Old 09-03-2015, 09:53 PM   #15
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
The HANS needs to be integrated with a roll bar or cage minimum. No way I'm holding my neck in place in the event of a rollover without a cage. I've discussed this several times. There's really not a good happy middle ground on this unfortunately.
trippinbillies40 is offline   Reply With Quote
Old 09-03-2015, 10:12 PM   #16
gatorac
Chin Track Event Manager
Drives: 15 Series Blue
That's great that you have researched the subject enough to make a decision you are comfortable with. If you have any data to share on the number of rollovers at a typical HPDE event vs frontal and side impacts this would be a great place to share it. Rollovers that the factory crash structure was found to be inadequate would be even more useful.
Im afraid I can't help on that as I've never seen a rollover at any event I've ever been too. I never even heard about a rollover at an event with the group I run with in my 12 years with them.
I have seen plenty of cars run into stuff though. I bring that up in the copy I posted. The important part is that we have the information to make our own decisions.
Jim Pomroy Chin Track Days Event Manager.
15 Series Blue in white
18 Golf R
09 Comp Yellow NC
20 Gladiator tow vehicle.
Last edited by gatorac; 09-03-2015 at 10:13 PM. Reason: more spelling errors. I fricken suck at typing with a tablet.
gatorac is offline   Reply With Quote
Old 09-03-2015, 11:00 PM   #17
CB390248
Drives: Asphalt FR-S
Serious question
Can someone explain to the newbies why safety is different on a common road vs a race track? I honestly don't know. I have always wondered why auto cross requires helmets. If it is safer why then is it illegal to wear on the regular road? I'm guessing the frequency of the types of crashes but does anyone have an explanation with real stats?
CB390248 is offline   Reply With Quote
Old 09-03-2015, 11:57 PM   #18
Sleepless
Drives: 2016 FR-S
I've seen a rollover that flattened the roof of a Cayman. Car was completely stock. The driver opened the door and crawled out unscathed; just terribly shaken. It rolled four times and then did one end over end flat on its roof! I could not believe he just walked away!
Definitely would not use a HANS of any type with stock belts...
My safety device rule is "all stock or all out half cage+HANS+6 point harness". Nothing in between.
Sleepless is offline   Reply With Quote
Old 09-04-2015, 12:10 AM   #19
trippinbillies40
Drives: '22 WRB
Important we can make our own decisions indeed, which is why I feel placing any additional proposed restrictions on HPDE's will be incredibly hard to do.
Believe me, I hear where you're coming from. I guess I look at it as I've also been doing HPDE's for about a decade now with a well-respected group from this area, and I've never seen a roll over, nor have I seen anyone remotely seriously injured in a frontal or side impact. I've seen plenty of cars bang into stuff, but the worst I've seen was a guy that hit a tree and needed to be cut out of his car, he was back at the track the next day. Just because one has seen or hasn't seen a particular type of accident doesn't mean we should severely sway the chances of killing someone in the rather plausible event of a rollover.
To me, the best we can do is educate people on not only the very real dangers of the increased performance of modern cars at HPDEs, but the available safety systems and how they should be used together. A sort of "you're more likely to hit something straight or have a side impact than a rollover according to ___ data, so a HANS, harness bar, and harness will help you there, but __% of the time you will rollover and your chances of snapping your neck go up ___%". Allow people to make their own decisions based on risk.
So again, I read ya loud and clear. If that's what you feel comfortable with, by all means go for it. I'd rather personally risk stock safety systems (belt and airbags). I'm not far off of daily driving a truck and caging the car though. Just hard to give up a competitive autocross car for me.
Old 09-04-2015, 01:34 AM   #20
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Pete, I'm curious... have you ever used a H&N restraint?
jmimac351 is offline   Reply With Quote
Old 09-04-2015, 02:59 AM   #21
CSG Mike
CSG Mike's Avatar
Another venue and audience thing I suppose...
I see more rollovers than I do contact (strictly speaking HPDE). We have quite a few places where an off gives you a high chance of rolling out here.
CSG Mike is online now   Reply With Quote
Old 09-04-2015, 06:32 AM   #22
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Originally Posted by smbstyle View Post
Also for head and neck restraints, I've picked up the Simpson Hybrid Sport since I routinely hop into street cars on the track, and it is a bit better of a system for OEM belts than the HANS (I've always got my HANS though when running a harness).
