Southern California SoCal
Old 08-14-2015, 09:07 PM   #1
xcooperx
Drives: FR-S 2015
Question Need help with Donut Gasket
I just changed my exhaust from q300 to ark grip yesterday, special thanks to Brztoni for teaching me about exhaust replacement anyway, after installation i did check for leaks and noticed that the area on where the donut gasket with springs is leaking some air and little bit of water, i removed the Midpipe and tried to reposition it, tight the bolt ( 15-17lbs torque) and no success then loosen it a little bit but same thing ,i can still feel air coming out on it, so i I'm guessing my donut gasket is damage, does anyone know where i can get a aftermarket replacement and prices for it? how much is it from dealership?
will this fit [ame="http://www.amazon.com/Subaru-OEM-Exhaust-Donut-Gasket/dp/B00ENJIWIG/ref=sr_1_fkmr2_1?ie=UTF8&qid=1439600152&sr=8-1-fkmr2&keywords=frs+donut+gasket"]Amazon.com: Subaru OEM Exhaust Donut Gasket: Automotive[/ame]
xcooperx is offline   Reply With Quote
Old 08-16-2015, 05:43 AM   #2
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Try driving it for a couple days...the heat might reshape the gasket/pipes a bit.
Worked for my brother who's running NO gaskets on his Greddy exhaust lol. Initial start up, no leak. 30 minutes in, small leak. Next day until to this day...no leak.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
The Following User Says Thank You to LXXXV1 For This Useful Post:
xcooperx (08-16-2015)
Old 08-16-2015, 11:03 AM   #3
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
still having problems let me know. donut gaskets are easy to install.. i like to apply a small amount of high temp silicone sometimes to exhausts that are finicky..
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
The Following User Says Thank You to BRZtoni For This Useful Post:
Old 08-16-2015, 12:50 PM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
I had similar issue so eventually I added some copper high temp gasket sealant. So far so good..
Decimus is offline   Reply With Quote
The Following User Says Thank You to Decimus For This Useful Post:
no flange for donut gasket on J2 front pipe k0tkmnd Engine, Exhaust, Transmission 1 06-05-2015 02:04 PM
Front Pipe donut gasket EightSix93 Scion FR-S / Toyota 86 GT86 General Forum 1 06-02-2015 09:02 PM
front pipe use donut gasket or not garfull Engine, Exhaust, Transmission 2 12-09-2013 03:20 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
Donut time! mr2lor Scion FR-S / Toyota 86 GT86 General Forum 20 05-24-2012 11:27 PM
