Old 08-31-2015, 10:35 PM   #29
ChrisD
ChrisD's Avatar
Drives: GT86
Ordered some new bits recently
Firstly the StopTech big brake kit for the front (328mm), which has already turned up as you can see below. Should be fitting them later this week.
Secondly, forged engine internals carrillo con rods and carrillo 10:1 pistons, stronger valve springs, ARP head bolts, cosworth head gaskets, better spark plugs, and the Reimax oil pump gear.
Oh and a Mishimoto radiator and baffled oil sump. From my searches it seems like there's some debate on this forum as to whether or not either of those things are necessary, but I'd rather be on the safe side.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
The Following 2 Users Say Thank You to ChrisD For This Useful Post:
CxG (06-26-2016), Lonewolf (08-31-2015)
Old 08-31-2015, 11:14 PM   #30
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Love the build thread keep it going!!
Just a quick question on the whiteline rear subframe bush inserts.
In my brz, in first or 2nd gear in almost any rpm range, if I romp on the throttle i get 2-3 solid stutters/jerks. Its been driving me absolutely crazy as i've never felt anything like that in any car and its just ridiculous. Is it Subaru and Toyota cutting cost corners and just not refining that aspect of the drive train or whats the deal. But anyways, just wondering if those inserts helped the jerkiness in you car.
Cheers!
olsonpg is offline   Reply With Quote
The Following User Says Thank You to olsonpg For This Useful Post:
ChrisD (09-01-2015)
Old 09-01-2015, 05:52 PM   #31
ChrisD
ChrisD's Avatar
Drives: GT86
Cheers!
Yeah I hated that as well and the rear subframe bushing inserts did make a noticeable difference to that. I wouldn't say it gets rid of it 100% but it definitely makes it better (and that's coming from someone who doesn't normally notice small changes that other people say make a "noticeable" difference). There's a guide here on how to install them: http://www.ft86club.com/forums/showthread.php?t=20920
CxG (06-26-2016), olsonpg (09-01-2015)
Old 09-01-2015, 06:56 PM   #32
olsonpg
olsonpg's Avatar
Thank you so much my good sir. I'll be ordering thes asap!
Old 09-02-2015, 04:00 AM   #33
EdiVip
Drives: Mario
How many HP & Nm on 0,8 Bar? Do U use PB98?
EdiVip is offline   Reply With Quote
Old 09-03-2015, 07:36 PM   #34
ChrisD
ChrisD's Avatar
Drives: GT86
Never had it on a dyno so no idea what BHP and Nm its making, but Fensport said it will probably be around 300 at the moment. To be honest I'm not really interested in the peak power figures, just want it to feel good and drive well.
The Following User Says Thank You to ChrisD For This Useful Post:
CxG (06-26-2016)
Old 09-03-2015, 07:39 PM   #35
ChrisD
ChrisD's Avatar
Drives: GT86
So this may have slightly slowed down my progress with the car... did a track day at Cadwell and smashed it in to a barrier. Will strip the broken bodywork off it tomorrow and see how serious the damage is.
Old 09-03-2015, 08:05 PM   #36
Lee
Drives: GT86
Ouch - where did you go off? One of my favourite tracks
Lee is offline   Reply With Quote
Old 09-03-2015, 08:32 PM   #37
ChrisD
ChrisD's Avatar
Drives: GT86
At coppice, the first corner after the start finish straight. Was a weird crash - I'd been driving a different car round the same track earlier that day, and the gear shift on the other car isn't as short as on the 86, so I went to downshift just before the corner and instead of going into 4th I accidentally put it into 2nd.... lol 2nd gear at 90 mph obviously just locked the rear wheels as soon as I let the clutch out. Video here for anyone who wants to laugh at my stupidity
[ame="https://www.youtube.com/watch?v=WJPxDQdAi2k"]GT86 Cadwell Crash - YouTube[/ame]
Old 09-04-2015, 09:00 AM   #38
Lee
Drives: GT86
You took it well
What camera mount is that? gopro compatible?
The Following User Says Thank You to Lee For This Useful Post:
ChrisD (09-11-2015)
Old 09-11-2015, 11:23 AM   #39
ChrisD
ChrisD's Avatar
Drives: GT86
You took it well
Its a universal head rest mount that has a tripod thread on it, so I just use the gopro tripod mount with it.
Old 09-11-2015, 11:30 AM   #40
ChrisD
ChrisD's Avatar
Drives: GT86
So I'm still repairing the car (pics below) but look what turned up today
Carrillo rods and pistons (10:1 CR) and a few other little bits
They were ordered before the crash, but as long as the engine is ok I'll go ahead and get them installed once everything else is repaired. Oh and the Reimax oil pump gear and Mishimoto rad also arrived the other day.
Anyway, here's some photos of the car now that I've stripped some of the broken bits off it
CxG (06-26-2016)
Old 11-18-2015, 09:29 AM   #41
ChrisD
ChrisD's Avatar
Drives: GT86
Forgot to update this thread again.
I finished repairing all the crash damage a few weeks ago, got the replacement panels wrapped etc and she's now pretty much as good as new
Went for a slightly different wrap on the front, with the gloss black part along the bottom centre section below the number plate. Also replaced the fog lights with the APR carbon fibre cooling ducts (which were a nightmare to get to fit even half decent).
The engine seems to be fine despite the over revving during the crash - I've done about 300 miles of hard driving since with no problems. It passed an MOT a few days ago as well, although I guess that doesn't mean much but at least it proves its not a wreck lol
Finally got round to installing the new StopTech big brake kit last week as well:
Word of warning to anyone considering these - the stock 17 inch wheels don't fit over the callipers. My 17 inch OZ wheels fit fine due to the lower offset though. Haven't had chance to drive it much yet since fitting the new brakes but first impressions are that they feel a lot better than the DBA discs and hawk pads I had before (with stock callipers).
Anyway, in a couple of weeks I'll be taking the engine out and getting the new pistons/rods/valve springs installed looking forward to it
CxG (06-26-2016), djdnz (11-20-2015)
Old 11-18-2015, 11:18 AM   #42
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by Nigelr32 View Post
Another UK guy on here I see. This really is a great forum, probably due to the fact the FRS is so affordable in the USA compared to our rip off Britain prices..meaning they're more popular among tuners.
Which region of the UK are you in Chris?
Don't complain... You could live in (South Africa)... We have to import pretty much everything, and our currency isn't strong!
I like driving!
86 South Africa is offline   Reply With Quote
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Forced Induction 234 09-24-2015 04:45 PM
For sale: Avo Stage 1 turbo kit h4nh Engine, Exhaust, Bolt-Ons 4 09-26-2014 02:36 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
P&L Motorsports BRZ / FR-S Stage 1 Turbo Kit P&L Motorsports Engine, Exhaust, Bolt-Ons 56 09-22-2012 03:28 PM
