#561 | |
The disassembly can be rough especially if it isn't organized... You need to ask them if it isn't under warranty and you want to take the engine to a builder how will it be organized... My builder would have a fit if i gave him a box full of bolts lol. If you weren't doing anything you should be doing I wouldn't be horribly afraid. I don't know what mods you had and what not. What part of the country are you in?
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#562 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
The dealership where the car was towed after failure says they put four quarts of oil in it. The oil was checked less than 3 days before failure (I'm like 99% sure it was checked the day before). There was no oil light at the time of failure (or ever) and the motor did not get hot when it blew. As for the car being disassembled, they have confirmed that it will just be torn apart. There will be no grand organization, or any attempts to have it put back together. I've been jerked around for 3 weeks by SoA and even lied to (they told me an engineer and regional tech inspected the car personally when no such inspection has taken place as confirmed by the service manager). They also just disassembled an STi at the dealership where the car was towed only for SoA to deny warranty and they left the car in parts with storage fees accruing by the day. I didn't realize the cams were that much, certainly not worth the maybe 20WHP gain (and that is ambitious). |
#563 | |
As for the oil bit... So they checked the oil them selves and saw it was fine and 3 days later it was 4 quarts low? I would make sure thats documented. Who did the last oil change? They will obviously try to throw that one at you... =/
#564 | |
#565 |
This sounds like a case where you may want to discuss your options with a lawyer knowledgeable about the subject. Just hearing you have hired one may change the way you are treated.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
#566 |
Resident Gear Head
My block is at Accelerated at the moment, Don there pays attention to detail
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following User Says Thank You to celek For This Useful Post: | FRS Justin (09-02-2015) |
#567 | |
Resident Gear Head
GCS told me they are looking into them around the same price range. There are 4 cams so honestly not a bad price.
#568 | |
Valve springs can be stupid cheap if anyone is planning on FI there is little reason to not pickup some.
#569 | |
Resident Gear Head
#570 |
Drives: GT86
I've just ordered the Reimax gear and will be getting it installed in a few weeks when I get my rods and pistons installed. Not sure I'll really be able to tell you how much it helps though, as I don't currently have any problems with the stock oil pump - just trying to be proactive and get the Reimax one before the stock one becomes an issue. In the grand scheme of things its not that expensive so seems like its worth a try as a few people seem to say it will help a little, even though it won't be a complete solution to the problem. Hopefully I won't ever be getting to that limit though.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits |
| The Following User Says Thank You to ChrisD For This Useful Post: | celek (09-01-2015) |
#571 | |
Resident Gear Head
| The Following 2 Users Say Thank You to celek For This Useful Post: | chaoskaze (09-02-2015), FRS Justin (09-02-2015) |
#572 |
I'm where you are... You know how quickly this shit adds up to an excessively expensive build. I planned on tossing this in my other block and hopefully someone gets some testing done before then but somehow I feel like I'll end up just having to buy one lol.
| The Following User Says Thank You to nelsmar For This Useful Post: | celek (09-03-2015) |
#573 | |
#574 |
Drives: GT 86
I posted this in another thread and relates to a possible cause for oil starvation.
Apparently the below motor had only just a bit over 4000 km on it and he believes it would have died not so far down the road. Would be good to see how much crap is in the motor Luckrider. ...................................... A guy I know builds lots of Subaru ej engines and he is in the process of doing a fa motor atm and he has told me that the amount of silicone inside the motor is just unbelievable. The amount of bits on the oil pickup strainer was huge and he found the oil galleries to the VCT has strainers built into the block and these were almost totally blocked with bits of silicone . Also a lot of bolts / screws weren't very tight at all and even some of the fixings retaining the oil pump weren't tight and he said you could see where the pump was starting to float/rub on the housing. Oil starvation could easily become an issue with all the above. Maybe some of these engine failures are as a result of how these engines are assembled like the swagging on the rocker arms in the earlier motors . |
| FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 02:31 AM |
| FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 05:19 AM |
| Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 12:33 PM |
| FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-17-2013 11:24 PM |
