Old 08-29-2015, 11:39 PM   #393
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Originally Posted by nelsmar View Post
People should buy a turbo car in the first place I 100% agree. i personally like wrenching and building things and there wasn't a small light turbo car with an excessive power to weight ratio on the market for me... So I built one.... With forged internals.
So you basically are doing what I am doing, but going turbo first then criticizing me for what I spend my own damn money on... aren't you a damn winner...
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
The Following 2 Users Say Thank You to ShadowSeraph For This Useful Post:
chaoskaze (01-27-2016), nelsmar (08-30-2015)
Old 08-29-2015, 11:41 PM   #394
ShadowSeraph
Originally Posted by Kiske View Post
Spoke with Justin last Wednesday while ordering some more parts. They still don't have any of the manifolds instock, nor had an eta.
@ShadowSeraph look at nelsmar's reply this way. By the time you buy the intake manifold, install it and have your car re-tuned, you will already have 1/2 the cost for the FBM base kit
Then it is a good thing the person he was specifically replying to said he was wanting to go turbo when his finances allow.
Eh... it is a long slow climb anyway until my wife gets her CPA and I become a dual income household.
Borla: UEL Header
Old 08-30-2015, 10:46 AM   #395
nelsmar
With all the time and money I have in my car I still have yet to see a single reason to buy a manifold. So no. No we are very far from the same. I wanted a power upgrade so I saved up and went FI right off the bat and then upgraded components I needed when I decided that I wanted more power after getting comfortable with the power instead of just going instantly to 500+HP off the bat. I also dont have a stock block where I am limited by compression, internals, and transmission strength (you know where the manifold would help...).
Well, It is my damn money to waste and who says that in I wont own this car for long enough to build the engine and do transmission upgrades. Anyone can call anything another person does with their money a "waste". I suppose anyone who goes a full effort NA build, you would call a "waste" too then.
"Im just trying to point out that people who buy parts that you use for "end game" FI setups BEFORE they go FI are wasting their money." <<< DA F**k is the difference before or after you go FI.. the $ amount is the same... now to move on from that moot point. Whatever man...
My flickr - Canibeat
Local magazine scout
Old 09-28-2015, 08:43 PM   #396
Slicknick951
Slicknick951's Avatar
Drives: 2014 WRB Brz
I hate to be that guy but I was really interested in those NA results
Slicknick951 is offline   Reply With Quote
The Following 2 Users Say Thank You to Slicknick951 For This Useful Post:
Mike Brz (02-21-2016), TouchMyHonda (11-07-2015)
Old 09-28-2015, 08:47 PM   #397
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I'm also interested. More importantly, after some new discussion about how efficient the heads are, I'm curious to see the number at the high RPM ranges, even above the stock limiter.
Luckrider is offline   Reply With Quote
Old 09-29-2015, 01:01 PM   #398
fika84
fika84's Avatar
Also in for NA results!
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Old 10-11-2015, 01:04 AM   #399
Mattygt86
Drives: red beam of hope with a frs badge
sooooooooo
Mattygt86 is offline   Reply With Quote
Old 10-11-2015, 03:10 PM   #400
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Intake manifolds designed to flow for forced induction are not going to make power NA.
Increased volumetric efficiency is where you will pick up NA power from an intake manifold. VE, especially at high RPM's is 100% dependent on velocity and harmonics. This requires careful selection of runner length and diameter, as well as runner geometry and plenum volume. Velocity and harmonics are your enemy when tuning FI; maintaining high and consistent manifold absolute pressure with minimal (linear and consistent) loss between the plenum and the cylinders is your friend when tuning FI. High static pressure is dependent on minimal velocity, and consistency necessitates minimal harmonics. A large, bored out plenum with shorter and wider runners is what I see here. That's not going to help with High RPM VE NA. It just isn't. I don't have to see a dyno to know that.
Just from a glance, looking at this manifold and hoping it will help you pick up NA power demonstrates a fundamental misunderstanding of NA tuning.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 10-11-2015, 04:01 PM   #401
Irace86
Drives: BRZ + Ducati M796
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Haha, jk, thanks for the info.
Irace86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Irace86 For This Useful Post:
Dream20b (01-27-2016), fika84 (11-07-2015), Spartarus (10-11-2015)
Old 01-26-2016, 11:50 PM   #402
ort895
ort895's Avatar
So i see this kinda died, updates?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
The Following User Says Thank You to ort895 For This Useful Post:
FirestormFlex (11-26-2016)
Old 01-27-2016, 02:02 AM   #403
FRS Justin
Drives: 2013 Asphalt FRS
Any independent dyno test results yet?
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
ort895 (01-27-2016)
Old 01-27-2016, 07:59 AM   #404
ort895
ort895's Avatar
i sure as hell cant find anything
The Following 2 Users Say Thank You to ort895 For This Useful Post:
FRS Justin (01-27-2016), raven1231 (01-27-2016)
Old 01-27-2016, 08:27 AM   #405
Dream20b
Y u do dis?
new signiature
Dat Hot Lava Doe
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
Irace86 (01-27-2016)
Old 01-27-2016, 10:30 AM   #406
Irace86
Haha
The Following User Says Thank You to Irace86 For This Useful Post:
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold cover protpibe Engine, Exhaust, Transmission 16 02-28-2014 06:44 PM
Wanted intake manifold ciro Want-To-Buy Requests 0 09-27-2013 12:03 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 01:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
