Old 08-29-2015, 11:28 AM   #43
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Originally Posted by olsonpg View Post
You said you used Nite Shade for the reflective bits, does that include the turn signal chrome housing??
THanks in advance.
Yes
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 08-29-2015, 11:30 AM   #44
poorsche
poorsche's Avatar
Originally Posted by waltco View Post
I wish I knew about the tape when I did this, I had absolutely no patience for the RTV method and within hours I had condensation. Also, Dremel is quick but cuts are messy, definitely going to try the heat method!
Edit: Could you go into detail on the sealing process?
Basically lay a thick bead of the 3m material along the cut line and pack it into the crack. You can be really liberal with the sealing material as none of it shows.
Old 08-29-2015, 11:33 AM   #45
poorsche
poorsche's Avatar
Originally Posted by tato.valverde View Post
I'm extremely happy with the look!
I didn't paint the turn signal reflector for legal reasons, but the rest is pretty much what you suggested.
However, I used a soldering iron and don't recommend it at all, get a dremel and do it right, people
Looks really good! A dremel doesn't work as well as you think it would, in the tight areas you end up with really big cuts that are harder to fill.
The Following User Says Thank You to poorsche For This Useful Post:
tato.valverde (08-31-2015)
Old 12-03-2015, 02:37 PM   #46
killswitch
killswitch's Avatar
Drives: 2013 Subaru BRZ
How has this held up? Still no condensation or issues with the paint? Thinking about tackling this over Christmas.
killswitch is offline   Reply With Quote
Old 12-03-2015, 05:34 PM   #47
zman
zman's Avatar
Drives: scion frs
I did this and it's fine so far but I would been happier if I just bought valentis
Sent from my iPhone using you know what
zman is offline   Reply With Quote
Old 12-03-2015, 08:10 PM   #48
killswitch
killswitch's Avatar
Honestly I think these look better... Hell of alot less expensive.. Thanks for the info though.
Sent from my SM-G920V using Tapatalk
Old 12-04-2015, 01:36 PM   #49
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Mine held up perfectly, no condensation at all.
However, during a snow storm in Chicago a couple weeks back, i did get frost inside the lens, not sure how.
After it got warmer, it's gone and there's no condensation whatsoever
tato.valverde is offline   Reply With Quote
Old 12-26-2015, 10:02 PM   #50
killswitch
killswitch's Avatar
Well so far I've done a good job fvckin' these tailights ALL up... ugh...
Old 12-27-2015, 03:56 AM   #51
zman
zman's Avatar
Drives: scion frs
That's why I recommended the valentines. How bad did you mess up?
Old 12-27-2015, 11:28 AM   #52
killswitch
killswitch's Avatar
Just paint issues. Tape was pulling it off. I let it sit over night and tried again with a different paint and that seems to have worked better. Valenties are hideous. Hell cutting was the easy part for me.
Old 12-27-2015, 01:44 PM   #53
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I think you mean valentis
Old 12-27-2015, 03:52 PM   #54
zman
zman's Avatar
Drives: scion frs
Yes autocorrect. Make sure you post a picture when you're fully done
Old 12-27-2015, 04:06 PM   #55
FRSBRZGT86FAN
Nah, I probably won't be painting mine, the LED turn signals were the only mod to my tails. I'll look into Tom's tails or valentis eventually
Old 12-27-2015, 06:45 PM   #56
mengmoua
Drives: 2016 Raven Fr-s
I butchered mine up pretty bad too. Didn't even get to paint it. I knew the project was over once I was done cutting lol. I used a butane soldering tool and had trouble cutting in tight spots. O well...just gonna wait for the valenti revo now.
mengmoua is offline   Reply With Quote
housing, lights, oem, retrofit, tails
Trade: Black Spyder V1 Tails for Tom's Tails Cross Exterior Parts (Aero, Lighting, Etc.) 3 07-05-2014 04:19 PM
Painting tails red. Is it worth wet-sanding/clear coating? nodeal Cosmetic Modification (Interior/Exterior/Lighting) 25 04-01-2014 05:17 PM
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 20 11-08-2013 01:51 PM
Painting the inside of the FR-S DealerFR-S Cosmetic Modification (Interior/Exterior/Lighting) 21 07-10-2013 11:29 PM
WTT: MY USDM Tails for your JDM/ADM/UKDM Tails ZC6BRZ Exterior Parts (Aero, Lighting, Etc.) 2 01-16-2013 11:24 AM
