Old 08-22-2015, 01:49 PM   #29
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
I don't notice any difference between D, M, sport, etc and any combination of the above.
I feel that there is some correlation between throttle position, transmission temperature, and rpm that gives you the jerk.
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 08-22-2015, 09:16 PM   #30
boxerfan
AT Transmission Hard Shifting
Originally Posted by RayC_FRS View Post
I've been putting the trans in manual or sport mode as soon as I put it into D and keeping it there for the drive to avoid the hard shifts. Also, what some may not notice in the hard shifting video is that the whole car violently jerks when it shifts and its not just a hard shifting feeling.
For reference, on my car, when the shifts are felt, the car does not jerk violently, the shock is felt through the steering.
Certainly something is not right with your unit. Best for the dealer to address.
boxerfan is offline   Reply With Quote
Old 08-23-2015, 08:51 AM   #31
MechEGR
Drives: 2015 Scion FR-S AT
UPDATE: After a week of testing all this further, this is what I have found:
My car is hard shifting/lurching in both sport mode and manual mode. It does not make a difference between the two.
It does not matter what gear i'm in, it always lurches the same.
Turning the car off and on still instantly gets rid of the issue.
The car most consistently hard shifts when I have been driving at high speeds (60+mph), and then stop, put it into sport mode or manual mode, and continue driving. I still had one instance where it hard shifted upon startup though.
As a couple people have mentioned, and as you can kind of see in the video, the whole car definitely lurches when it is hard shifting. This is not a slight bump that can only be felt through the steering column, and was definitely not purposely programmed.
Going to be calling the dealer on Monday and seeing what their recommended next steps are.
MechEGR is offline   Reply With Quote
The Following User Says Thank You to MechEGR For This Useful Post:
RayC_FRS (08-23-2015)
Old 08-23-2015, 06:13 PM   #32
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Good luck and hope this issue gets fixed. I've tried do replicate this but it's been silky smooth on my car.
The Twins make me smile
Old 08-24-2015, 06:17 PM   #33
about94ninjas
Drives: 2015 WRB BRZ Limited 6AT
I have this same issue, and when the hard upshifting occurs, the car won't rev match downshifts. Going into first at about 25 MPH causes the tires to chirp. It seems as though the ECU isn't applying throttle when shifting. Also, when taking off normally in auto, when the car shifts into second at about 2,000 RPM, it feels like there's a drop in torque for a couple seconds, and that's when the problem starts.
Sometimes when I come to a complete stop, the RPMs will dip below 500 then jump up to about 950, although I'm not 100% sure the two are connected.
about94ninjas is offline   Reply With Quote
The Following 2 Users Say Thank You to about94ninjas For This Useful Post:
Bergen23 (08-25-2015), MechEGR (08-25-2015)
Old 08-24-2015, 06:22 PM   #34
MechEGR
I definitely get some funky downshifting as well but have never gotten any tire chirp. This is 100% an electronic issue.
I haven't noticed the RPM's jumping like that but I'll keep an eye out for it.
Old 08-24-2015, 06:43 PM   #35
about94ninjas
I'll try to get a video of it next time it happens.
Old 08-24-2015, 07:51 PM   #36
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
In regards to the rpm drop upon stopping, was your AC running? AC compressor is a parasitic draw on engine power. It will cause that rpm dip. It's normal if that's the case.
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
MechEGR (08-24-2015)
Old 08-25-2015, 12:09 AM   #37
about94ninjas
That could be the case, but the drop is usually not that severe. I'll take note of it next time to be sure.
Old 08-25-2015, 12:33 AM   #38
Bergen23
Drives: '15 Halo FR-S
This is exactly what happens to me, check my video
@Wayno
[ame="https://www.youtube.com/watch?v=kowBGGlK18M"]Downshift problem - YouTube[/ame]
Bergen23 is offline   Reply With Quote
Old 08-25-2015, 12:40 AM   #39
about94ninjas
That's exactly it! Did you happen to notice if your car was idling weird?
Old 08-25-2015, 12:48 AM   #40
Bergen23
It has the usual idle dip, but nothing weird as far as I remember.
Old 08-25-2015, 08:52 AM   #41
MechEGR
Yikes, I don't think mine is anywhere near as bad as that. Are going to take yours into the dealer again?
Old 08-25-2015, 09:21 AM   #42
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The shifts in sport and manual should be hard but they should rev match perfectly 99.99% of the time, except when you do something very funky to confuse the TCU like force a downshift by hard braking then immediately hit the throttle.
I only ever drive in auto and manual though, never sport. I did let my dad drive it at the track once in sport mode and it worked perfectly. Plenty of hard driving, shifting at 7300-7500 rpm, downshifting right before getting on the throttle, etc.
[ame="https://www.youtube.com/watch?v=FckSpnpu2ag"]2015 Queensland Raceway Clubman 86's - YouTube[/ame]
Any idle issues are an entirely different matter relating to ECU tune. Nothing to do with the AT.
The Following User Says Thank You to Wayno For This Useful Post:
automatic, hard, issues, shifting, transmission
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 12:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
