does not count because you fix that with software. |
| The Following User Says Thank You to Wayno For This Useful Post: | CxG (04-25-2016) |
#17 |
Drives: 2015 FRS
Glad to be part of the .01%!
| The Following User Says Thank You to SkiRideDrive For This Useful Post: | Fastbrew (08-12-2015) |
#18 |
Drives: 2014 Pearl White BRZ
Good write up and well documented.
When I make the leap - I am putting in the AVO system but this looks suitable for a pretty straightforward install. |
#19 |
Thanks for the post. I am looking at adding this if I do decide to keep the my FRS. BTW Was this on Palomar the temps you were getting in post 1?
#20 |
Drives: 2015 FRS
First logs are palomar south grade uphill. Second logs were east grade.
| The Following User Says Thank You to SkiRideDrive For This Useful Post: | jflogerzi (08-13-2015) |
#21 |
Bump.
#22 |
Bump.
#23 |
Drives: White brz series blue
Would this work in turbo applications or should I just get a standard oil cooler?
#24 |
Drives: 2015 FRS
I think that depends if the turbo utilizes the lines I tapped for cooling the turbo.
#25 |
It will be fine if you never plan on going on track. Kind of defeats the purpose of adding more power if you don't go somewhere you can drive hard, so the answer is no. Get some kind of proper laminova setup or air cooler with thermostat.
#26 |
Not a troll
Is this ok to use in climates that have winters that get to around -30*C?
| The Following 2 Users Say Thank You to Cole For This Useful Post: | SkiRideDrive (09-24-2015), Wayno (09-24-2015) |
#27 |
Either this or a block heater or an external oil warmer!
| The Following User Says Thank You to Wayno For This Useful Post: | Cole (09-24-2015) |
#28 |
Not a troll
| Perrin Oil Cooler Kit Installation and Review!!! | Sony | Engine, Exhaust, Transmission | 29 | 03-27-2017 02:03 PM |
| Texas Heat Sale- Perrin Oil Cooler 10% Off with Installation! | GSpeed | Southwest | 0 | 07-30-2015 02:47 PM |
| Beat the Texas Summer Heat! Perrin Oil Cooler 10% Off with Installation! | GSpeed | Engine, Exhaust, Bolt-Ons | 0 | 07-30-2015 02:44 PM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
| Oil Cooler usability: Changing oil, installation, etc | post_break | Engine, Exhaust, Transmission | 20 | 06-12-2013 02:36 AM |
