#365 |
Drives: brz
No one using ESC in Europe ?
Inviato dal mio GT-I9100 utilizzando Tapatalk |
#366 | |
Drives: DGM BRZ 6MT
#367 | |
Drives: BRZ Limited
I'm currently at 13 months since the order request (August 2014) Hopefully I will have this thing soon. I haven't seen any update on the international list unfortunately. |
#368 |
Drives: MR Spyder/GT86
Same here im also on the list but no idea how close im at getting This thing.
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter |
#369 |
Drives: brz
I had an ESC kit for my previous Car(mx5) and I sell it to another mx5 user because asking a conversion kit for BRZ I havn't received a commercial offer. I was thinking for a moment to buy a new kit v2, but I see isn't a good idea to do it now! too much to wait for me
#370 | |
Time Traveller
How did you like your MX-5 Kit? |
#371 |
Drives: brz
ESC v1 hardware work great, I had some problem with tuning service caused by different engine ( mine was 1.8L , and this is only an option for european market, and base tuning was developed for 2.0L) . Never finish the tune, i had a couple of issue in raining days and some strange knock correction @ low rpm and low load, but in other cases work well! Now I've a Brz w/ same Fa20 engine so i think for a moment to buy it again.
#372 |
Drives: White 2014 BRZ
#373 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I've had mine installed for a month now, so I suppose it's time to post here. I'm working on OFT tunes and Procede throttle maps for the AT's. Will post more here as it comes.
#374 |
I think I have pinned down the reason behind my recent high-mileage tune. My tune has enough power in the .3 load areas to coast, cruise, and ever-so-slightly accelerate. The .4 load column is where port injection starts. Cruising with only direct injection is more fuel-efficient, so, I'm currently working on the transition to the .4 load column to make it more efficient as well, and will post my results as I find them.
#375 |
Port Injection Pressure Compensation
While looking for pressure related tables to explain why my car doesn't speed up when the pressure rises above 13 PSI below 3000 RPMs, I found the following table, "Port Injection MRP Compensation". Where MRP stands for manifold relative pressure. Normally it stops at 0 PSI, but I added the same relative amounts all the way up to 15.47 PSI. Maybe this is why it seems to wait till the RPMs build before it can use the pressure of the ESC. I'll be testing this out as well as several slightly modified tunes this weekend to see what difference it makes.
#376 | |
Drives: Scion FR-S A/T, Whiteout
#377 | |
New tunes and Procede throttle map
#378 |
Drives: 86 GT MT
The controller was repaired, upgraded to current specs and cooling, I upgraded to the current 2 stage throttle switch and wiring harness.
Am I hitting the thermal protection mode?? Hard street driving, 2nd to 3rd gear full acceleration, everything works fine for a couple of minutes, then, During long accelerations, boost and voltage down to lowest of 17-18V in second gear, then change to 3rd gear and the voltage goes to 25.9V and boost/power is obviously less. (cool weather this morning). I can slow down and do the same again. Is this normal thermal protection mode? Any suggestions to get it working fully for longer? I have seen Steve's cooling duct. any other suggestions. |
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6049 | 06-25-2026 10:40 PM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
