Pat.Thornton
Old 08-17-2015, 10:27 AM   #197
xlid007
Drives: Scion FRS
It's your throwout bearing carrier binding/grinding against the transmission front cover. Print the image on this post and show it to your service dept.
You are correct. I just got my car back for the same noise and the same parts were replaced. I had to fight with the service adviser because the techs first said that the noise was normal, which I insisted that it was not and that my car is barely 2 years old and it should not be making these types of noises. I drove with the tech and showed him the noise, then he smirked and said, "Yeah, we have to take the transmission apart to see what's going on". If you don't get firm with these people and shove the evidence in their face, they'll just make excuses not to fix your issue. Also, demand to speak to the ACTUAL Service Manager. A lot of them claim to be the Service Manager and they're not. He can actually get stuff done.
xlid007 is offline   Reply With Quote
The Following 4 Users Say Thank You to xlid007 For This Useful Post:
axelo (08-17-2015), JS + BRZ (08-17-2015), SuperDave (08-20-2016), Ultramaroon (08-17-2015)
Old 08-17-2015, 10:29 AM   #198
xlid007
Drives: Scion FRS
Originally Posted by Aztec View Post
My car has a cat less header, lowered, wheels, tuned.
I'm not too sure I want to deal with them haha. They refused to fix my clicking axles nuts because I was lowered ha
EDIT: They blamed the clicking noise on the lowering springs. I'm like wat...
My car has full bolt-ons and tune. i guess that depends on the dealer. My dealer called me and told me that they had to remove my exhaust to get to the transmission and since it was aftermarket, they would not be responsible if it didn't line up. That's the only thing you would encounter. I knew they weren't going to have any issues since my exhaust lines up perfectly.
Old 08-17-2015, 04:43 PM   #199
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Good to see this thread... I'm having the same problem. Barely made it into the dealer. By the time I got there they couldn't get it into first gear without stalling the car. They had to push the car into the shop. They're telling me that I may have to pay them $1500 for tear down and inspection if they find that it's not a factory defect.
What a relief I'm not the only one with the same problem.
Intent > Content
Old 08-17-2015, 05:01 PM   #200
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Yours sounds like a different problem. This thread is about the problem with clutch making squeaking noise. The clutch itself works normally. Was yours making a grinding noise instead of a squeaking noise? I'm guessing yours wasn't making the noise while the engine is off. The noise this thread talks about makes the noise even when the engine is off.
Old 08-17-2015, 05:04 PM   #201
solidONE
solidONE's Avatar
It does both. Started with just squeaking and works normally. Then the engagement point shifts lower and lower until you can barely get into gear.
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
JS + BRZ (08-17-2015), Sigh-on-Rice (08-17-2015)
Old 08-17-2015, 05:10 PM   #202
Sigh-on-Rice
Uh oh. Bad news.
Old 08-17-2015, 06:40 PM   #203
Yeah, THAT squeak is from a seized throwout bearing. It's a quick trip to full meltdown from there.
Old 08-17-2015, 06:57 PM   #204
CSG Mike
CSG Mike's Avatar
That's a legit claim; lowering your car puts a bit more strains on your axles, and accelerates wear. The driver side is notorious for going out.
Old 08-17-2015, 07:02 PM   #205
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
That's reasonable enough. I'm considering taking my car in for the squeaky clutch. Would removing the spring behind the clutch cause an issue with the warranty?
My car is otherwise heavily modded, but it's still the stock clutch
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 08-17-2015, 07:18 PM   #206
CSG Mike
CSG Mike's Avatar
The spring behind the clutch pedal? If you've modified anything directly linked to the clutch mechanism, then yes, it can potentially affect your warranty.
If the pedal is squeaky, I'd recommend checking your slave fork, and grease it with high temp grease if the grease is gone.
Old 08-17-2015, 07:20 PM   #207
tracerit
Drives: '13 SSM BRZ Limited 6MT
Mine wasn't just squeaky, it was also "crunchy" as well. The tech described it as a dry throw out bearing which makes sense.
tracerit is offline   Reply With Quote
The Following 2 Users Say Thank You to tracerit For This Useful Post:
CSG Mike (08-17-2015), JS + BRZ (08-17-2015)
Old 08-17-2015, 08:22 PM   #208
JS + BRZ
Drives: 2010 MS3
Really!? Hmmmm...
Mine started to squeak back in May I believe. I've done two track days and a lot of hard canyon cruises.
Subaru Pacific just didn't want to open up the transmission and check it. They just told me to come back when it gets worse saying that I still have a lot of warranty miles left....
Old 08-17-2015, 08:31 PM   #209
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
15K miles and I'm starting to feel a little rumble in my clutch pedal when the engine is running.
I'll crack it open soon. Pics to follow.
Let me know when you do (assuming you get to it before me) this is something on my to do list for winter.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Old 08-17-2015, 08:32 PM   #210
CSG Mike
CSG Mike's Avatar
If the bearing is bad, at idle, in neutral, if you're not on the clutch, you'll hear the bearing.
Even with a bad bearing, the car should run for quite a while, but it's better to get it replaced sooner, rather than later. The bearing is cheap, but the labor is $$$.
JS + BRZ (08-17-2015), tracerit (08-17-2015)
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
