View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 08-30-2015, 07:00 PM   #491
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by nelsmar View Post
I try to tell people this all the time... But people get tunnel vision from what they read on the internet because people are pushing the absolute max and posting dynos. *sigh*.
I feel you. With such high compression there is no room for bare minimum.
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
Astroboy (08-30-2015)
Old 08-31-2015, 03:09 PM   #492
AppleSauce
Drives: FR-S black. Buell XB12s 25th anniv.
So what can a stock engine with at transmission and full exhaust handle safely assuming the tune was done right?
He who shall be last shall be sideways and smiling
AppleSauce is offline   Reply With Quote
The Following User Says Thank You to AppleSauce For This Useful Post:
Chad86 (08-31-2015)
Old 08-31-2015, 03:28 PM   #493
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
In extremely simplified numbers...
Consensus seems to be around 300-350 crank hp or 240-280 wheel hp, all the 50 state emissions legal kits and tunes are at the bottom end of that at ~240-250whp claiming ~300 crank hp and I have not seen any of those blow up yet. I think some feel comfortable pushing ~300 whp but that is kind of the current edge imo and I think you get into clutch and potentially driveshaft issues at that point.
I would not mind being contradicted, I need to know more, personally a 50% increase in power for a couple thousand bucks and I don't have to worry about legality is a goddamn bargain.
ineedyourdiddly
Old 08-31-2015, 04:16 PM   #494
OkieSnuffBox
Drives: '23 BRZ Limited
That's what I was thinking, not that I'm a guru or anything, but just reading the dozens and dozens of threads here....that seems to be the point past which people start to have problems, whether temp related or a nice big ventilation hole in the block.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
strat61caster (08-31-2015)
Old 09-01-2015, 11:03 AM   #495
Wretch
Drives: FRS
I have voted wrong. Missklicked on complete Failure. Mine isn´t Boostet yet. Can Someone of the Admins delete my Vote pls.
Wretch is offline   Reply With Quote
Old 09-01-2015, 11:26 AM   #496
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Three weeks ago I had the motor shut off which idling. It sounded pretty rough just before dying and two cranks killed the battery. The car is now sitting at home after SoA denied warranty citing a drop of oil on the drain plug (literally a a drop the size of a small pea accumulated on the bottom of the drain plug). It sounds like a spun bearing. We can confirm when the block gets torn down.
NA 2013 BRZ with Openflash Header and Tune. No other mods. 38k
Luckrider is offline   Reply With Quote
Old 09-01-2015, 11:27 AM   #497
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Who tuned it?
Sent from my SAMSUNG-SM-N900A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 09-01-2015, 11:36 AM   #498
Luckrider
Luckrider's Avatar
Originally Posted by texasbound972 View Post
Who tuned it?
Openflash OTS. It doesn't appear to be tune related. SoA cleared the modifications from being the reason of failure. They are not denying warranty claim on that issue.
To expand. The dealership says they put 4 quarts of oil. Oil was checked less than 3 days before the incident.
Old 09-01-2015, 11:48 AM   #499
texasbound972
USMC
That sucks man. Fuck it, build up your block and get a proper tune by Church Performance. Hope everything works out man. I know the struggle lol. I'm on my 2nd built block. Engine blew from overboost in December, head gasket repair on my built block in May, then spun a rod bearing in June which made me get my second built block lol. Sucks balls! $25k in 7 months on engine bullshit alone.
Old 09-01-2015, 11:51 AM   #500
nelsmar
Wait you only had 1 drop left in the oil pan? Or there was one drop visible on the outside of the oil pan?
My flickr - Canibeat
Local magazine scout
Old 09-01-2015, 12:00 PM   #501
Luckrider
Luckrider's Avatar
No, Subaru told me they were denying for maintenance errors due to a leak. The leak was one drop on the drain plug. Oil showed on the stick when it was pulled on the side of the road.
Old 09-01-2015, 12:10 PM   #502
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
did you read the op?
You say you have a NA 2013 BRZ and you posted that you blew your stock BOOSTED motor? If you're NA, you're NOT boosted...
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
texasbound972 (09-01-2015)
Old 09-01-2015, 12:14 PM   #503
Luckrider
Luckrider's Avatar
Jaden
Stock NOT BOOSTED. I posted in here because people are compiling motor failures and the common causes.
Old 09-01-2015, 12:23 PM   #504
Jaden
Road-hole
read the thread title one more time a little more slowly...
Try reading the thread title a little more slowly...
"Anyone Blown a stock boosted motor yet?"...
They mean a non built BOOSTED motor...
Jaden
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
