Old 08-14-2015, 10:21 AM   #141
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Just for the sake of clarity, I didn't have to grind off the lip on the block. I could have, but I instead decided to grind about 1/16" off the bottom of the bosses on the cooler plate. It fits like a glove. I have driven 1500+ miles in the last 3 days, and everything is holding fine. Oil temps are brilliant! I love this mod!
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
DustinS (08-14-2015)
Old 08-14-2015, 10:37 AM   #142
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Hyper4mance2k View Post
Just for clarity, I didn't have to grind off the lip on the block. I could have, but I instead decided to grind about 1/16" off the bottom of the bosses on the cooler plate. It fits like a glove. I have driven 1500+ miles in the last 3 days, and everything is holding fine. Oil temps are brilliant! I love this mod!
Thats good info to know. If i ever need to do it again, I'll use the derale cooling plate. The money savings is enough of an incentive.
Old 08-14-2015, 10:40 AM   #143
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Make sure your fittings are tight. For some reason mine backed out and I sprayed oil all over my car on the interstate...
Kuri is offline   Reply With Quote
The Following User Says Thank You to Kuri For This Useful Post:
Old 08-14-2015, 10:52 AM   #144
DustinS
DustinS's Avatar
External mount anyone?
Edit: Found some hose that may make it even cheaper:
Parker Push-lok 801
It's cheap and exceeds what we need for our oil cooler needs. Also comes in many different colors (Grey, Blue, Black, Red, Yellow, and Green). Can be found online(Link) or at any hydraulic supply store (Hyspeco is local to me).
Here is the official link:
Parker Website for 801 Push-lok hose
The Following 2 Users Say Thank You to DustinS For This Useful Post:
Hyper4mance2k (08-15-2015), Joe-G (03-14-2016)
Old 08-15-2015, 01:33 AM   #145
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
I went with Aeroquip pushlock hose and fittings. So far I have driven from LA to Nashville, TN without incident.
Old 08-15-2015, 01:40 AM   #146
DustinS
DustinS's Avatar
I'm sort of concerned. Mine went on fairly easy, or at least easier than I expected. Everything I read made it seem like a pain to install the fittings in the hose. Hoping mine don't fail.
Good to note, the 27mm socket for the oil filter adapter needs to be thin walled or it will not allow you to torque the bolt properly(for the mocal sandwich plate). I'm still unsure of how tight/loose the sandwich adapter is because of this issue.
Old 08-16-2015, 09:57 PM   #147
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Parker Push-lok 801
Is that a Volvo intercooler?
Old 08-17-2015, 10:02 AM   #148
DustinS
DustinS's Avatar
Intercooler that is included in the Speed By Design Turbo kit.
Everything was a pretty tight fit:
The Following User Says Thank You to DustinS For This Useful Post:
Hyper4mance2k (08-18-2015)
Old 01-24-2016, 04:17 PM   #149
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
@mit_peid I completely forgot to mention that I found a solution to the Derale problem. Just use the oil filter for a 1990-1995 Chevy Corvette ZR-1. K&N Part# HP-2007. The o-ring fits the landing perfectly. It's over-sized with more filter media for better filtration, it holds more oil than stock, and it has the same bleed back valve and pressure bypass as stock. All good news!
Old 03-14-2016, 05:11 PM   #150
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Ever get a chance to take a picture of your setup? Did you end up using that plate?
Hows it all going so far?
Joe-G is offline   Reply With Quote
Old 05-28-2016, 12:00 PM   #151
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
dumb question, not sure if it's been answered, I saw the post shaving the hex nut off to rotate the sandwhich. Has any tried this with a low profile oil filler cap? I have a kraftwerks kit so I can't really push the hoses out or angled towards the front it needs to go out the side over the filler cap...
pgranberg11 is offline   Reply With Quote
Old 05-30-2016, 08:18 PM   #152
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
I made a DIY thread. Everything has been flawless.
http://www.ft86club.com/forums/showthread.php?t=100503
jbailey8748 (05-25-2018)
Old 01-14-2020, 06:12 PM   #153
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
Anyone know if the spacer can be purchased on it's own without the sandwich plate
Razzle is offline   Reply With Quote
Old 09-14-2020, 08:21 PM   #154
randing
randing's Avatar
Drives: 2015 FR-S
Bumping an old thread, but I also have questions about the spacer. I noticed all of the oil cooler kits use some sort of spacer, is it just meant to add clearance for the oil lines? If I'm already using the OEM Forester oil cooler can I continue using that to warm the oil faster and just mount the sandwich adapter to Forester oil cooler, not using the spacer? Does it make sense to do this, or too convoluted, pull the Forester cooler? 185F is kind of low to have the oil cooler functioning anyways, continuing to warm the oil with coolant doesn't sound too bad.
randing is offline   Reply With Quote
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
Apexi Oil Temp Meter, and Setrab Oil Cooler Moto-P Scion FR-S / Toyota 86 GT86 General Forum 5 07-09-2013 01:58 PM
Mocal Oil Cooler swift996 Engine, Exhaust, Transmission 11 07-01-2013 04:00 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
