Old 08-15-2014, 01:21 PM   #1
connorlug
Drives: #1553 10 Series FRS
Confused on safety equipment?
Hey guys, I need some help on this I'm kinda lost. A little background I've been racing in auto-x for a couple years now and I feel that I'm more prepared to finally get on the track. I have my first session scheduled for oct 17th at NJMP Lightning, I'm just signed up for progressively paced laps.
I'm shopping around for a harness and harness bar, but I have no idea what I'm looking for in a harness, where I can mount it, and what harness' are recommended. I'm going to be purchasing the cipher auto harness bar, trying to keep things somewhat affordable.
Any of you track gurus got some really good advice for me? Anything helps. Thanks guys.
connorlug is offline   Reply With Quote
Old 08-15-2014, 02:04 PM   #2
wparsons
wparsons's Avatar
Don't buy a 5 or 6 point belt unless you have a roll cage (not a harness bar). The only multi point harnesses I would run without a cage have a breakaway section on the inner shoulder strap so that if you roll the strap will give way before the roof breaks your neck.
That said, you don't need a harness bar and multi point harnesses for your first track sessions.
flickr
The Following 5 Users Say Thank You to wparsons For This Useful Post:
Dave-ROR (08-15-2014), phastafrican (08-15-2014), Racecomp Engineering (08-15-2014), rice_classic (08-15-2014), unsurety (08-16-2014)
Old 08-15-2014, 02:09 PM   #3
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
If you want to feel tightened down in the seat, one of these should be sufficient:
http://www.walmart.com/ip/21391103?w...139312&veh=sem
bimmer635csi is offline   Reply With Quote
Old 08-15-2014, 02:10 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you should first and foremost ask the organizers of your particular event which rules they follow. They should tell you the type of standards they expect from their belts, from which you could figure out the pool from which to buy.
having said that, your car's 3-point is fine for a first time is more than adequate..
hell, I'd just stick a CG-Lock in and call it a day.
Old 08-15-2014, 02:11 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
What wparsons said.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
wparsons (08-15-2014)
Old 08-15-2014, 02:32 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
what they all said.
All jokes aside, I have ran 9 events with stock seats and stock belts. Unless you are a big dude that won't fit in the seat, you're perfectly fine.
And if you bounce around too much... either your suspension is set up wrong or you have horrible track surfaces.
-alex
Old 08-15-2014, 03:32 PM   #7
connorlug
thank you very very much fellas, i've had some fast cars but never had to put in a harness or harness bars or anything. Looks like I'll just get the clip for my stock belt for now. Thanks!
Old 08-15-2014, 04:42 PM   #8
I recommend you just go to the track initially with 100% stock safety equipment.
To properly use a harness, you need a cage, and a 5 or 6 point harness, and an appropriate bucket seat. You'll also need a head and heck restraint, and probably an airbag removal.
Unless you have *all* of the safety equipment together, you're actually hurting the safety of the car and putting yourself at risk of worse injury.
Sleepless (08-16-2014), wparsons (08-15-2014)
Old 08-16-2014, 12:18 AM   #9
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Everything @CSG Mike recommended is the way(s) to go : all stock or dive deep into roll-bar, seats and 5/6 point harness, and HANS (or equiv.), etc.
Everything in between is almost always less safe.
Sleepless is offline   Reply With Quote
Old 08-16-2014, 08:57 AM   #10
dp1
driving smoother faster
Drives: Sold
For HPDE I use Simpson R3 with sliding tether attached to the helmet, OEM seat belts and seats.
dp1 is offline   Reply With Quote
Old 08-16-2014, 09:36 AM   #11
ddeflyer
It should also be added that you have to have a correctly fitted seat to use a 5 or 6 point harness along with the mount for the harness being at the correct height for that seat. If the harness mount is too low it could crush your back in a wreck and I think too high also has unpleasant results. Similarly, just threading the harness through headrest mounts on a stock seat is quite likely to tear apart the seat and leave some part of your body taking excessive load (ie. the belt could crush your internal organs as all of your mass being decelerated is focused on one part of your body). Safety is hard and you really need to build a proper system; half ass'ing it puts you in extreme risk during a bad accident.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
WTT: Audio Equipment for Stock Wheels?! mastamoon NY / NJ / CT / PA 3 05-02-2014 03:07 PM
**Safety Equipment & Track Supplies: Helmet / Gloves / Suits / Tools etc... Touge Factory Miscellaneous 5 02-20-2014 02:39 PM
Feel safe at the track without safety equipment? iLuveKetchup Tracking / Autocross / HPDE / Drifting 36 02-28-2013 05:22 PM
Toyota 86 LUCK equipment Harinjo Scion FR-S / Toyota 86 GT86 General Forum 31 02-28-2012 02:18 PM
Lets See What Your Models with Equipment & Pricing for the FR-S Would Look Like?! Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 33 05-11-2011 02:44 PM
