Old 03-05-2014, 02:41 AM   #1
nodeal
Drives: Scion FRS
Painting tails red. Is it worth wet-sanding/clear coating?
Hey guys, I have vinyl overlays on my tail lights to make them red. It looks great on my whiteout frs, but they don't wrap around the entire tail light which pisses me off from certain angles. Also, they lack gloss and shine which I do not like either.
I want to paint them red with the VHT Nightshade Red. I see a lot of people here using it for this purpose.
I wanted to know how essential it is to wet-sand, clear coat, polish, etc. after applying the initial layers of red paint? I have seen pictures of them without being wet sanded or polished or anything, and although they do have a matte look they are still better looking than the vinyl overlays I have.
Is the wet sanding really worth it? I honestly don't want to have a job that looks half-assed, but the pics I have seen without the wetsanding/polish really do look very good.
My painting skills are limited. I've painted a couple side-view mirrors and plasti-dipped my emblems and rims. All came out very nice, but I am no expert. Is the wet sanding hard or easy to mess up? Can someone link me to a good DIY for the wet sanding, clear coating, polishing, etc. part? Detailing each step and proper application and procedure, particularly for a tail-light or surface of this sort?
Thanks guys!
nodeal is offline   Reply With Quote
The Following User Says Thank You to nodeal For This Useful Post:
Jolaessss (03-05-2014)
Old 03-05-2014, 03:15 AM   #2
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
I too, want to do this but a bit on the fence
Jolaessss is offline   Reply With Quote
Old 03-05-2014, 05:48 AM   #3
vincent201089
vincent201089's Avatar
Drives: frs
Yes. wet sanding will remove all orange peel you see on your paint surface to give it a pro look. You could skip the wet sanding but clear/polish/wax are must-to-do (especially clear coat). wet sanding also helps to remove unwanted dirt/hair that stick to the paint when you spray.
Here are how I did mine.
- 3 light coats of duplicolor metalcast
- 2-3 medium coats
- 2-3 mid-heavy coats ( wait between coats was around 15')
That was all. Wait overnight and put tails back on the car and left it there for a week to let the paint cured.
- wet sading with 2500 sand paper (some people don't but I did)
- looks like shit but people say clear coat will bring everything back (true)
- 3-4 light coats of spray max 2k (they say this is the best clear coat for shinny)
- 3-4 medium coats
- 3-4 mid-heavy coats (wait was around 15' between coats)
And I did put it back on my car and wait for another week (paint needs time to cure and I only can do all my car stuff once a week on my day off)
- wet sand with 2500 sand paper, you can go with 1500 and follow with 2000 or start with 2000 to remove the orange peel faster and use 2500, 3000 is even better (I stopped at 2500 cause I couldn't find 3000 at autozone).
- rubbing compound
- polishing compound
- wax
I never seen a pro job but my eye can tell that my job was not bad. Don't have any thing to complaint !!!
vincent201089 is offline   Reply With Quote
The Following User Says Thank You to vincent201089 For This Useful Post:
wrb (03-06-2014)
Old 03-05-2014, 11:48 AM   #4
nodeal
Drives: Scion FRS
- 2-3 medium coats
- 3-4 medium coats
- rubbing compound
- wax
That sounds like a lot of fun…
I have never wet sanded before. Stupid question, but do you wet the surface of the tail light, and then sand it down? Or do you wet the sand paper and then sand it down? Or it doesn't matter?
How come you went with Duplicolor Metalcast over the VHT Nightshade?
If you have pics of the finished job, I'd love to see them
Old 03-05-2014, 12:24 PM   #5
wparsons
wparsons's Avatar
Wet sanding just uses water as a lubricant to give a smoother finish when sanding and keep the very fine paper from clogging.
You'll definitely want to wet sand after the colour coats (before the clear), and also wet sand and buff the clear for best results.
flickr
Old 03-05-2014, 12:29 PM   #6
sirsol66
Drives: 2013 FRS- Hot Lava
Without a proper clear, expect your color to fade.
