Old 07-16-2015, 02:01 PM   #295
wparsons
wparsons's Avatar
Maximum toe out will be with the LCA level, any movement in either direction will cause toe in. You'd have to see where the LCA was at the height you had it aligned at.
The toe link is shorter than the LCA, and is in front of the rear axle.
flickr
fika84 (07-16-2015)
Old 07-16-2015, 02:01 PM   #296
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Originally Posted by 7thgear View Post
asked this in a separate thread but got a hypothetical answer.
Does toe change in the rear with ride height changes?
And if it does even a little bit, which way does it change when the car goes up or down?
It's a different car and different suspension geometry... but the Miata rear toe does not change with suspension travel.
Link to MX-5 Forum
Our geometry will have a toe curve, but if you design suspension appropriately, the curve can flatten across a significant range (as with the Miata). I suspect that our suspension was designed similarly.
Edit:
Found the toe curve on an S2000. It's got a spread of 5/16" throughout the 5-1/2" of travel.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
fika84 (07-16-2015)
Old 07-19-2015, 07:08 AM   #297
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
soOoooo
experiment time
car currently has toe out in the rear, OEM everything
I put a plank on two jackstands at around center height of the wheel and measured the distance between the tire and plank (back and front of tire) with no spare in the car and an empty tank
then I loaded my trunk with 100 lb of weight and asked my dad (~220lb) to stand in it as well.
under compression the car goes into negative camber, so the distances from the plank increase... and the front of the tire increased by 1.2~3mm more than the back, meaning the front of the tire tucked in more than the back, which means toe-in under compression given my initial settings.
I hope
The Following User Says Thank You to 7thgear For This Useful Post:
fika84 (07-20-2015)
Old 07-30-2015, 12:21 PM   #298
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
do we know the length of our scrub radius in the front? (distance between OEM wheel centerline and the strut inclination where they meet at the ground?
Old 07-30-2015, 01:56 PM   #299
fika84
fika84's Avatar
Not that I know of.. These guys have the data, but they charge for it... http://www.morsemeasurements.com/
fika84 is offline   Reply With Quote
Old 07-30-2015, 02:15 PM   #300
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
Subscribed! I will read through later. I did suspension design in FSAE for 4 years. Psyched for this one and hope I can contribute.
SkiRideDrive is offline   Reply With Quote
The Following 2 Users Say Thank You to SkiRideDrive For This Useful Post:
fika84 (08-03-2015), Shankenstein (07-30-2015)
Old 09-23-2015, 06:13 PM   #301
RBbugBITme
Drives: S60R/Corvette
Not sure if I'm missing something but the OP has the rear motion ratio around .85 and links another thread that has it around .75.
From a sketch I built off the factory 3D model I have the MR changing from .768 at 2" of bump to .758 at 2" of droop so its .763 at at OEM ride height.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
The Following User Says Thank You to RBbugBITme For This Useful Post:
Shankenstein (09-23-2015)
Old 09-23-2015, 09:38 PM   #302
Shankenstein
Frosty Carrot
Whenever a forum member pipes up with new data, I generally assume that they're correct (because they took the effort to correct me). Laziness and bad science. Seems like the old data was better in this case.
If you see any other areas we can improve, don't hesitate to speak up.
Old 01-18-2016, 04:09 PM   #303
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Uh this hasent been updated in quite some time, but quick question. struts; are they simple or complex harmonic motion?
Old 01-18-2016, 04:33 PM   #304
RBbugBITme
College level analysis = simple
Real world analysis = complex
Ryan M.
Strange Engineering
cdrazic93 (01-26-2017)
Old 01-18-2016, 04:37 PM   #305
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I had a feeling itd be complex, currently my SHM and motion equations are of only the first and second order normal diff eq lol
Old 04-22-2016, 10:30 AM   #306
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
Hey guys, I have slight rubbing between my rear tires and fender on the outside. I'm wondering if installing whiteline rear upper control arm bushing will be enough to get the tire tucked in. I'm currently running 17x9 +35 with 255-40-17 RS3 on coilovers and SPC rear LCA. Anyone know how much maxing out the UCA bushing will tuck in the top of the tire?
infinity21 is offline   Reply With Quote
Old 06-24-2016, 11:58 AM   #307
Shankenstein
Frosty Carrot
Ran across an interesting blog post from a Miata dude who talks about developing a semi-active suspension system.
LINK to Article
Basic idea is to use valves to open bleed paths (compression and rebound, with check valves to keep each path independent). "Skyhook" theory is simple enough, since you support/stiffen the vehicle to resist roll and pitch.
I'm betting that we could develop a simple feed-forward system that uses gyroscope data with some filtering/dead zones to keep things robustly stable. A potentiometer could let you dial in the aggressiveness of valve opening.
Here's another thread about similar topics: LINK to Miata.net
Tein's EFDC Active Pro does modify damping... but this type of system is pretty slow and uses motors on the adjustment knob.
Ohlins has a similar system:
LINK to SportRider
Old 10-17-2016, 01:10 PM   #308
cool7
Drives: BRZ WRB
I searched for "rear lateral link" in this thread and didn't find any results.
Do we know how this link affects rear toe and caster under suspension travel?
The link in question is the left green arrow
cool7 is offline   Reply With Quote
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ Hachiroku BRZ First-Gen (2012+) — General Topics 350 02-02-2013 01:52 PM
Need opinions on two new items we're developing! yospeed Cosmetic Modification (Interior/Exterior/Lighting) 56 12-03-2012 02:13 AM
Chances of Someone Developing 5x114.3 HUBS (not spacers)? Entropy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-04-2012 03:35 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
