Old 09-02-2015, 01:53 AM   #1
86 driver
86 driver's Avatar
Drives: 2013 FRS
Built engine question
Are forged pistons necessary or can I just use rods? I want to keep the same ratio as stock anyways.
There hasn't been any reported cases of busted pistons to my knowledge. Only busted stock rods.
FYI my goal is to be around around 450 hp when it is built. Valve springs will be installed as well. What are your opinions on stock vs forged pistons?
86 driver is offline   Reply With Quote
Old 09-02-2015, 02:24 AM   #2
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Replacing one without replacing the other seems a bit of a waste.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post:
celek (09-02-2015), Freeman (09-02-2015), humfrz (09-02-2015)
Old 09-02-2015, 05:25 AM   #3
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
Better to just make sure everything is on the same page. Despite the main weakness being fixed, it opens up other problems for parts not up to that level.
megamarines is offline   Reply With Quote
Old 09-02-2015, 07:01 AM   #4
350matt
Drives: toyota mr2/ Toyota GT86
I think the stock item is pretty good but if you're aiming for 450Bhp then I think you'll have an easier time getting there with a slightly lower ratio and more boost I mean 10.5:1 is still a reasonable level of ratio for a boosted engine
350matt is offline   Reply With Quote
Old 09-02-2015, 09:36 AM   #5
celek
Resident Gear Head
celek's Avatar
With the stock compression you are fighting Knock to make power. Requiring Higher Octane to compensate. Spend a bit more for Pistons at the same time. I can tell you rods and pistons in our block with Valves springs can yield OVER 700 HP.
celek is offline   Reply With Quote
Old 09-02-2015, 11:04 AM   #6
smudge
Drives: Supercharged GT86
I still envy you Yanks with your e85 fuel wish we had that in the UK
smudge is offline   Reply With Quote
The Following User Says Thank You to smudge For This Useful Post:
aagun (09-10-2015)
Old 09-02-2015, 11:56 AM   #7
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
'Murca!
MS, CSCS, TSAC-F, CPT
Old 09-02-2015, 12:25 PM   #8
smudge
Originally Posted by weederr33 View Post
'Murca!
Can I have some of that sweet, sweet freedom sent over via bald eagle please?
weederr33 (09-02-2015)
Old 09-03-2015, 12:54 AM   #9
86 driver
86 driver's Avatar
Drives: 2013 FRS
That makes sense. I'm running a flex fuel kit, so it will be on e85 for that kind of power. My tuner was saying that lowered compression wasn't necessary.
I will definitely look into forged pistons now. Thanks for the heads up.
Old 09-03-2015, 10:03 AM   #10
celek
Resident Gear Head
celek's Avatar
Does your builder realize its a factory 12.5:1 compression motor?
Old 09-03-2015, 11:11 AM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Lots of big power cars on stock compression levels. A good tuner can handle it.
Old 09-10-2015, 07:43 PM   #12
86 driver
86 driver's Avatar
Drives: 2013 FRS
Yes. I thought the same thing, but he said that's the way he prefers it.
Old 09-10-2015, 11:47 PM   #13
aagun
Drives: 86
UAE TOO PLZ
aagun is offline   Reply With Quote
Old 09-11-2015, 12:16 AM   #14
stevo585
Drives: White 2014 BRZ
Helps keep the lag down. And if your running e85 full time even more reason to keep stock comp. ratio.
stevo585 is offline   Reply With Quote
Boost pressure for built engine ChrisD Forced Induction 75 01-06-2016 02:24 PM
Built Engine. Sprintex 335. GTX30r. other bolt ons for sale. alexisfire02 Engine, Exhaust, Bolt-Ons 9 02-03-2015 01:42 PM
WV: 04 STI Low miles Built 400+ AWHP 33K on chassis 1500 on engine $25K dakjones Cars for Sale/Trade 6 09-03-2014 09:05 PM
Anyone has Stroked and Built FA Engine yet ? Whitigir Engine, Exhaust, Transmission 11 03-14-2014 06:31 PM
What is the best turbo for a fully built engine scion frs SUB-ZERO Forced Induction 41 09-18-2013 07:41 PM