For those of you with HANS posts on your helmets, that do the same (street car to track car routinely at the same events), the Hybrid posts are the same as the HANS posts, so you can switch back and forth without changing the helmet posts; just make sure you order it with "Post clip tethers and post anchors".
Recently, one of the groups I'm a part of made an announcement clarifying the use of the Hybrid products with 3-point belts. Apparently only the Simpson Hybrid is intended to be used with three point belts because it has the longer solid back piece. The Pro and Sport both lack the longer back piece and should not be used with 3-point belts.
Although I don't know the basis for the information, I do trust the source.
Thanks everyone for the valuable information in this thread. I'm at the end of my second year of HPDE with my BRZ (around 35 days) and I'm trying to figure out where I go from here as far as safety. Unfortunately, I don't have a place to park a trailer. So whatever I do has to be safe on the street. That seriously limits my options. After having seen spec miatas and other similarly sized cars roll in youtube videos, I'm not too thrilled about heading out there as I get faster.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 09-04-2015, 08:33 AM   #23
smbstyle
smbstyle's Avatar
Interesting.... I'll contact Simpson to get to the bottom of this!
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 09-04-2015, 11:08 AM   #24
Sleepless
Drives: 2016 FR-S
Yes, I've had a HANS in the past and now use the Necksgen. Along with Schroth 6 point harness and a 4 point roll bar from Cantrell Motorsports and Recaro Sporster seats. I've been using this setup for 10 years on various cars to maintain a good balance between street/track safety.
Old 09-04-2015, 12:25 PM   #25
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
Have you ever seen what happens when a car gets t-boned on the street, with a harness bar? That bar's gonna bend and it's gotta go somewhere. Sometimes, it goes places you don't want it to go.
Race seat - deletes side airbag. If you get into an accident, good luck getting insurance to cover your medical bills, after they find out you deleted a core safety component of the car.
Roll bar - Depends on the person, but still a risk
Harness - Absolutely , 100%, illegal on the streets (we're not debating the merits in terms of safety, but legality). Also, see above regarding insurance and an accident
Just how you're trying to prepare HPDE drivers for a worst case scenario at the track, I'm comparing that prepped car against the worst case scenario on the street.
I absolutely agree that safety equipment is important on the track, but track/racing safety equipment does NOT belong in a street car.
Schroth 4-points and I believe Takata's equivalents are DOT approved for the street, as long as they have ASM.
Not attempting to be combative, but I'd also be interested in some data on harness bar collisions and if it matters where and what they are mounted to.
fatalelement is offline   Reply With Quote
Old 09-04-2015, 01:45 PM   #26
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Speed. That's the difference.
The DOT, IIHS, NHTSA have lots of car crash data. The car manufacturers themselves have conducted lots of this as well.
PRO86 | STL | LuckyDog
Old 09-04-2015, 01:57 PM   #27
johhnc479
Drives: White FRS, 2011 Cayman, 1986 944
Frequency of roll over vs hit something is going to be track specific. Probably not to many rollovers at the glenn
johhnc479 is offline   Reply With Quote
Old 09-04-2015, 02:31 PM   #28
rice_classic
The OP brings up SpecE30 or Spec Miata so with that it's worth saying..
More often than not the biggest difference between a race car (like a spec miata) and a street car is the safety gear. Modern street cars are often faster than many race cars. So while the risk of incident may be lower (much lower) in a regular E30 street car on a lapping day, the speed at which the event occurs and magnitude can be every bit equivalent yet the violence which it imparts to the driver will be more severe. I don't know if enough folks give that reality enough respect.
But I hear lappers more and more use the word "racing" in describing their activities (in person, online and on often on this very forum). This is unfortunately becoming more common. They're not at a racing event yet in their heads, they are and they are not making the mental distinction between the two. This mentality is dangerous and it is my opinion that it is growing.
Most of the time track day fails look like this:
But sometimes they look like this:
And while this is a "race car" it is wrecking at a speed in which most street cars would but in a very spectacular fashion.
just some food for thought.
Confused on safety equipment? connorlug Tracking / Autocross / HPDE / Drifting 10 08-16-2014 09:36 AM
**Safety Equipment & Track Supplies: Helmet / Gloves / Suits / Tools etc... Touge Factory Miscellaneous 5 02-20-2014 02:39 PM
Feel safe at the track without safety equipment? iLuveKetchup Tracking / Autocross / HPDE / Drifting 36 02-28-2013 05:22 PM
