#127 |
Enjoyed the video Steve! Missing those roads already... It was great getting to meet and chat. Maybe next time we can find time to organize a hangout. We will bring cookies!
| The Following User Says Thank You to Beastronix For This Useful Post: | stevesnj (08-19-2015) |
#128 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#129 |
I am loving the LED lights for cars and so far I converted over my LandCruiser and now I'm going to do the 86. So I finally got my LED's from China and they look great! I waited for a few weeks specifically for the red rear signal bulbs, that will replace the amber, which project the light towards the reflector creating a nice even bright light. The front switchbacks I had to wait also to get the proper lumens that matches the filament bulb lumens for amber and white. White is 6k and amber 3k in the switchback. I had an issue with all the bulb bases as they are tight putting in the socket. I pushed the bulb's in and they kept on popping out of the socket. They worked but they would pop out. Weird! So I took them out and pushed more firmly and they slid right in farther into the socket. One of the front switchbacks and one of the rear red signal bulbs fell into the housing. Yikes. Getting the front switchback out was easy wit a claw grabber, in the rear no such luck so since the bulb uses metal prongs I attached a magnet to the end of a piece of wire and went fishing. Took a couple of minutes but it worked out nice. Also the wire for the rear socket is way short and meant for a smaller filament bulb and the LED is longer so I had to place the LED into the housing and holding wit a pliers I pushed on the socked. I pushed it fully into the socket base using my hands. The rear bulbs are polarity sensitive so I tested them outside the housing and marked with a sharpie the proper orientation. Waiting for my LED flasher unit due tomorrow so living with hyperflash for a few days.
Links for bulbs; Switchbacks I can't find the link for these Rear Red Signal http://www.aliexpress.com/item/2pcs-...301780128.html
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 08-23-2015 at 09:43 PM. |
#130 | |
Drives: Scion FR-S 10 Series #2263
Links to the LED's you used? The temperature difference vs headlights for the front switchbacks really bothers me for the ones I got (corn cob / diamond style emitter) |
#131 |
Yeh the switchbacks and the headlights clash. I am getting LED headlight bulbs but not just yet. Posted the link for the red bulbs I can't find the link for the switchbacks
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 08-23-2015 at 10:31 PM. |
| The Following User Says Thank You to stevesnj For This Useful Post: | aegisdrgn (08-23-2015) |
#132 |
please don't get LED headlights. I haven't seen one where they outperform a proper halogen projector setup, let alone an HID setup. if anything, you will probably get better performance with an HID kit. and if you upgraded to the bi-xenon from factory, then there's no need to touch it lol.
| The Following User Says Thank You to ryoma For This Useful Post: | Bergen23 (09-13-2015) |
#133 | |
#134 |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
More pics
#135 |
#136 |
Anything! Waiting on Oceanic also, just trying to build up my own hype =)
| The Following User Says Thank You to NARFALICIOUS For This Useful Post: | stevesnj (08-31-2015) |
#137 | |
Drives: frown slasher
#138 |
Well to me the Oceanic has more metallic than the UM but need a side by size comparison still...but the hype is true...it's a perfectly powered, handling, and fun car. Just pick a color and enjoy!!
#139 |
#140 |
Yep some just don't need to travel as much as others. There are people with as low as 3 on here.
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 07:09 PM |
| 2016 FR-S vs 2016 MX-5 Coupe | NWFRS | FR-S / BRZ vs.... | 55 | 11-29-2013 11:17 AM |
| EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 07:34 PM |
