Old 09-08-2015, 07:08 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OpenFlash Tablet: OTS v2.068 released (FFS/LC for D00C roms)
Hi guys,
New OTS map folder has just been released and is now available to download HERE
Please read the change log in the included Release Notes file. It says:
8/08/15
v2.068
-Added Flat-foot-Shift (FFS) and Launch Control (LC) functionality to all 6MT D00C ROMs.
-Added revised XML file (with FFS and LC defined) for D00C Calibration ID.
This means that the ONLY change we made was to add FFS and LC to D00C ROMS and revised the D00C XML file accordingly (courtesy of Td-d). Tuning has not changed. So unless you have a D00C ROM, this update is of no relevance to you
Again, be sure to only use the new XML on the new ROMS with the LC/FFS coded added. Do NOT use it with older D00C ROMs. If you try to adjust LC/FFS settings on older D00C ROMs without FFS/LC code, you will brick your ECU.
One way to making sure that you are using the correct ROM is to view the default data for Launch Control RPM Delta. It should be set to 2000RPM. If all you see is a black-filled window, STOP RIGHT THERE. You are using the wrong ROM.
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 16 Users Say Thank You to Shiv@Openflash For This Useful Post:
BillyStrato (09-10-2015), cameronjones239 (09-09-2015), Chad11491 (09-08-2015), D_Thissen (09-08-2015), icybrzzz (09-09-2015), JonAvalon (09-08-2015), JPxM0Dz (09-08-2015), kch (09-08-2015), Mufasah (09-12-2015), phrosty (09-08-2015), RustySocket (09-08-2015), Snyperiflex (09-10-2015), swarb (09-08-2015), tato.valverde (09-09-2015), Wayno (09-08-2015), _gt86_user (09-10-2015)
Old 09-09-2015, 07:41 PM   #2
Frsboxer
Drives: 2015 scion frs
Where is the correct rom located I downloaded the new v2.068 but I don't see the d00c rom anywhere
Frsboxer is offline   Reply With Quote
Old 09-10-2015, 04:29 AM   #3
Snyperiflex
Snyperiflex's Avatar
Drives: Scion FR-S Release Series 1.0
Gotta use the new XML
Snyperiflex is offline   Reply With Quote
Old 09-10-2015, 07:44 AM   #4
Frsboxer
Can you tell me where the new xml is
Old 09-10-2015, 09:40 AM   #5
philooo
Drives: 13' Scion FRS Track car
it would be good to link again to the ressources allowing to understand how this works.
I know it is all natural for you guys, but personally I did it 6 months ago and I already forgotten all about the process
would be nice if the open flash could detect what to do once plugged into our cars ...
philooo is offline   Reply With Quote
Old 09-10-2015, 10:51 AM   #6
Frsboxer
I agree when I got my oft I downloaded all the stuff I needed the and since forgotten how to do it. I think a direct link to the xml file would be a great help
Old 09-10-2015, 11:11 AM   #7
Snyperiflex
It's in the OTS v2.068 folder, in the "v2.08 XMLs [MUST USE THESE FOR EDITING]" folder
I think this must be a typo, it should say v2.068 lol
http://www.ft86club.com/forums/showthread.php?t=71157
http://www.ft86club.com/forums/showthread.php?t=79152
http://www.ft86club.com/forums/showthread.php?t=74754
The Following User Says Thank You to Snyperiflex For This Useful Post:
Frsboxer (09-10-2015)
Old 09-10-2015, 11:45 AM   #8
Frsboxer
Ok I seen that file. The one that said for editing so it's in that one
Old 09-10-2015, 05:22 PM   #9
slowest86
Drives: slow frs
just tryed this. It works great, thanks very much!
slowest86 is offline   Reply With Quote
Old 09-10-2015, 05:46 PM   #10
Krazy
Krazy's Avatar
Drives: FR-s
hey guys, how do you set up LC and FFS to certain RPMs?
Krazy is offline   Reply With Quote
Old 09-19-2015, 11:27 AM   #11
Kyle106
Kyle106's Avatar
Drives: 2013 WRB BRZ Limited
Okay, stupid question.... what is D00C ROM.
Kyle106 is offline   Reply With Quote
Old 09-19-2015, 12:15 PM   #12
SlammedSilly
Drives: 2015 Ultramarine FR-S
D00C is the ECU code, i guess you call it that, that informs you what tunes you can use on your ECU... if im wrong, someone correct me, im like 99% sure im right though
SlammedSilly is offline   Reply With Quote
Old 09-19-2015, 12:47 PM   #13
Vroomin86
Drives: 2015 Fire
nevermind... got it
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
Old 09-19-2015, 07:18 PM   #14
steve99
Drives: FT86
guys see the Tune Tweaks or OFT TIPS links below for info on LC/FFS and links to shivs posts
read shivs post here http://www.ft86club.com/forums/showthread.php?p=2383903
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 11:17 AM
FS: New OpenFlash Tablet, Used OpenFlash Header, New Crawford BPB FT86POWER Engine, Exhaust, Bolt-Ons 10 11-27-2015 09:28 AM
FS: New Openflash Tablet, New Openflash Header, New Ducktail Spoiler, NewCrawford BPB FT86POWER Engine, Exhaust, Bolt-Ons 5 09-16-2015 04:26 PM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 03:56 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 07:20 PM
