Old 09-19-2015, 06:02 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Stock Caliper pass, BBK Drivers?
So trying to troublshoote some strange noise, anyone have any insight if i could put a factory caliper and rotor on one side, and then bbk on the other, this will help me determine what side is causing the issue?
wouldnt drive on it much, other than a couple blocks to see if noise goes away.
gdrider77 is offline   Reply With Quote
Old 09-20-2015, 07:59 AM   #2
troek
troek's Avatar
Drives: 2012 Toyota 86
driving slowly around the neighborhood? shouldnt be a problem. i wouldnt go very fast.
troek is offline   Reply With Quote
Old 09-20-2015, 10:52 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Just jack up the front and Have someone spin the wheel by hand and be in the car to operate the brake pedal.
Hell of a lot less work.
Old 09-20-2015, 01:23 PM   #4
gdrider77
gdrider77's Avatar
Cannot spin the wheels by hand fast enough to replicate. Need to be going around 10-15
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 08:14 PM
Drivers side Brake caliper stuck shut? ABS engaged all the time. gdrider77 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-20-2015 10:02 PM
FRS/BRZ Affordable OEM Caliper BBK - Larger Rotors with Stock Calipers! RB Performance Brakes Brakes, Suspension, Chassis 60 08-11-2014 03:01 PM
Stock caliper model? skoodge Cosmetic Modification (Interior/Exterior/Lighting) 4 05-31-2012 09:41 PM
