Old 09-15-2015, 11:21 AM   #2143
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by Wingnut537 View Post
Thanks, yeah it forgets random things at random times. Sometimes it good for a few days then it'll forget almost everything. I have emailed Ca-Fi and they seem to be aware of the issue with this (the new DashlinqCT) and are working on new firmware. I may just replace it with a known good unit (Eonon or similar) until the new firmware is out and then decide which to keep and which to sell.
Torque dose not currently work on the new units either. Honestly, the DashlinqCT is a huge disappointment and it makes me wish I had a got a Dashlinq4 before the new one came out.
Torque works fine. Buy one of these:
[ame="http://www.amazon.ca/gp/product/B00D5CE6XC?psc=1&redirect=true&ref_=oh_aui_detailp age_o00_s00"]GPFD ELM327 V1.5 USB OBD2 OBDII CAN-BUS Diagnostic Scanner for windows7,xp: Amazon.ca: Automotive[/ame]
And plug it in. I used it for torque until I found dashcommad (much better IMO)
The new CT does have its learning curves but I am in love with mine. The only thing I dont like is the audio quality sucks IMO.
DC2R (09-15-2015)
Old 09-15-2015, 05:22 PM   #2144
DC2R
Drives: 2014 Scion FR-S
Looks like Amazon Canada. Think this is the same?
https://www.amazon.com/gp/aw/d/B011K...A1CB3Z22TJJTAD
DC2R is offline   Reply With Quote
Old 09-15-2015, 05:36 PM   #2145
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yup, it is a ELM 327 (well knock off according to torque app haha) but it is 100% working. Just throw the CD out. DO NOT put in in you computer they like to put malware on those CD's from china haha!
DC2R (09-15-2015)
Old 09-15-2015, 08:18 PM   #2146
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've never used dashcommand, what do you like about over torque?
Old 09-15-2015, 08:53 PM   #2147
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Does the same thing and looks wayyyy nicer. Try it out. Has a free 30 minute trial
Calum (09-16-2015)
Old 09-16-2015, 07:18 PM   #2148
Wingnut537
Drives: 2015 FR-s RS1.0 0186/1500
That's the one I have. Will at Ca-Fi has confessed that the issues I am having are "known issues" with the version of firmware they put on my unit. He tells me that the "engineering department" is working a fix. and it should be ready within a week but would not commit to a date.
Wingnut537 is offline   Reply With Quote
Old 09-16-2015, 07:27 PM   #2149
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Really? mine works fine it has crashed a few times but nothing a close and reopen of the app cant fix? Bluetooth OBD is not supported at this time though.
Old 09-20-2015, 01:37 AM   #2150
TommyGT
Drives: Subaru Forester 2014
Hi Bros,
I am going to install new Dashlinq CT to my Subaru, which has OEM SWC with 3 wires.
According to dashlinqCT main wiring harness diagram, the OEM SWC-1 wire will connect to pin-4 on DashlinqCT, so where do I connect SWC-2 to Dashlinq?
I found on new Dashlinq CT has addition wiring harness (as see in picture) that has a wire marked as SWC 2, is it ok to connect the SWC-2 (from OEM SWC) to this wire (SWC 2) on Dashlinq?
Please advise,
DashlinqCT main wiring harness:
DashlinqCT addition wiring harness:
Thanks,
TommyGT
TommyGT is offline   Reply With Quote
Old 09-20-2015, 01:44 AM   #2151
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
You may need an adapter.
SilverlightPony is offline   Reply With Quote
Old 09-20-2015, 09:36 PM   #2152
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Originally Posted by TommyGT View Post
I am going to install new Dashlinq CT to my Subaru [2014 Forester], which has OEM SWC with 3 wires.
What is the model number on your Forester's factory HU? (you'll find one printed on the front).
Try this -- connect:
* Dashlinq CT's SWC1 input lead to Forester's SWC1+
* Dashlinq CT's SWC2 input lead to Forester's SWC2+
* Dashlinq CT's extra ground lead (on same harness with their SWC2 input lead) to Forester's SWC(-) / common lead
You'll need to find the menu on the Dashlinq CT to "learn" your cars SWC buttons.
The Forester's SWC wires are either on the 20-pin power/speaker harness (on 2014 models without OEM nav), or on the 28-pin mic/aux harness (on models with OEM nav). I can supply a harness for either of those, so you won't have to hack into the factory wires. For details, see my web site and/or send me your e-mail.
SVXdc is offline   Reply With Quote
Old 09-21-2015, 03:48 AM   #2153
TommyGT
Hi David,
Thanks for the reply, my Subaru is Forester 2014 and the HU model is Harman Kardon without Nav, I have ordered the wiring harness from you (20 pin + 16 pin for amp control wire) and waiting for delivery.
As information from previous Dashlinq4 model owners, I'll need to add a resistor (1.2k ohm) to combine my car's 2 SWC signal wires into the single input wire, but in Dashlinq CT there is SWC 2 wire that I am confusing if it's designed for SWC 2 or for other purpose (i.e CAN Bus). In fact I have raise the question to Ca-fi (Dashlinq manufacturer) but no response from them (poor service).
If any Bros have successful installing Dashlinq CT with Subaru OEM SWC (3 wires harness), please feel free to share your experiences.
Thanks in advance,
TommyGT
Old 09-22-2015, 06:20 AM   #2154
zussypoo
Drives:
Hi guys,
I just had a Dashlinq4 installed onto my '14 FR-S, and we spliced the orange wire(SWC?) from pin #8 onto the blue wire labeled AMP and connected the wire into pin #9 to get the door speakers working. Now the door speakers only works for radio, ipod app, bluetooth, and USB. It still doesn't work for the AUX. Is there anyone else that experienced the same issue and/or know a fix for it?
zussypoo is offline   Reply With Quote
Old 09-22-2015, 07:26 AM   #2155
SilverlightPony
Originally Posted by zussypoo View Post
Hi guys,
Do you get sound from AUX on the other speakers, or not at all?
Old 09-22-2015, 07:28 AM   #2156
zussypoo
Drives:
I was getting sound from AUX on an older iPod nano on other speakers just fine, but the door speakers are not working exclusively on AUX mode.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