I actually liked mine best with just the red, but added the clear to protect it. Of course the clear ran, so I had to wait two weeks and then sand/buff it back. It looks nice now, but boy was it a pain. Still, I would recommend clear coating.
sirsol66 is offline   Reply With Quote
Old 03-05-2014, 01:03 PM   #7
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
More info and pics in these threads:
http://www.ft86club.com/forums/showthread.php?t=7826
http://www.ft86club.com/forums/showthread.php?t=32259
Drift&Drag is offline   Reply With Quote
Old 03-05-2014, 01:06 PM   #8
vincent201089
Drives: frs
I was worry about messing everything up when I wet sand then red coat before applying the clear. However, I followed the instruction in the Diy thread and they say that we dont have to worry, clear coat will bring the shine and gloss back.
Evrything looked perfect after the clear was dry/cured but there was tons of orange peel/uneven level because of the home job. Thats why we have to wet sand to remove the orage peel to make the surface even/remove small dirt/hair sticked to the paint.
After sandding everything down. I started with rubbing compound to remove big scratches and followed with polishing compound for thinner scratches. Now you will see your job looks just like it just came out from the factory. Lol and just a thin layer of wax to bring up the shine/gloss. Thats it.
Good luck.
Old 03-05-2014, 07:15 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
http://www.club3g.com/forum/3118649-post22.html
Old 03-05-2014, 07:21 PM   #10
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
You need 3M Hand Glaze to get the orange peel out of the clear coat.
Here's something I posted elsewhere recently:
Wetsand with 2000 grit and use 3M hand glaze after your clearcoat hardens. Works great for getting out orange peel as well.
Before:
After:
That's about 10 minutes of sanding/polishing. One coat. You can make it even better by repeating. Give the glaze a few days to set and it should be good for outdoor use.
fourvalleys is offline   Reply With Quote
The Following User Says Thank You to fourvalleys For This Useful Post:
Old 03-05-2014, 10:09 PM   #11
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
So what did you use to paint yours? I'm really wanting to do this and the color you have is perfect IMO. And did you wetsand and then use the 3M hand glaze or was it the other way around?
Husker BRZ is offline   Reply With Quote
Old 03-06-2014, 09:58 AM   #12
fourvalleys
Howdy!
It's VHT Nite-Shades. In retrospect, I think I should have used DupliColor MetalCast, as VHT looks to be a bit darker. I prefer the candy-apple red look over the almost-smoked look, but that's just my preference.
In this order:
- Sprayed 2-3 coats of VHT (light 2000 grit wet-sand between each coat to scuff)
- Sprayed 2 coats of clear (light wet-sand between coats - you may want to do more than two coats)
- wet sand clearcoat once hardened
- 3M hand glaze
If it still isn't perfect...
- went sand again if there are remaining imperfections in the clear
- 3M Hand Glaze
Just give the 3M a day or two to set. If you touch it an hour or two after you hand buff, it will still scratch easily and leave marks. Even a microfiber can leave marks when it's fresh. Just be patient. At least leave it overnight before installing them.
Husker BRZ (03-06-2014)
Old 03-06-2014, 10:48 AM   #13
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
[IMG][/IMG]
[IMG][/IMG]
In this order:
- 3M hand glaze
- 3M Hand Glaze
Why not only use red VHT if you wanted them to be red? those are super dark.
headlikeahole is offline   Reply With Quote
Old 03-06-2014, 11:42 AM   #14
fourvalleys
Howdy!
That is only red VHT.
I didn't think it would darken as much as it did with a second coat.
e: here are a couple other pictures. It's dark, but not super dark.
Here's how it looked (wet) after the first coat. When this coat dried it was noticeably darker.
This is what ONE coat of VHT Red looks like in direct sunlight:
Powder coating vs painting Rims Giccin Other Vehicles & General Automotive Discussions 36 01-28-2015 07:44 PM
WTT: Buddy Club Tails for Clear Toms CreinCrein Canada Classifieds 25 10-15-2014 12:56 PM
*LEGIT USDM TOM'S TAILS US LEGAL! RED LENS & CLEAR LENS $450 AUTHORIZED DEALER!!!* Vicious LED Exterior Parts - Lighting 121 04-19-2014 04:13 PM
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 20 11-08-2013 01:51 PM
Wet sanding curves qoncept Cosmetic Modification (Interior/Exterior/Lighting) 3 07-02-2013 02:50 PM
