Old 06-01-2012, 10:43 PM   #15
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Looks like a '10+ LGT rear pad.
old greg is offline   Reply With Quote
The Following 4 Users Say Thank You to old greg For This Useful Post:
blu_ (06-04-2012), Fly Guy (06-01-2012), Lonewolf (06-02-2012), Racecomp Engineering (06-04-2012)
Old 06-01-2012, 10:50 PM   #16
dsgerbc
Drives: BRZ(sold), STI
Ah, there's THAT LGT too
I keep forgetting it exists...
Looks pretty similar to BRZ though.
Old 06-02-2012, 03:14 AM   #17
danscar
danscar's Avatar
Drives: Jeepney
Here's a write up about the FRS/86 from Import Tuner.
Go to the 'Big Brake Kit' portion regarding similarities between WRX's and FRS/86's brakes.
http://www.importtuner.com/features/...05-30-08-46-00
danscar is offline   Reply With Quote
Old 06-02-2012, 03:24 AM   #18
OrbitalEllipses
Drives: Attitude
STI Brembo brake upgrades have been mentioned a billion times; while Import Tuner is correct in that they are direct BOLT on, they are not properly functional.
Dimman (06-02-2012)
Old 06-04-2012, 03:19 PM   #19
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Topic is a good idea, but someone has already put together a pretty comprehensive spreadsheet:
http://www.ft86club.com/forums/showthread.php?t=5511
Old 06-04-2012, 03:32 PM   #20
That's just a parts list though, doesn't really have any data. Gonna try and keep up with posting gory tech details in here.
- Andrew
Old 06-04-2012, 05:11 PM   #21
Dimman
Kuruma Otaku
Dimman's Avatar
- Andrew
Have you guys tested any FR-S springs/shocks yet? I'm curious if they are 160/260 lbs like the Tein H Techs...
Because titanium.
Old 06-04-2012, 05:17 PM   #22
Not yet. I was under the impression the rears are identical to BRZ with softer fronts.
160/185 wouldn't surprise me, but 260 lbs/in in the rear would be a big time surprise IMO. We'll get on it soon.
- Andrew
Dimman (06-04-2012), Fly Guy (06-04-2012)
Old 06-04-2012, 06:50 PM   #23
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
so we know the sti calipers would eb mounted "upside down" if we kept them properly mounted on the FR-S/BR-Z.
I don't know these calipers well enough to guess, but other cars' calipers are uniform enough that they could be drilled and tapped to fit the bleeder on the other side. I'd think this would be a pretty simple modification to the calipers. Anyone know these calipers enough to know if this could happen? Brakes are important, so it would be a little scary to be the first to "test" this, but thought I'd ask...
matt
Matt Andrews is offline   Reply With Quote
Old 06-08-2012, 11:02 PM   #24
Lonewolf
Lonewolf's Avatar
Drives: Moped
For those who do not know (Centric/Powerslot) apparently has braking components available for the BRZ:
http://www.powerslot.com/
(Search under find parts for your car)
Old 06-09-2012, 06:41 AM   #25
taosracer
Frickin' Genius
taosracer's Avatar
Drives: GBS BRZ 6sp, 2002 ts wagon WRX swap
Part #s for the stock BRZ pads are
26296SC010 f
26696CA000 r
Easy enough to cross reference from there. I won't be looking at upgrading brakes other than lines and fluid, as I don't plan on using the brakes much.
Seriously though, with the high compression ratio which makes for more engine braking at throttle lift, and the fact that the car is not that powerful but light weight, it's definitely a "momentum" type car for track driving. No need to use the brakes much.
Cullen
I hear on occasion, people say that they are bored...wrong answer....An engine can be bored, a person would more correctly state that they are boring.
taosracer is offline   Reply With Quote
Old 06-09-2012, 06:59 PM   #26
taosracer
Frickin' Genius
taosracer's Avatar
Here is some info on alignment you might find interesting :
http://www.ft86club.com/forums/showt...d=1#post250254
Cullen
Old 06-27-2012, 08:45 PM   #27
blalor
Drives: WRB BRZ Limited 6MT
Ok, I'm confused. I've seen this in a couple of places.
What's the correct size and factory part number for the BRZ's front and rear rotor? I'm looking to buy a set for track work and haven't figured out what and where to buy. I guess I could go to the dealership, but it seems like there should be cheaper options…
blalor is offline   Reply With Quote
Old 06-27-2012, 09:14 PM   #28
Lonewolf
Lonewolf's Avatar
Drives: Moped
Yeah, I was a bit thrown off too. I'm pretty sure all BRZ's in the US come with vented rear discs. I would call Centric (Powerslot) and ask them directly.
Limited gets brake "upgrade" over Premium - Canada only? Sport-Tech BRZ First-Gen (2012+) — General Topics 25 05-15-2012 12:35 AM
The Official "E-Peen" (BRAG) Thread S2kphile Off-Topic Lounge [WARNING: NO POLITICS] 46 03-31-2012 09:49 PM
New Official WRB Subaru BRZ Video from Geneva "Lift" gt86mods BRZ Photos, Videos, Wallpapers, Gallery Forum 13 03-06-2012 10:25 PM
The *Official* "I'm Back!" thread BoostJunkie Off-Topic Lounge [WARNING: NO POLITICS] 34 02-02-2012 07:21 AM
