#15 |
Drives: '22 WRB
The HANS needs to be integrated with a roll bar or cage minimum. No way I'm holding my neck in place in the event of a rollover without a cage. I've discussed this several times. There's really not a good happy middle ground on this unfortunately.
| The Following User Says Thank You to trippinbillies40 For This Useful Post: | CSG Mike (09-04-2015) |
#16 | |
Chin Track Event Manager
Drives: 15 Series Blue
Im afraid I can't help on that as I've never seen a rollover at any event I've ever been too. I never even heard about a rollover at an event with the group I run with in my 12 years with them. I have seen plenty of cars run into stuff though. I bring that up in the copy I posted. The important part is that we have the information to make our own decisions.
Jim Pomroy Chin Track Days Event Manager.
15 Series Blue in white 18 Golf R 09 Comp Yellow NC 20 Gladiator tow vehicle. Last edited by gatorac; 09-03-2015 at 10:13 PM. Reason: more spelling errors. I fricken suck at typing with a tablet. |
#17 |
Drives: Asphalt FR-S
Serious question
Can someone explain to the newbies why safety is different on a common road vs a race track? I honestly don't know. I have always wondered why auto cross requires helmets. If it is safer why then is it illegal to wear on the regular road? I'm guessing the frequency of the types of crashes but does anyone have an explanation with real stats?
#18 |
Drives: 2016 FR-S
I've seen a rollover that flattened the roof of a Cayman. Car was completely stock. The driver opened the door and crawled out unscathed; just terribly shaken. It rolled four times and then did one end over end flat on its roof! I could not believe he just walked away!
Definitely would not use a HANS of any type with stock belts... My safety device rule is "all stock or all out half cage+HANS+6 point harness". Nothing in between.
| The Following 5 Users Say Thank You to Sleepless For This Useful Post: | CSG Mike (09-04-2015), Jyn (09-18-2015), strat61caster (09-06-2015), TRAKRAVN (09-18-2015), why? (09-04-2015) |
#19 | |
Drives: '22 WRB
Believe me, I hear where you're coming from. I guess I look at it as I've also been doing HPDE's for about a decade now with a well-respected group from this area, and I've never seen a roll over, nor have I seen anyone remotely seriously injured in a frontal or side impact. I've seen plenty of cars bang into stuff, but the worst I've seen was a guy that hit a tree and needed to be cut out of his car, he was back at the track the next day. Just because one has seen or hasn't seen a particular type of accident doesn't mean we should severely sway the chances of killing someone in the rather plausible event of a rollover. To me, the best we can do is educate people on not only the very real dangers of the increased performance of modern cars at HPDEs, but the available safety systems and how they should be used together. A sort of "you're more likely to hit something straight or have a side impact than a rollover according to ___ data, so a HANS, harness bar, and harness will help you there, but __% of the time you will rollover and your chances of snapping your neck go up ___%". Allow people to make their own decisions based on risk. So again, I read ya loud and clear. If that's what you feel comfortable with, by all means go for it. I'd rather personally risk stock safety systems (belt and airbags). I'm not far off of daily driving a truck and caging the car though. Just hard to give up a competitive autocross car for me. |
#20 |
Chin Chief Instructor
Drives: 2015 Ford F150 Aluminium Couch
#21 | |
I see more rollovers than I do contact (strictly speaking HPDE). We have quite a few places where an off gives you a high chance of rolling out here. |
#22 | |
Drives: 2013 SWP BRZ Ltd. / E60 M5
Although I don't know the basis for the information, I do trust the source. Thanks everyone for the valuable information in this thread. I'm at the end of my second year of HPDE with my BRZ (around 35 days) and I'm trying to figure out where I go from here as far as safety. Unfortunately, I don't have a place to park a trailer. So whatever I do has to be safe on the street. That seriously limits my options. After having seen spec miatas and other similarly sized cars roll in youtube videos, I'm not too thrilled about heading out there as I get faster.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
| The Following User Says Thank You to Alan For This Useful Post: | Dave-ROR (09-17-2015) |
#23 | |
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#24 |
Drives: 2016 FR-S
Yes, I've had a HANS in the past and now use the Necksgen. Along with Schroth 6 point harness and a 4 point roll bar from Cantrell Motorsports and Recaro Sporster seats. I've been using this setup for 10 years on various cars to maintain a good balance between street/track safety.
#25 | |
Drives: 2015 FR-S (Halo)
Not attempting to be combative, but I'd also be interested in some data on harness bar collisions and if it matters where and what they are mounted to.
#26 | |
Drives: Nevermorange FRS
The DOT, IIHS, NHTSA have lots of car crash data. The car manufacturers themselves have conducted lots of this as well.
PRO86 | WTCC | STL
| The Following 3 Users Say Thank You to rice_classic For This Useful Post: |
#27 |
Drives: White FRS, 2011 Cayman, 1986 944
Frequency of roll over vs hit something is going to be track specific. Probably not to many rollovers at the glenn
#28 |
The OP brings up SpecE30 or Spec Miata so with that it's worth saying..
More often than not the biggest difference between a race car (like a spec miata) and a street car is the safety gear. Modern street cars are often faster than many race cars. So while the risk of incident may be lower (much lower) in a regular E30 street car on a lapping day, the speed at which the event occurs and magnitude can be every bit equivalent yet the violence which it imparts to the driver will be more severe. I don't know if enough folks give that reality enough respect. But I hear lappers more and more use the word "racing" in describing their activities (in person, online and on often on this very forum). This is unfortunately becoming more common. They're not at a racing event yet in their heads, they are and they are not making the mental distinction between the two. This mentality is dangerous and it is my opinion that it is growing. Most of the time track day fails look like this: But sometimes they look like this: And while this is a "race car" it is wrecking at a speed in which most street cars would but in a very spectacular fashion. just some food for thought.
PRO86 | WTCC | STL
| Confused on safety equipment? | connorlug | Tracking / Autocross / HPDE / Drifting | 10 | 08-16-2014 09:36 AM |
| **Safety Equipment & Track Supplies: Helmet / Gloves / Suits / Tools etc... | Touge Factory | Miscellaneous | 5 | 02-20-2014 02:39 PM |
| Feel safe at the track without safety equipment? | iLuveKetchup | Tracking / Autocross / HPDE / Drifting | 36 | 02-28-2013 05:22 PM |
