Old 08-23-2015, 09:59 AM   #15
BRZnut
Drives: BRZ DGM Limited
Also, make sure you don't need to add distilled water to your battery. The stock battery is not maintenance free. Check the fluid level (there are makings in the outside and you can also take each cap off and look inside.
If its low on distilled water, you need to add some or trying to charge it when dry will not get you anywhere.
The Following 3 Users Say Thank You to BRZnut For This Useful Post:
humfrz (08-23-2015), levifig (08-24-2015), Tcoat (08-23-2015)
Old 08-24-2015, 03:47 AM   #16
levifig
GBS Mafia Member
levifig's Avatar
Drives: N/A
All that aside it is a know fact that the stock batteries in some of these cars have had some issues. If your battery went flat after just a week or two of sitting then it will happen again. Bite the bullet and go get a new high quality battery and be done with it. I have had high quality batteries in project cars that have sat for two years and started on the first try.
Nice tips! I went ahead and ordered the charger because, push comes to shove, it's a "nice to have". Having said that, I'm seriously considering a new battery. Any brand/models you'd recommend to a stock car? Thanks in advance.
levifig is offline   Reply With Quote
The Following User Says Thank You to levifig For This Useful Post:
Tcoat (08-24-2015)
Old 08-24-2015, 06:44 AM   #17
Never hurts to have a charger on hand and they are cheap enough.
There are different brands and sources available in the U.S. then we have here so I will let somebody from down there field the question.
Old 08-24-2015, 08:54 AM   #18
... Any brand/models you'd recommend to a stock car? Thanks in advance.
I wouldn't worry about the brand as much as the replacement/total warranty. that will speak towards the battery quality. Also, check the manufacturing date so you get one as fresh as possible.
A large percentage of batteries in the US (and probably the world) are made by the same single company anyway (Johnson Controls). They make most "private label" batteries including Interstate, DieHard, Duralast, EverStart (WalMart brand), Kirkland, ProStart. They own Varta, Optima, LTH and Heliar, and make OEM batteries for Ford, Chrysler Honda, Toyota and Nissan.
Old 08-24-2015, 12:15 PM   #19
stevesnj
stevesnj's Avatar
Never ever charge a battery via the alternator from a dead state. When charging from a charger make sure the terminals are disconnected and you charge at the lowest amperage possible. I charge at 2amps for a good 6 hours and that works well, slower yes but less chance of sulfation that way.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Chad86 (08-01-2016), levifig (08-24-2015)
Old 08-24-2015, 05:09 PM   #20
ryoma
ryoma's Avatar
Duralast from AutoZone is a good brand if you want to replace your battery. their warranty rocks. my brother's battery had extreme corrosion and his terminal was stuck on the post. after pouring coke and getting the corrosion off and terminal unstuck, we noticed that the post was lifting slightly when pulling on the terminal. we took it to AutoZone and wanted to buy a new battery, but they looked up his info in the system and gave him a new one for free. it had been at least 3 years since he bought the battery and they still replaced it. caught me off guard.
Old 08-24-2015, 06:11 PM   #21
levifig
GBS Mafia Member
levifig's Avatar
Drives: N/A
Charging mine at 6A with a charger. It's coming up nicely… Maybe I should get it down to 2A though. I did take the battery completely out of the car and brought into the house (i.e. into an unused bathroom, where I can run the exhaust fan).
It took about 5 minutes to go from 0% charge to about 50% (again, 6A). The fluids seem to be good so I have faith in this battery… :P
stevesnj (08-24-2015)
Old 08-24-2015, 07:59 PM   #22
stevesnj
stevesnj's Avatar
Cool
Old 08-26-2015, 04:33 AM   #23
levifig
GBS Mafia Member
levifig's Avatar
Drives: N/A
Well, I guess "final update": fully charged (to 100%) in about 12h at 6A. Seems to be working just fine now…
Thanks for everyone that sent in their tips and recommendations!
aegisdrgn (08-26-2015)
Old 08-26-2015, 04:54 AM   #24
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
OP, thanks for the final update to conclude your issue. You are a rare breed, indeed.
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
levifig (08-26-2015)
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 05:17 PM
Dead battery Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-07-2015 10:58 AM
Dead battery. AlanKent BRZ First-Gen (2012+) — General Topics 50 03-31-2015 02:36 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 05:06 PM
Ignorance and a dead battery Red John Issues | Warranty | Recalls / TSB 9 03-02-2013 02:29 PM
