Old 10-20-2014, 10:52 AM   #29
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Originally Posted by viscositosis.rex View Post
Group III+ ?
Group IV ?
Olive oil would be Group V.
Group V – All others not included above such as naphthenics, PAG, esters. ...
These are primarily triglyceride esters derived from plants and animals. For lubricant base oil use the vegetable derived materials are preferred. Common ones include high oleic canola oil, castor oil, palm oil, sunflower seed oil and rapeseed oil from vegetable, and Tall oil from tree sources. Many vegetable oils are often hydrolyzed to yield the acids which are subsequently combined selectively to form specialist synthetic esters.
http://en.wikipedia.org/wiki/Lubricant#Base_oil_groups
Miller's Nanodrive, being triple ester based, is Group V as well so I guess we're not actually too far
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
Sportsguy83 (09-22-2015)
Old 10-20-2014, 04:07 PM   #30
viscositosis.rex
Drives: Currently 2018 Taco
-Dennis
Trudat. Although you and I know how much MolaKule loves those veggie esters, like RLI corn oil. LOL.
viscositosis.rex is offline   Reply With Quote
Old 12-16-2014, 02:45 PM   #31
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Bg8780 View Post
I've been pretty happy with he fluids so far. 190whp 155wtq with JDL UEL uncatted and catted front pipe. I'm not saying Miller's oil gave me those results but I think it helped.
Originally Posted by GotBRZ1691 View Post
+1
Originally Posted by Reaper View Post
@ATL BRZ looking forward to your uoa.
Originally Posted by Xuningshen View Post
Likewise Reaper. ATL Please post your UOA in this thread once you get it done. but If you've been using it like that. I'd assume its okay for my usage. Thanks
Here is mine. 3000 miles, 10 track days, exclusively E85.
Just spoke with Harry at Performance Racing Oils who said to ignore the red flag on the oxidation number since Nanodrive uses ester base stocks. The baseline shows high oxidation numbers as well but the lab is reporting it as a false red flag.
He said it looks great considering the amount of track time it has on it.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Reaper (12-16-2014), Xuningshen (12-16-2014)
Old 12-16-2014, 03:48 PM   #32
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
That's very similar to the uoa I posted at 5,000 miles @ 460whp e85 on my oil. Including the oxidation levels.
Though I have substantialy more zinc and less dirt.(silicon) viscosity is the same too. Interesting.
Old 12-17-2014, 09:25 AM   #33
viscositosis.rex
Thanks again for these enlightening reports. Solid. Miller's, Motul, Red Line, Royal Purple. Anybody trying the German ester based oils? Pentosin. Liquimoly.
Not that you track/E85 dudes would be inclined to do so, but I am interested in how thin someone could get away with. These ester based oils are so shear stable. Maybe RL 0W20/5W20 or RP 5W20 HPS.
It has been suggested that viscosity can be masked by fuel dilution+oxidation.
Old 12-17-2014, 11:46 AM   #34
Reaper
Reaper's Avatar
Drives: violent
I'm on 5 quarts 5w20, 3 quarts 10w30 amsoil dominator for the winter now just for the ease of cold start cranking if it gets that cold. I also pulled my oil cooler out.
The Following User Says Thank You to Reaper For This Useful Post:
DriftinFRS (10-03-2015)
Old 02-03-2015, 06:57 PM   #35
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Updated with 10k analysis
Bg8780 is offline   Reply With Quote
Old 09-02-2015, 05:16 AM   #36
killy
Drives: BRZ Limited
Do they recommend keeping this oil on for 10K miles?
Or do they advice to change it more often?
killy is offline   Reply With Quote
Old 09-02-2015, 08:38 AM   #37
OkieSnuffBox
Drives: '23 BRZ Limited
@ATL BRZ any idea why Miller recommends 3k oil changes on E85, yet you have UOAs showing 3k track miles and 7k street miles on E85 showing good results?
I want to run Millers, but not at 3k oil change intervals, it's just too pricey at that point.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
killy (09-04-2015)
Old 09-02-2015, 10:23 AM   #38
bluesubie
The "uoa wear metals" are low, but I wouldn't call these results that good because of the fuel.
The severe oxidation flagged by Polaris could partially be because this is a ester based oil and high oxidation readings are a trait of ester based oils and not necessarily "true" oxidation (need a VOA to tell), but the fuel dilution is far from good at 6.1%, IMO. The fuel may be causing oxidation as well.
Check for source of FUEL LEAK. Fuel is at a SIGNIFICANT LEVEL. Fuel dilution may be caused by component faults related to injectors, ignition/timing or excessive blow-by. Additional causes include heavy throttle application, engine lugging, frequent short trips, and excessive idling. Infrared results indicate OXIDATION is SEVERELY HIGH; FUEL DILUTION has caused viscosity to decrease moderately; FUEL DILUTION reduces the viscosity of the lubricant which decreases FILM STRENGTH and LUBRICITY and may lead to increased wear.
Old 09-04-2015, 11:31 AM   #39
killy
Drives: BRZ Limited
It has proved to be very durable. I'm strongly considering pushing this to 10k intervals. I may do another analysis around 8500 MI and see how it's looking.
Sent from my XT1060 using Tapatalk
Did you managed to keep this oil running for a longer mileage?
Do you know what is the recommended oil change interval?
I was eager to try this but i want to keep it for at least 10.000 km, at least.
Old 09-17-2015, 04:34 PM   #40
Bg8780
Bg8780's Avatar
I actually did. I went to 10k miles. The UOA came back as fine. It was DEFINITELY time for an oil change but there was no wear or damage. I now change at 7500mi. Based on all the UOA's 7500mi seems to be a good time. Keep in mind I am not tracking the car but I go to redline quite a bit and drive quite spiritedly.
Old 09-18-2015, 11:23 AM   #41
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Where can i buy this??
jaorocks1 is offline   Reply With Quote
Old 09-18-2015, 12:23 PM   #42
ATL BRZ
ATL BRZ's Avatar
www.performanceracingoils.com
Oil Analysis - 1st oil change R L Newb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 375 11-19-2021 09:24 AM
P1 at Miller Motor Cars Tgionet NY / NJ / CT / PA 9 03-01-2014 12:48 PM
Used Oil Analysis Results Captain Snooze Engine, Exhaust, Transmission 2 11-21-2013 12:59 PM
R Miller Auto Lipster kit nixeighty6 Cosmetic Modification (Interior/Exterior/Lighting) 12 03-08-2013 02:58 PM
