| Software Tuning Discuss all software tuning topics. |
Drives: 2015 Subaru BRZ Limited
Oft disappointment
So I have a 15 brz limited 6mt. I picked up an oft and flashed the appropriate stage one ROM for my calibration #. My car is basically stock aside from a k&n drop in. I have waited 5 days before posting here. I cannot tell any difference from the stock tune. I wanted to ask you guys if there's a considerable difference with a stock car.
Thanks in advance... |
#2 | |
Drives: FT86
what is your rom calid like ZA1JD00C can you log tune with oft and post log with knock parameters IAM FLKC Knock Correction AFR maybe ring or email the openflash guys |
#3 |
Running 93 my calid is ZA1JD00c. I'm not sure how to log tune but I'll try it when I get home from work today.
#4 |
Drives: 2015 Subaru BRZ Series Blue
Do a 20 roll up to 60-70 from 2nd gear, then a 65-70mph pull up to about 80-85 in 5th and 6th. Revert to stock tune and repeat. See if you notice it then. When I first did mine I felt the same, didn't notice hardly any change. After going back to the stock tune it made me appreciate the OFT tune a lot more.
http://instagram.com/cameronjones239
2015 Subaru BRZ Series Blue Build http://www.ft86club.com/forums/showt...09#post2002909 |
#5 |
Drives: 2017 BRZ
It's not a world of difference, but subtle. It also opens the door for bigger changes. Not sure what you were expecting, but the suggestion of doing some runs and then going stock is good, if you want to feel the difference. Though I've always found it takes a few drives for things to settle, out something like that.
#6 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
The main change is the torque dip between 3500-4500 is lessened. Just a tune does help, but you'll notice a large change when adding a header or E85
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
| The Following User Says Thank You to Aztec For This Useful Post: | golfyankee2121 (09-06-2015) |
#7 |
Drives: 2015 Scion frz
I bought oft for my 2015 brz not expecting much of a difference. When I first flashed it I ran the 91 octane stage 1 tune. Drove around for a few days like that, and then threw on the 93 octane stage 1 EL tune. I could definitely feel the difference over the stock tune just daily driving. Feel more power down low and the throttle response is better. After driving for a few days with the 93 tune I switched back to stock tune and that's when I realized how much the car is improved with oft.
You sure you loaded the EL stage 1 tune? |
#8 | |
EL as in Equal Length Header? I have stock the header in
#9 |
Yes you should load the EL - equal length header stage 1 tune for a stock brz/frs
#10 |
Drives: Crystal Black BRZ(Sophia)
#11 |
From what I've researched thats the tune that was recommended to run on a stock brz/frs.
Maybe someone with more knowledge on this could chime in? It has worked for me and the car feels great with this tune. |
#12 |
Drives: 2014 Scion FRS monogram series
Do you have a manual or auto transmission?
#13 |
The Fail Boat
Drives: CWP S.B.
Oft disappointment
You are just expecting a bit much I guess.
Oft does a bit more if u have a header. But it's still an offshelf tune, don't expect too much. You would get more from a proper tune/header/e85. |
#14 |
Drives: 85.5 Porsche 944, '15 mustang GT PP
I'm very pleased with mine with a jdl uel. I think I will eventually go the ecutek/flex fuel route though long term.
| Valenti Tail lights disappointment/question | kincito | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-02-2014 09:47 PM |
| Pre-Order Disappointment woes | Draco233 | BRZ First-Gen (2012+) — General Topics | 16 | 03-03-2012 04:31 PM |
| BRZ pricing disappointment thread | dsgerbc | BRZ First-Gen (2012+) — General Topics | 42 | 02-29-2012 02:37 PM |
