GBS Mafia Member
Drives: N/A
Battery dead. Warranty ended less than a month ago…
2013 BRZ Limited MT owner here.
For many reasons, I haven't been driving the car daily in recent months and, as I needed to drive to the grocery store a week ago, after not touching the car for about 2 weeks, the battery was dead. And I mean DEAD: no signal whatsoever, Rev needle stuck on 9k. Today I used my other car to jump it (2015 VW Jetta TDI) and drove around for about 5 minutes and stopped and turned off the engine. It couldn't start it back up. So I jumpstarted it again, drove home and parked. I have researched it a little bit and it seems I shouldn't have even driven it with that dead/dying battery anyway, as it strains the alternator too much. Well, I've learned that now and so now I'm in the market for a new battery. I hear the stock batteries aren't great but I do have the car stock so I don't *need* the extra power, though I'm sure I should buy a little bigger battery. So, what is the recommended battery replacement for a stock BRZ Limited MT? And I should be able to replace it myself, right? I'm handy so I'm confident I can figure it out, but I would like to make sure this car doesn't have some special sauce that would require a special key (or enchantment) to make it work… ![]() Thanks for the/any help… |
#2 |
Drives: '13 FRS - STX
5 minutes is not long enough to charge the battery, go for a longer drive before you drop the money on a new battery imo, 30+ minutes.
I killed my battery by leaving an interior light on over a few days, jumped it and drove it ~45 minutes and it hasn't missed a beat since, that was 2 years ago. |
#3 |
Drives: 2013 Subaru BRZ Premium
Same thing happened to me when I first got my car. I didn't drive it for about a week plus the dying out from being my first manual and car alarm proximity sensor probably didn't help either.
I also tried driving the car to recharge the battery, but it didn't help and I stopped after reading that it's not good for the alternator. I thought I would need a new battery since it was as bad as your battery, but it's like new and I've never had any issues after recharging it. If you still want to try using your old battery, then you might want to try a battery charger like Schumacher or Battery Tender which are about $20-40 on Amazon. Cheaper ones charge slower and take longer. Don't get like a trickle charger though, get like at least 10 amp charger and charge for about a day. |
#4 | |
GBS Mafia Member
Drives: N/A
![]() Any specific model recommendations? |
#5 |
I have the Schumacher SC-1200A, which was about $35. I thought it wouldn't work, but it worked for my "dead" battery.
I remember reading somewhere though that if you leave the battery "dead" too long, then it's less likely to revive, so might want to try as soon as possible. I've also heard good things about Battery Tender, but they are more expensive and you'll probably need a higher end model to revive a "dead" battery.
| The Following User Says Thank You to dys586 For This Useful Post: | levifig (08-22-2015) |
#6 | |
GBS Mafia Member
Drives: N/A
I hope I don't have to start researching new batteries any time soon… :X |
#7 |
Yeah, only difference is the amp, recharging might take a little longer than the 12 amp, but either one will work. Good luck.
#8 | |
GBS Mafia Member
Drives: N/A
Thanks for the tips and recommendations! |
#9 |
I think you guys are worrying too much about a dead battery lol. if it's dead, jump it and drive for a good 30+ minutes. you want to go all around the rev range and not just stay like under 3k. that's what I have done on all my cars that have died on me and haven't yet encountered any problems with it.
and if you do buy a new battery, just go to autozone and buy one. all you do is tell them your car and they will get you a battery. it's extremely simple, though somewhat expensive at about $130 a pop.
| The Following 2 Users Say Thank You to ryoma For This Useful Post: | strat61caster (08-23-2015), Tcoat (08-23-2015) |
#10 |
This may be useful information for your situation:
http://www.aa1car.com/library/battery_runs_down.htm I feel that a car with a good battery, should be able sit for at least two weeks and still start the car. humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | strat61caster (08-23-2015), wbradley (08-23-2015) |
#11 | |
GBS Mafia Member
Drives: N/A
![]() Is this wrong? I mean… I "read it on the Internet" so it must be true, right?
| The Following User Says Thank You to levifig For This Useful Post: | Tcoat (08-23-2015) |
#12 | |
#13 |
If the battery was totally drained, it probably isn't a good idea to recharge it via the alternator, just because it will take a while. I would spend the money for a battery charger (they just aren't that expensive) and recharge it that way. However, if your battery is over about three years old, I would just go ahead and replace it. It will cost a little more, but it takes 10 minutes to do, and you'll be done with it.
if you want to recharge the battery, do it overnight with a charger.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#14 |
There are two different scenarios at play here when you start to talk damage to alternators.
An alternator is perfectly capable of charging a dead battery as long as the battery is still good. If you damaged an alternator by boosting and letting it charge then places like AAA would not boost due to all the lawsuits they would have. The alternator has a complete system that protects it from damage while charging. This is what it is designed to do. Now if you have a faulty battery then yes you can cause serious issues by trying to recharge by driving. The charging system is designed with a properly working battery in mind so it can not protect the alternator if the battery will not take a charge at all or if there is a short. Although the alternator will eventually charge the battery even at an idle it would take a long time. To charge it by running the car you need to keep the revs as high as possible so a half hour highway run should be more than enough. All that aside it is a know fact that the stock batteries in some of these cars have had some issues. If your battery went flat after just a week or two of sitting then it will happen again. Bite the bullet and go get a new high quality battery and be done with it. I have had high quality batteries in project cars that have sat for two years and started on the first try.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (08-23-2015), humfrz (08-23-2015), levifig (08-24-2015), strat61caster (08-24-2015), wbradley (08-23-2015) |
| Dead battery | technoid | BRZ First-Gen (2012+) — General Topics | 17 | 03-17-2016 05:17 PM |
| Dead battery | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 33 | 08-07-2015 10:58 AM |
| Dead battery. | AlanKent | BRZ First-Gen (2012+) — General Topics | 50 | 03-31-2015 02:36 AM |
| Dead battery!?! | Hoahao | Issues | Warranty | Recalls / TSB | 5 | 02-23-2015 05:06 PM |
| Ignorance and a dead battery | Red John | Issues | Warranty | Recalls / TSB | 9 | 03-02-2013 02:29 PM |
