Old 08-06-2015, 12:23 PM   #575
mid_life_crisis
Drives: FR-S 10 #103 AT
Have a look at your throttle position when afr is 15 its zero, the ecu shuts off injectors on overun to save fuel this is normal
I understand about lift off, but there are several points where throttle is 5,6, almost 10.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-06-2015, 01:09 PM   #576
steve99
Drives: FT86
also look at the commanded AFR (what ecu is asking for) and the measured afr, sometimes the ecu is asking for AFR arround 15 in low load light throttle, looks pretty normal to me.
Old 08-06-2015, 02:00 PM   #577
mid_life_crisis
You've done a lot more of this stuff than I have. I'll trust your judgment, and thanks for the patience.
Old 08-06-2015, 09:15 PM   #578
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by JonAvalon View Post
Yea I had a feeling someone would mention engine load. I put it back on yesterday, some of the stuff I left in there from testing but I'll remove them. Here are logs from yesterday with engine load if you want to take a look, no pulls just regular driving.
http://datazap.me/u/jonavalon/aftern...ta=1-3-4-10-11
http://datazap.me/u/jonavalon/aftern...log=0&data=1-3
I honestly didn't know that, good to know. I've been doing countless research and that didn't cross my mind. I hope I'm not trying to come across as a total noob about this stuff. I'm really trying to learn about this; what the data means, what I should watch out for etc. But I think I'm getting slowly a decent grasp of it.
Yep I've been looking at your thread for a while, great stuff. I've been trying to figure out how to do all of that in romraider.
Thanks
Don't look at the thread, look at the roms. Compare them to 2.06.
Old 08-07-2015, 08:27 AM   #579
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
sounds like a hardware problem ie intake or exhaust leak, dirty maf/map sensor ect. melted wiring ect.
i would talk to shiv, turbos running lean not good
Welp turned out to be that Evap line that I clamped..guess clamping that blindly was a bad idea.
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
steve99 (08-07-2015)
Old 08-08-2015, 01:40 PM   #580
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
http://datazap.me/u/el-92/3rd-gear-8...-2-3-7-9-12-13
data log a point in the right direction 3rd gear pull 91 octane
el-92 is offline   Reply With Quote
Old 08-21-2015, 12:15 AM   #581
JB86'd
JB86'd's Avatar
Drives: JAWS
get rid of the vvt intake and exhaust, kc learned and log IAM, FLKC, and Knock Correction. That will give a better indication of how your car is running.
JB86'd is offline   Reply With Quote
Old 08-21-2015, 12:23 AM   #582
JB86'd
JB86'd's Avatar
Drives: JAWS
first hard runs with the new JDL UEL header and OFT 2.06. 91 oct.
http://datazap.me/u/joshbustos86/jdl...1-3-8-10-11-14
Still running 11.25 AFR upper rpms, guess that's the nature of the OFT tunes and my car.
but damn do I love this combo.
Old 08-21-2015, 12:36 AM   #583
Wayno
Wayno's Avatar
Attachment 118364
It's richer than 11.25
You need to copy the MAF scale from Stg1 tunes in my thread.
And run DI to 7000, so you don't get a LTFT difference of 4 at 5200rpm.
Old 08-21-2015, 03:10 AM   #584
JB86'd
JB86'd's Avatar
Drives: JAWS
so these are the maf scaling values in the stg 1 tune (which look to be the same as your stg 2 tune) compared to my UEL stage 2 tune. Are these the correct changes to make?
Name:  maf scaling 2.06.jpg
also, not quite sure how to run DI to 7000. How important is that?
Old 08-21-2015, 03:41 AM   #585
Wayno
Wayno's Avatar
Attachment 118382
Yes, it's correct.
Also copy the injector ratio tables. They have re-scaled axis.
Old 08-21-2015, 04:18 AM   #586
JB86'd
JB86'd's Avatar
Drives: JAWS
Yes, it's correct.
Got it, thank you. How exactly does changing those injector ratio tables affect AFR/LTFT? In other words when I datalog this new tune, what changes should I be looking for that weren't due to changing the MAF scaling?
Old 08-21-2015, 04:51 AM   #587
Kodename47
Kodename47's Avatar
Drives: UK GT86
Any reason you chose to run full DI until 7k RPM?
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-21-2015, 05:02 AM   #588
Kodename47
Kodename47's Avatar
Drives: UK GT86
It shouldn't change anything, however there is usually variance between the injector systems so you may see a slight change in AFR.
RE: LTFT, if what Wayno is saying is correct, I have also seem similar recently. It was believed that LTFT was universal however I have seen a car that LTFT changed the moment it went from PI only to DI only at the same RPM range (idle). I'm not talking insignificant either, it went from 0% to -40%!! Admittedly the car had a hardware issue, but that's a saved LTFT.
.: Stealth 86 :.
Kodename 47 DJ:
JB86'd (08-21-2015)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
