#3 |
Site Moderator
Drives: ichi 86 Project
Please follow the member classified rules or I'll delete the thread
thanks ichi |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | whataboutbob (08-25-2015) |
#6 |
I got sucked into boost..
Drives: Whiteout FR-S & Supercharged BRZ
Oil Cooler
Hi, I'm interested in this unit. I need something to warm my oil up a bit quicker in the mornings and also keep it cooler for occasional track days.
Did you get readings on your oil temps when using it compared to stock? How hard was it to install? Thanks! Marc
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's |
#7 |
Drives: 2012 Toyota 86
Its pretty easy to install, hardest part being the lower radiator hose as you have to remove the aluminum tray under the engine. after that its pretty easy. drain your coolant, swap the hoses in, and bolt the cooler on, don't even need to drain your oil if you don't want. theres some pretty good DIY guides out there I can link to if you need. I don't have any temps for without a cooler(ive read some peoples went as high as 280), but with this cooler on tracks i saw 230-240, occaisonly it hit 250 on longer straits in the summer. It definitely helps warming the oil up, it seems to take forever now for me.
#8 | |
Drives: 2005 Toyota Camry
Install is easy if you have replacement radiator hoses available, however the lower hose is the hardest hose to remove. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | troek (09-03-2015) |
#9 |
Thanks for the info! Sounds like it will sufficient.
| Cusco Oil Cooler | akuhei | Forced Induction | 126 | 08-19-2016 10:05 AM |
| FS Cusco oil cooler (water cooled) | keen as | Australia Classifieds | 10 | 08-31-2014 01:25 AM |
| DIY Cusco Oil Cooler | lazyluka | DIY (Do-It-Yourself) Guides | 11 | 02-27-2014 02:15 AM |
| Cusco oil cooler vs Perrin input please | ft86me | Engine, Exhaust, Transmission | 0 | 10-08-2013 05:05 PM |
| New Cusco oil cooler | ahaghshenas | Engine, Exhaust, Transmission | 11 | 04-02-2013 10:48 PM |
