Old 09-07-2015, 11:52 AM   #1
LWAA
Drives: Subaru BRZ
Easy mods for power and sound.
Can you suggest the best mods that can be done by a non mechanically minded owner* to give more power and a better sound?
I'd like to get more power in 5th (I'm assuming it's 5th...it changes up again when I get to around 130-140kph), it seems to struggle a little between 100-130kph, then really picks up after it changes up to 6th.
I love the sound too but it could be improved too.
Any thoughts?
I'm driving a 2015 sport-tec AT.
* I have friends who would help with anything that needs more complex changes.
Sent from my iPhone
LWAA is offline   Reply With Quote
Old 09-07-2015, 12:00 PM   #2
mikool
mikool's Avatar
Drives: 14' Firestorm FR-S
The easiest to install for sound and a little bit of power would be intake and cat-back. On that note you would have to do your own research on which sounds you would prefer. If you don't mind the current intake and catback, you could do a header change, but that you will have to go cat if running no tune, unless you get lucky with no codes being thrown or just don't care if you go non-cat. You will also have to do research on the sound you prefer.
mikool is offline   Reply With Quote
The Following User Says Thank You to mikool For This Useful Post:
LWAA (09-07-2015)
Old 09-07-2015, 12:24 PM   #3
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
A header and tune would be the only thing to give you noticeable power gains Without going FI. An intake will give you at best 5-7 hp and a catback being super optimistic just 1 or 2 IF any. A header and tune will eliminate the torque dip as well as adding 10-20hp
Chad11491 is offline   Reply With Quote
Old 09-07-2015, 12:34 PM   #4
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
Open Flash Tablet, Intake tube and filter, and remove noise maker assembly. Proven 10-20 horsepower, easy reversibility, much better sound and MUCH better drivability in my '14 BRZ limited Auto.
MGPAX is offline   Reply With Quote
Old 09-07-2015, 12:34 PM   #5
Kerune
Kerune's Avatar
Drives: Lexus RC-F
I'm running a decent combo of a good catback and E85 tune and it's a night and day difference from stock without going overboard. The sound is aggressive and isn't obnoxious and the E85 tune is a surprising step up.
Kerune is offline   Reply With Quote
Old 09-07-2015, 12:43 PM   #6
E85 is very, very hard to find in Southern Ontario so you may not want to consider it as a viable option. Now if you do have some local it is certainly a way to go but you would have to plan any longer trips very carefully.
Old 09-07-2015, 01:16 PM   #7
Kerune
Kerune's Avatar
Drives: Lexus RC-F
Yeah it's not viable for very many people. I have two stations both 15-20 miles away and I was originally going to get the Flex Fuel kit but I wanted to feel the E85 tune prior to buying a kit + replacing my OFT. You're right though, I dread thinking of going far unless I had the FF kit but I at least carry the tablet around xD
The Following User Says Thank You to Kerune For This Useful Post:
Tcoat (09-07-2015)
Old 09-07-2015, 04:24 PM   #8
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
http://www.ft86club.com/forums/showthread.php?t=81493
The Twins make me smile
The Following User Says Thank You to soulreapersteve For This Useful Post:
LWAA (09-07-2015)
Old 09-07-2015, 04:30 PM   #9
LWAA
Drives: Subaru BRZ
Thanks. A very interesting read even with the appalling grammar.
Sent from my iPhone
Old 09-08-2015, 02:57 AM   #10
wil5bart
Drives: '16 BRZ
I also recommend a new intake and free flowing exhaust for an easy and affordable mod that can give some hp gain.
wil5bart is offline   Reply With Quote
Old 09-08-2015, 09:44 AM   #11
cjd
cjd's Avatar
Drives: 2017 BRZ
Intake and exhaust will do little beyond noise.
Header and tune, overpipe helps, the rest is optional but will change sound (louder, typically more brash and annoying)
Intake, probably nothing to a little, most need maf rescaled to work right (tune) though the Grimmspeed has been good without for me.
Old 09-08-2015, 09:51 AM   #12
DarkSunrise
DarkSunrise's Avatar
For power and sound, I'd go with a header + tune. That will net you 20 whp and a nice UEL rumble. E85 tune is even better (30 whp) if it's available in your area.
2022 BRZ Build
2013 FR-S Build
Old 09-08-2015, 10:59 AM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I'd buy new car
Old 09-08-2015, 05:39 PM   #14
LWAA
Drives: Subaru BRZ
Originally Posted by zc06_kisstherain View Post
I'd buy new car
Haha. I just did!
Sent from my iPhone
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 09:19 AM
easy OEM Sound System Upgrade with DSP OnkelC Electronics | Audio | NAV | Infotainment 0 05-24-2015 09:12 AM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 08:53 PM
Easy to Do Mods steve87j Scion FR-S / Toyota 86 GT86 General Forum 23 12-23-2012 12:11 AM
A couple of Mods & Sound Upgrade ravenMTgirl Electronics | Audio | NAV | Infotainment 23 09-02-2012 01:52 PM
