Old 09-16-2015, 08:01 PM   #99
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Originally Posted by BRZ RN View Post
Im planning to put +45 with 5mm spacers on extended lugs. I hope it works T___T
Sent from my SGH-T999 using Tapatalk
I should have mentioned I do have arp studs
Sent from my HTC6525LVW using Tapatalk
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
BRZ RN (09-16-2015)
Old 09-16-2015, 11:40 PM   #100
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
When i stated extended lugs i meant extended studs lol
BRZ RN is offline   Reply With Quote
The Following User Says Thank You to BRZ RN For This Useful Post:
k.houan (12-02-2015)
Old 09-16-2015, 11:41 PM   #101
Gopherboy6956
Maybe you have both lol? Need to cover those threads !
BRZ RN (09-17-2015)
Old 12-14-2015, 12:17 PM   #102
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
For Reference - My Setup:
17x9 45mm offset
255/40 Z2 Star Specs
Tarmac 0 coils
Camber -1.5 front, -2.5 rear
I needed 10mm spacers and to raise my ride height a bit to make it fit in the front.
Photos on this setup:
No Rub as it sits now - that's AutoX and Road Course proven.
Why did you need to add the 10mm spacer up front? Was the tire rubbing the coilover Spring?
smg1138 is offline   Reply With Quote
Old 06-03-2016, 01:03 PM   #103
CxG
Drives: Pearl White '13 ZN6
Did you do anything else to the suspension or just that? Been looking at the tarmac 2's myself.
17x9 45mm offset
Tarmac 0 coils
CxG is offline   Reply With Quote
Old 06-03-2016, 02:00 PM   #104
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I tarmac 2s and the +45s. They fit fine with a proper alignment.
Edit: with 245/40/17 rs3s.
Mad_Mike is offline   Reply With Quote
The Following User Says Thank You to Mad_Mike For This Useful Post:
CxG (06-03-2016)
Old 06-03-2016, 03:03 PM   #105
Gopherboy6956
SMG1138 - I had to add the spacers because the inside of the tire would rub on the inner wheel well when i turned.
That's pretty much it - I know a few people with Tarmac 2's and they are very happy with them. I chose 0's just because i knew i wasn't going to adjust anything buy height.
The Following 2 Users Say Thank You to Gopherboy6956 For This Useful Post:
CxG (06-03-2016), smg1138 (06-03-2016)
Old 06-03-2016, 04:32 PM   #106
CxG
mind if I ask what brakes you're running?
Old 06-03-2016, 05:31 PM   #107
Mad_Mike
Mad_Mike's Avatar
Carbotech xp10 pads on stock calipers with titanium shims in the front for pdx events. Stock pads for dd and autox. Motul rbf600.
CxG (06-04-2016)
Old 06-03-2016, 05:36 PM   #108
Gopherboy6956
X2 for me - Carbotech all around for Track (10f, 8r) All stock calipers / separate track / street rotors. Steel lines and RBF
My 245/40 x17 dont rub at all (don't use spacers then) But my 255/40 will without the spacers. I think it's more a height thing and the -1.5 camber
CxG (06-04-2016)
Old 06-03-2016, 05:43 PM   #109
Mad_Mike
Mad_Mike's Avatar
I should have said earlier that I have 245/40 tires, so that makes sense.
CxG (06-04-2016)
Old 12-15-2016, 05:44 PM   #110
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Sorry for the thread revival,
But I'm still struggling with picking up either +35 or +45 RPF1s.
I currently have ST coils running -1.5 camber in the front and -2.5 in the rear. I ran an autocross event with my stock rims and tires and found out that I really need a wider set of 17' wheels. So RPF1s it is!
With my camber specs, and track use in mind, should I go for the 45's or 35's? After reading through a few threads I think I should jump on the 35s, however what is the general concession with this setup?
Sent from my Pixel using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 12-15-2016, 06:16 PM   #111
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
+45's rub on the inside fender liners at full lock, it's really minor if you're on 245's, might loose a string of rubber on the brake line bracket, bigger tires may have more of an issue.
The only time I go to full lock is in parking lots, if these are track/autox wheels/tires only it's a non-issue.
Most people try and get a wider track width so the +35's help there, but if you've got longer studs (I switched to ARP after stripping the OE) you can space out the +45's to get the same effect as the +35's.
I went with the +45's used as they came with good tires and were available. Buying new price being equal, +35 seems to be preferred, but nothing wrong with the +45's if you know what the potential problems are.
Thread revival is preferred to creating multiple threads.
ineedyourdiddly
Bowen (12-15-2016)
Old 12-15-2016, 06:32 PM   #112
Bowen
Powered by Crickets
Bowen's Avatar
+45's rub on the inside fender liners at full lock, it's really minor if you're on 245's, might loose a string of rubber on the brake line bracket, bigger tires may have more of an issue..
Thanks man,
Yea I figured I'd be safe with 45s since I have coil overs. My 18x9.5 Gramlights w/265's don't rub so +45 RPF1s wouldn't be too much of an issue. And since I don't plan on moving to a BBK then +35s aren't a necessity.
But for the track I think I'll pick up the +35s. The poke with my camber setup will help make the wheels fit inside of the wheel wells.
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 02:35 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 07:23 PM
