Old 08-20-2015, 11:35 AM   #281
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Updated Stg1 and Stg2 petrol tunes.
The v85 petrol MAF scale should also work well for Stg2 petrol on MT, but hasn't been tested.
MAF scale is not quite perfectly smooth, but damn close.
OTS Stg2:
http://datazap.me/u/wayne/stg2-uel-9...om=16741-16948
v85 Stg2 (based on Stg1):
http://datazap.me/u/wayne/98-v844-3-...&zoom=834-1030
Old 08-20-2015, 12:08 PM   #282
workthatupdoo
Drives: 2015 Halo FR-S
Alright last one I swear...
Everything else saves except Cranking Fuel Injector Pulse Width F (ECT). I'm in debug mode and have Wayno's XMLs loaded.
It will allow me to save changes to the pulse width, but not the coolant temp. Any help would be appreciated!
workthatupdoo is offline   Reply With Quote
Old 08-20-2015, 07:05 PM   #283
steve99
Drives: FT86
Eekk, something looks weird their, check out thetemps in the A01I table looks like something strange happened they are all 32 somethings corrupted or def is wrong
Old 08-20-2015, 07:18 PM   #284
workthatupdoo
I've tried it with both the OTS def and Wayno's. 32s across the board on the A01I rom. Aside from the temp, the pulse width values are changed from the OTS E85 map though so I'll just leave the temperatures alone and see how it runs.
Old 08-21-2015, 03:23 AM   #285
Kodename47
Kodename47's Avatar
Drives: UK GT86
Try these:
I Series Def
D Series Defs
Replace the Definition files in the Definition Manager in Romraider, just don't delete the originals from your computer. These are compatible with the v2.x OFT files.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-21-2015, 03:31 AM   #286
Wayno
Wayno's Avatar
Originally Posted by drewbot View Post
You should also look into the modified tables for 91 Cali fuel (it's somewhere)
The timing changes attached in this thread are more sophisticated than the crater of timing pulled in that thread.
The Following User Says Thank You to Wayno For This Useful Post:
drewbot (08-21-2015)
Old 08-21-2015, 03:36 AM   #287
Wayno
Wayno's Avatar
You don't need to edit it. Please don't edit axis that look obviously incorrect. There's no guarantee that the definitions reference the correct addresses so if you make changes to something that's incorrectly addressed, you could be wiping ecu code.
Old 08-25-2015, 11:54 AM   #288
Wayno
Wayno's Avatar
Update: although the version number is still 85, the tunes have been updated with minor tweaks. Added PI back in to petrol at 0.3g/rev, Stg2/E85 MAF smoothing, etc.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
akyp (08-29-2015), gonzo (09-02-2015)
Old 08-26-2015, 07:13 PM   #289
freerunner
freerunner's Avatar
Drives: GT86
freerunner is offline   Reply With Quote
Old 09-02-2015, 07:39 PM   #290
gonzo
Drives: frs
Sorry if this was already answered, but why is the o2 sensor being rescaled 12 to 10.5 and should I add this change to my USDM e85/91 tunes? I'm here for the e85 fuel saving mod but figured to add the radiator and some other "utility" changes.
"- Rescaled O2 sensor from 12 down to 10.5 - thanks to ztan."
gonzo is offline   Reply With Quote
Old 09-02-2015, 07:41 PM   #291
Wayno
Wayno's Avatar
More accurate logging. It doesn't matter if your AFR is already on target.
Both stock and ots stg2 will hit afr in the 10's on AT, that's how bad they are.
gonzo (09-02-2015)
Old 09-02-2015, 07:47 PM   #292
gonzo
Drives: frs
By "on target" do you mean afr following command afr? How close should they be? Thanks for your posts!
Old 09-02-2015, 08:10 PM   #293
Wayno
Wayno's Avatar
It's up to you, but general rule E85 = on target (12.3). Petrol = below target (11.8)
Your best bet on petrol on both AT and MT is to start with the modified Stg1 MAF scale.
Petrol:
http://datazap.me/u/wayne/98-v844-3-...&zoom=852-1048
E85:
http://datazap.me/u/wayne/v84-3-pull...zoom=2215-2437
Here's OTS on MT:
http://datazap.me/u/shivvishnu/stage...1&zoom=799-958
gonzo (09-03-2015)
Old 09-05-2015, 07:02 AM   #294
derka-derka
Drives: Silver GT86
hi wayno,
is there a 700I version of this map. My dealer never updated (and had no idea wtf i was on about when asking them to). Im currently using shivs 2.067 and want to give this map a go. I kno the A01I is pretty much same map, but my ecu is still on 700I calId.
derka-derka is offline   Reply With Quote
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 10:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 11:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 01:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 06:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 05:26 PM
