Old 09-13-2015, 12:34 AM   #309
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Updated OP
The Following 5 Users Say Thank You to Wayno For This Useful Post:
cawith (09-14-2015), chickencornsoup (09-13-2015), ollie (09-13-2015), phrosty (09-13-2015), steve99 (09-13-2015)
Old 09-14-2015, 05:08 AM   #310
ollie
ollie's Avatar
Drives: GT86
Hey Wayno thanks very much for your continued hard work. Also just wanted to check what headers are you running. Thanks champ
ollie is offline   Reply With Quote
Old 09-14-2015, 05:12 AM   #311
Wayno
Wayno's Avatar
PSR, functionally and quality equivalent to Gruppe-S and Tomei.
The Following User Says Thank You to Wayno For This Useful Post:
ollie (09-14-2015)
Old 09-14-2015, 05:19 AM   #312
ollie
ollie's Avatar
Drives: GT86
Awesome thanks, where did you get them from?
Old 09-14-2015, 05:25 AM   #313
Wayno
Wayno's Avatar
PSR. They're in NSW.
Old 09-14-2015, 07:53 AM   #314
ollie
ollie's Avatar
Drives: GT86
I am based in Sydney, did you end up getting EL or UEL? from one of your posts you suggested getting UEL headers if you have an AT.
Also looking at running E85 with your latest tune
How does all this affect NSW emissions?
Old 09-14-2015, 08:03 AM   #315
Wayno
Wayno's Avatar
I've no idea mate. At the least make sure you run a stock catted front pipe or after market catted front pipe with them.
http://www.prospeedracing.com.au/pro...t-coating.html
Old 09-14-2015, 08:45 AM   #316
ollie
ollie's Avatar
Drives: GT86
Thanks champ, yeah I am running the stock chatted front pipe after reading @steve99 post no need to change it as it does not really help with performance and can be to loud if you have a catless header.
Old 09-14-2015, 03:02 PM   #317
freerunner
freerunner's Avatar
Drives: GT86
Hey Wayno!
I'm currently taking a glance at the changes in the new v86 rom.
Is it intended that nearly half of the diagnostic sensors are disabled?
freerunner is offline   Reply With Quote
Old 09-14-2015, 04:23 PM   #318
elBarto
elBarto's Avatar
Drives: Toyota GT86
I noticed this also and I compared it with a complete stock rom, the only difference between the stock and the stg2 rom I used was:
P0420 Cat efficiency (because no more cat in the header)
U0155 Lost comm (sometimes OFT could create this problem)
All the others are on and off just like stock
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 09-14-2015, 06:08 PM   #319
cawith
Drives: Toyota GT86 6M/T
Updated OP
Thanks for the update!
Just adopting the changes to my A00G right now, but have a question:
Engine Load Limiter B Maximum and Engine Load Limiter C Maximum are both different for EL/UEL and MT/AT, right? Should I stick with those tables from your v85? I noticed a slight difference in the axis from A01I to A00G on the E85 tune but a big difference on the 98 tune.
I'm running catless UEL btw.
cawith is offline   Reply With Quote
The Following User Says Thank You to cawith For This Useful Post:
Chimera (09-14-2015)
Old 09-14-2015, 06:33 PM   #320
Wayno
Wayno's Avatar
They're only different between el and uel now. AT and MT are consistent.
cawith (09-14-2015)
Old 09-14-2015, 06:45 PM   #321
cawith
Okay, so I can copy/paste the table and let the X axis change itself both on E85 and 98?
Old 09-14-2015, 06:46 PM   #322
Wayno
Wayno's Avatar
Yep
cawith (09-14-2015)
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
