Old 08-26-2015, 07:11 AM   #1
Dylan0123
Drives: '13 FR-S w/ P&L turbo
What is this thing leaking oil?
I noticed this sensor on the passenger side of the motor seems to be seeping oil. Could someone tell me what it is and how i can fix it? Its just above what im guessing is where the camshaft is
I was going to loosen that bolt and pop it out but i thought i'd try to find out if theres an o-ring or a gasket or rtv under it first.
Dylan0123 is offline   Reply With Quote
Old 08-26-2015, 08:38 AM   #2
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Cam sensor? Probably has an oring.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 08-26-2015, 08:45 AM   #3
And or a gasket?
Old 08-26-2015, 11:54 AM   #4
qwerty66
Drives: frs
o-ring
qwerty66 is offline   Reply With Quote
Old 08-26-2015, 12:55 PM   #5
1Cor10:23
1Cor10:23's Avatar
Cam sensor should be dripping below....this could be a long shot but could it just be sloppy use of your dipstick? It's in the path of drawing the stick out of the engine.
Old 08-26-2015, 01:30 PM   #6
Dylan0123
No chance ^ lol but thanks for the suggestion
Old 08-26-2015, 02:48 PM   #7
humfrz
Well, the first thing I would do is to clean the oil from the area then torque the bolt down ..... and see if the leak stops.
If it still leaks, I'd suggest you remove the part, clean it up and re-install, using some gasket stuff (like ATV).
That ought to fix er up ......
humfrz
Old 08-26-2015, 04:02 PM   #8
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
humfrz
I know RTV can fix many things, but being a mechanic. I absolutely HATE when a vehicle comes in and has rtv covering something that should have a gasket, or an o-ring on it.
I agree with what you said about the cleaning/and re-torqueing it, but if the o-ring/gasket is damaged, do it right the first time with the right part. Will save you a headache down the road.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
Old 08-26-2015, 04:19 PM   #9
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
humfrz
wouldn't it be torqued to spec before they leave the factory?
Old 08-26-2015, 05:48 PM   #10
Dylan0123
Maybe it vibrated loose or after going through so many heat cycles the bolt is backing out slightly. I'll see how tight it is when i get home here in a minute. I definitely want to replace it with an oem oring or the right kind of gasket material, im not going to just slob on some random sealant from autozone
Old 08-26-2015, 06:20 PM   #11
humfrz
Oh, I agree with replacing a damaged O-ring or gasket.
However, it has been my experience, that sometimes, gaskets (except head gaskets) could use a little help ..... .
humfrz
Old 08-26-2015, 06:40 PM   #12
humfrz
Hopefully so, however, sometimes bolts become un-torqued .....
I remember, back in the day, I was baling hay with an old IH, PTO driven baler, and noticed the "sheer" pin was loose.
So, I put in a brand new "bolt" ...... a nice shiny one, with three dashes stamped on top and torqued it down good (tight. then another 1/4 turn with a 1/2"drive ratchet). That's 87 ft lbs, for those of you that don't have a calibrated wrist ....
Fired that machine up and the first time the plunger/ram got stopped by a restriction in the shoot ....... all heck broke loose ...... guess what "gave" .... and why .... ??
First one to guess correctly ....... WINS!
humfrz
Old 08-26-2015, 10:44 PM   #13
twag4
Drives: frs
humfrz
My guess is that it wasn't the grade 5 bolt...
twag4 is offline   Reply With Quote
Old 08-26-2015, 11:29 PM   #14
Dylan0123
Lol i dont know about that farm machinery but it makes me feel better to know theres a good ol' country boy chiming in on my thread!
There was an o-ring under there, it appears to be in good shape. Im guessing its just leaking because theres some extra pressure in the crankcase as a result of the motor being boosted. I do have an oil catch can at least.
For now i just cleaned everything up and put it back in place. I wonder if i'll be able to buy just the o-ring separately or if i'll have to buy that entire sensor
Does anybody know what this sensor is? i couldn't see how it would work. I need to get a factory service manual.
I did get to stick my finger in the hole and touch the cam, so that was kind of exciting
Oil leaking oil pan? Astroboy Engine, Exhaust, Transmission 9 01-30-2015 03:32 PM
Oil leaking.. Senzai Issues | Warranty | Recalls / TSB 3 10-02-2013 12:02 AM
Oil leaking? grgonium CANADA 7 07-30-2013 04:08 AM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
