Old 09-06-2015, 08:23 PM   #197
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by SilverFRS View Post
At 1.2" lower than stock, ended up at -1.8 left, -2.5 right, so I bought cheap SPC lca, not sold on their adjustment method, haven't installed yet, any body weigh in on SPC?
@CSG_David doesn't recommend SPC if you do any sort of performance driving.
http://www.ft86club.com/forums/showt...81#post1659981
aegisdrgn is offline   Reply With Quote
Old 09-06-2015, 09:14 PM   #198
CSG Mike
CSG Mike's Avatar
I wouldn't recommend the Flex Z if you're doing anything more than super casual spirited driving.
CSG Mike is online now   Reply With Quote
Old 09-06-2015, 09:54 PM   #199
bfrank1972
Drives: 2013 FR-S Argento
hah, I love that... "super casual spirited driving"
Seems to me that the stock BRZ/FR-S setup is great for spirited driving and occasional track work. Most of us are not track junkies, just guys looking for some driving education and a good time.
Would you say this Tein suspension is better than the stock suspension for track work? (i.e. more than super casual spirited driving)
Old 09-06-2015, 10:05 PM   #200
CSG Mike
CSG Mike's Avatar
Absolutely, but it'll wear the damper at an accelerated rate if you're setting the dampers to a setting more suited for track driving. If you're tracking on the street setting, then life isn't really affected.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
bfrank1972 (09-07-2015), GT86_PRAGUE (09-11-2015), tracerit (09-06-2015)
Old 09-06-2015, 11:22 PM   #201
tracerit
Drives: '13 SSM BRZ Limited 6MT
Funny, I was just about to come on and ask if riding on 0 clicks would wear the damper faster.
I havne't been too pleased with the Flex Z at 5 clicks coming from stock shocks/Eibach Prokit but after setting it to 0 clicks the car definitely improved handling wise. It's just a tad bit harsh, if I can even call it that, comfort wise. 10 clicks was hilarious and pointless at the same time but a setting I'll use when driving others. It's been two weeks since I've driven on the Prokit so my ability to compare is fading but I have a feeling 2 clicks will be my sweet spot.
tracerit is offline   Reply With Quote
The Following User Says Thank You to tracerit For This Useful Post:
shellslinger (09-07-2015)
Old 09-07-2015, 03:42 AM   #202
shellslinger
Drives: Whiteout FRS
Definitely interesting to hear. I have the Japanese spec Flex Z's and I find anything close to 3 - 4 clicks its really harsh on the streets especially on Los Angeles roads. I'm also running thicker sway bars as well. But then again, the definition of "harsh" is different for everyone.
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
jawnthen (09-08-2015)
Old 09-07-2015, 05:20 PM   #203
JGalp
Drives: 2015 CWP BRZ Limited
I've had the Flex Z's for a little under a week, got them installed and adjusted with Darin at West end, started of with 7 clicks from stiff in front and 8 in back as the manual suggests, felt very similar to stock and i wanted a little firmer so i went 5 in front 6 in back, still wanted a little more. now I'm on 4 front 5 back. still pretty comfortable but could be a little firmer, might try 3/4 next. haven't reached that point where its uncomfortable for me
JGalp is offline   Reply With Quote
The Following User Says Thank You to JGalp For This Useful Post:
CSG Mike (09-07-2015)
Old 09-08-2015, 10:38 PM   #204
tracerit
I went in to get an alignment but after seeing my rear camber at -1.9 L, -2.5 R, I'm considering getting LCA to bring them both to -1.5 L/R. I'm not sure if it's worth $200 (for SPC LCA) to fix that just for mainly highway driving. Opinions?
Old 09-09-2015, 01:33 AM   #205
CSG Mike
CSG Mike's Avatar
-2.5 is on the higher side for purelys treet use, but not too extreme. I'd say keep an eye on your tire wear, and rotate tires with the fronts to even it out.
The LCA would allow you to even it out...
tracerit (09-09-2015)
Old 09-09-2015, 01:38 AM   #206
tracerit
After reading multiple threads and with your input, I'll do exactly that. The question now is should I match the front camber to something along the lines of -2.0 L/R tro bring it in line with the uneven -1.9/-2.5 L/R rears? My original plan was:
Camber Front -1.5
Camber Rear -1.5
Toe Front -0.05 (for slightly better turns)
Toe Rear 0.05 (for highway stability)
Old 09-09-2015, 01:42 AM   #207
CSG Mike
CSG Mike's Avatar
Camber Front -1.5
Camber Rear -1.5
Is your priority grip or tire life, because right now, you're contradicting yourself...
Lets make a scale of 10 total points. Split those 10 points between tire life and turning/cornering grip.
Old 09-09-2015, 01:50 AM   #208
tracerit
7/10 tire life, 3/10 grip.
I phrased my question after reading a few comments in this thread (post #11 and down)http://www.ft86club.com/forums/showt...t=control+arms Seems a few posters mentioned if one is running a certain camber in the rear, why not match the front as well. Since I can't change the rear without LCA (which I plan not to at this point), I'm c urious if I should match the front to the rear or keep the rear at the original -1.5 that I had planned. Hopefully that made sense, all this suspension talk is new to me haha.
Old 09-09-2015, 02:27 AM   #209
CSG Mike
CSG Mike's Avatar
I'd say run 1/16" toe-in front and rear. Get camber bolts to reduce front camber.
tracerit (09-12-2015)
Old 09-10-2015, 04:35 PM   #210
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I am new to suspension as well but i would get LCA.
do it at one time!
I got good deal on used Cusco LCA. i saw some used one on forum for used. grab those.
I need time to install mine..question is what setting i need to go with...
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
