Old 09-03-2015, 10:39 PM   #2843
impossible
Originally Posted by impossible View Post
Hi there,
Looking forward to buy some wheels and tires and want to know will there any effect if i upgrade coilover in the future and whats the pro and con on the offset.
1. 17x8 et35 225/45/17
2. 17x8 et45 225/45/17
in this setup is it just representing 1. is more flush and 2 is more tuck in? why do people prefer 35 over 45.
anyone?
impossible is offline   Reply With Quote
Old 09-03-2015, 11:15 PM   #2844
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by BCTV93 View Post
I know someone posted about XXRs with a +20,
But I'm wondering if I get 18x9 +20 wheels on an Eibach Pro Kit drop, will there be any rub?
I don't know what tires to get yet, but I won't have LCAs or anything, not for awhile.. There would be natural camber right?
Too much poke. Tire will rub on the fender.
Try to get something closer to a +35 or +40.
Slick is offline   Reply With Quote
Old 09-03-2015, 11:20 PM   #2845
Slick
Slick's Avatar
Hi there,
Yes, +45 is more inboard while a +35 pushes it out 10mm.
+35 works well in most instances, whether stock, springs or coilovers.
+45 will be tighter to the spring perch but will work on stock or coilover applications.
I recommend the +35 setup.
Old 09-03-2015, 11:22 PM   #2846
impossible
But isn't it +35 front will be a bit poke on the front?
Old 09-04-2015, 12:02 AM   #2847
Slick
Slick's Avatar
Nope, not with a 17x8 wheel, even stock.
Old 09-04-2015, 12:03 AM   #2848
impossible
Thanks I will get the +35 offset then but just wondering is the rpf1 got a concave face even is 35+?
Old 09-04-2015, 12:06 AM   #2849
Slick
Slick's Avatar
See here:
http://www.ft86club.com/forums/showthread.php?t=35426
Old 09-04-2015, 12:07 AM   #2850
impossible
Thanks. But wot abt the face? As it is really hard to see from the photo for rpf1
Old 09-04-2015, 06:51 AM   #2851
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
I have some 17 x 7.5 +43 Rays CE28n. Im considering putting track rubber on and not using any spacers........but Im also considering setting them up as my daily wheels with some spacer.
The car is dropped about 1.5 to 2 inches on coil overs.
Running a 20mm front and a 25mm rear spacer will give me effective offset of +23 front and +18 rear.
Tyres will either be the stock Michelins 215/45 or I will get some 225/45.
So will 17x7.5+23 F and 17x7.5+18 R fit?
Thanks
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 09-11-2015, 09:34 AM   #2852
DerHauptDigga
DerHauptDigga's Avatar
Drives: 2016 FRS
So I am looking at running one of these options:
RPF1 - 18x9.5 +38 (square setup)
NT03 - (same as above)
Work Meister - 18x9et35 and 18x9.5et35 5x100 (currently in FS thread)
I'll be running TRD lowering springs on my suspension setup (that is the only modification).
My question is, I have seen these setups on other cars, but they are all lowered, control arms, camber, etc. (which I would do eventually). But running on just the lowering springs, would I poke a lot? Would I need spacers? Basically, would this work for me without the coilovers, and camber, and all that, or would it just poke a lot, or look god awful?
DerHauptDigga is offline   Reply With Quote
Old 09-13-2015, 10:02 PM   #2853
Sazexa
Drives: '15 Firestorm FR-S
Hey guys, looking at getting tires and rims in the Spring. I've tried to use the calculators to see what will work/work well. Here the important information:
Enkei Raijin - 18" x 8.5"
Pirelli P-Zero System - 235/35 18R
+35mm Off-set
I also plan on grabbing a set of RS-R Black-i coil (~1" lowered) overs. Should this all fit without issue?
Sazexa is offline   Reply With Quote
Old 09-14-2015, 03:56 AM   #2854
gMit
Drives: Pearl BRZ
Hey all.
Looking into getting some new wheels and tyres. Will probably have to go coil overs.
I don't know too much about fitment so would love feedback.
Thinking of the following:
XXR 530 - 18" x 8.75"
Bridgestone potenza RE003's - 235/40 18R
+33mm off-set
Looking at picking up some Shockworks coil overs ( Aussie brand).
How bad would the poke be?
Cheers
gMit is offline   Reply With Quote
Old 09-16-2015, 07:13 PM   #2855
workthatupdoo
Drives: 2015 Halo FR-S
Hey guys,
Hoping to get confirmation this setup will fit:
XXR 527 18x8.75 5-100/5-114.3 [+35mm]
245/40 18R
Not sure if it's relevant, but my car is also lowered ~1.4 inches.
I also wanted to know the difference between 245/40 and 255/40 tires. I'm not sure how width will affect the tires being mounted. According to the calculator both look like they fit but maybe someone can clarify for me since I'd rather have 245/40 but I don't want there to be any issues getting it mounted.
Thanks!
workthatupdoo is offline   Reply With Quote
Old 09-21-2015, 03:59 PM   #2856
Jonde875
Drives: GT86
Hello!
Im planning to put 18x8.5 +42 Gram Lights 57xtremes Face-2 wheels if I find where to buy them.
Tyres I planning 225/40 all around and some drop to get that gap smaller to the fender!
Do you know is there gonna be any rubbing or other issues?
Jonde875 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
