Old 08-26-2015, 11:57 PM   #15
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Stuck your finger in the hole, didja now...
I came in expecting to say "replace the cam plate" and left having learned something new.
aegisdrgn is offline   Reply With Quote
Old 08-26-2015, 11:57 PM   #16
Originally Posted by Dylan0123 View Post
.......... I wonder if i'll be able to buy just the o-ring separately or if i'll have to buy that entire sensor
I did get to stick my finger in the hole and touch the cam, so that was kind of exciting
Well, Dylan0123, you can buy O rings at almost any hardware store.
However, they may not be TRD certified or able to handle a boosted engine ..... (just kidding).
Now, about you getting all excited about touching a cam, ...... I wouldn't know where to start .......
PS - good pictures!
Old 08-27-2015, 12:13 AM   #17
Originally Posted by twag4 View Post
My guess is that it wasn't the grade 5 bolt...
Yep, @twag4 figured it out ......
After I took the badly bent ram tube off and my grandpa and I heated it up with a torch and sledged on it against a RR rail, till it was almost round, the hay baling resumed.
My grandpa explained to me that "sheer" bolts are meant to "sheer" and don't have markings on the head. The "case hardened" bolts - as he called them, have marks on the top of them ....... aaaaaannnnnndddddd ..... they don't sheer.
Sorry ...... ....... I digressed again ..........
So, Dylan0123 ...... didja ya get the leak stopped ..... ??
Old 08-27-2015, 07:52 AM   #18
Dylan0123
Drives: '13 FR-S w/ P&L turbo
Well i didnt get a chance to run it so im not sure if its still seeping or not but i'll check it out this weekend. I always like to buy oem parts even for small things like that oring because you never know if its made out of a specific material or its an oddball size only made for that application
Dylan0123 is offline   Reply With Quote
Old 08-28-2015, 06:50 AM   #19
empower-auto
Kouki-Monster
empower-auto's Avatar
Assuming this could be a pressure sensor associated with AVCS functions
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 09-04-2015, 01:16 PM   #20
Dylan0123
Update: i cleaned the o-ring and everything surrounding it, reinstalled it and havent had any issues with it again. I'll keep an eye on it
Old 09-04-2015, 01:23 PM   #21
aegisdrgn
aegisdrgn's Avatar
Thanks for reporting back!
Oil leaking oil pan? Astroboy Engine, Exhaust, Transmission 9 01-30-2015 03:32 PM
Oil leaking.. Senzai Issues | Warranty | Recalls / TSB 3 10-02-2013 12:02 AM
Oil leaking? grgonium CANADA 7 07-30-2013 04:08 AM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
