#15 | ||
Drives: 2015 Series.Blue
Sport mode should get BETTER mileage so long as you're not trying to coast (on normal it won't engine break, allowing engine RPM to drop but rolling speed to not as the converter isn't locked up). The converter is going to be locked up at cruise anyway, but a lower speeds I'm not so sure. Quote:
I meant more that a lot of people are somehow scared of the higher gears and feel that anything under 2K RPM is hurting the engine. On flat level ground, the engine will happily cruise at just over 1.5K PRM. Hell, I remember a thread about someone that only used 6th on the highway if there wasn't traffic, and would stay in 5th instead ![]() I'm curious what the ECU is doing but he'd need to log to find that out. |
| The Following User Says Thank You to Poodles For This Useful Post: | strat61caster (09-10-2015) |
#16 | |
Drives: 2014 Subaru BRZ Limited 6smt
#17 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Or if I'm taking the GF down to peir 39
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#18 |
What octane fuel are you using? Has this just started with your last fuel fill? Change of brand of fuel?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#19 |
Mentat
Drives: 2013 Scion FRS 6MT
That is pretty good for 100% city.
#20 |
Drives: 2015 FR-S (Halo)
In my entire ownership the best I have ever averaged is 23.7, which ironically it climbed to from 23.5 while I was driving extra hard for a week. This is also with the AT which has much better mpg.
My friend's m5 is lucky to get 11
#21 | |
Drives: FT86
But these cars are very sensitive to how you drive you need to be using the highest gear possible and light throttle to get decient economy when you changed exhaust was that header or just catback did they use new gaskets , exhaust leaks at header can cause issues with 02 sensor readings but not in catback area if your on 91 fuel with stock tune in high temps its going to knock and the ecu will pull a crap load of timing to protect motor, especially if your driving in the below 4000 rpm area all the time. and the IAM ignition advance multiplier will never reset unless you do some light steady throttle runs to above 5000. It will reduce again when it knocks enough. if you had a tuning device we could log it and fix it but you could try occasionally doing a couple of light steady say 10 to 15% throttle runs in second or third and jist let the rpm slowly clim to 5500 or so this will bump your iam up , untill you get more knock, but it will probably result in slightly better economy. you logs would probably look like this iam at 0.2 instead of 1 and evry time you get on the throttle hard it knocks like crazy. the stock tune runs like crap on 91 fuel, its not dangereous just way below optimium http://datazap.me/u/steve99/south-af...&mark=975-1047 |
#22 |
Drives: FR-S H Lava
Shifting @ 4K+ most of the time.
Lots of highway Still mpg is 21.8 here for my 2013 MT |
#23 |
Killed Scion
Wow lots of people get significant lower mpg than me.... making me feel like i drive like a grandpa...
| The Following User Says Thank You to MisterSheep For This Useful Post: | Packofcrows (09-11-2015) |
#24 |
Drives: SOLD...
Only time I get less than 25mpg is trackdays...
And I never shift below 4k.. Best I have seen is over 35mpg, 2hours on the 401 with cruise set at 110km. This is the 3rd summer for my car with 45,000kms on it. Mileage has improved slightly over time.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
#25 | ||
hey you, yeah you <3
Drives: 2014 37J FR-S
Lots of highway driving can be sidetracked/skewed in terms of mpg by just a few lousy city miles. For example, my hwy driving of over 180 miles (tracked by car) showed me getting 32.8 mpg, I drove in town for about 20 miles and my mpg avg dropped to 22.6. That's just 20miles! I shift at 3.5k on avg. Joining hwy I shift at 4.5k-5k if you shift around 2.5-3k, I believe, you get the best mpg. Downside is you gotta drive like a granny and take a deep breath every time you are itching to hit a 6k rev. But....if I would have chosen a vehicle for its MPG, I would have gotten a 2015 Corolla, 2013 SI Civic or Prius. I chose the FRS for it's rich history>>>enthusiast old ae86 owner>>sporty look>>go-kart feel>>>mpg>>>room>>>uniqueness>>>boxer engine Quote:
Are you using 93 gas... or lower? Avg is 20 city, 30 hwy....30+ is a gift! Tire pressure ok? In heat tire pressure should expand. Also, for my parents old Ford Windstar, when we dropped psi on tires by 2-4 we got 3-4 better mpg. Maintenance is key and slow ease of driving takes dedication. 93 gas will give you a better mpg than 91.
#26 |
Drives: 2015 BRZ Sport Tech CWP
I've been averaging 7l/100km consistently , which is 33.6 mpg, pretty much since I have the car (6 months ago). I don't baby it, but I don't trash it either. Normal, but spirited driving style I would say. I use all the gears and the whole rev range when driving.
I once got almost 37 mpg with one tank of gas taking it easy.
| The Following User Says Thank You to Guru Woodman For This Useful Post: | Packofcrows (09-11-2015) |
#27 |
Killed Scion
I drive like that most of the time. I shift no higher than 3k rpms. I don't like to beat on my car that much. But sometimes I do like to take it on spirited drives. I'm averaging a full dedicated spirited drive (1 hour mininum) once a week now.
#28 | |
Yes! It's possible on semi flat or mostly flat hwy driving! None of my close buds believe me, but it is possible. Even 40mpg! I noticed I get 35-42mpg driving from Monterey to outskirts of LA without traffic but on way back I get avg 30-34mpg. I'm guessing due to the elevation changes.
| Is it just me or is the paint really shitty? | AppleSauce | Issues | Warranty | Recalls / TSB | 30 | 09-01-2015 10:44 PM |
