Old 06-27-2013, 02:14 AM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Homebrew Oil Cooler (Setrab/Mocal)
**Update: Track Day Log
http://www.ft86club.com/forums/showp...5&postcount=33
20130629-TDE-MSR-Green-Session3-Temps by VictorN07, on Flickr
**Update: More Track Day logs!
http://www.ft86club.com/forums/showp...5&postcount=40
**Update: Installation pictures
http://www.ft86club.com/forums/showp...8&postcount=51
20130628-HomebrewOilCoolerInstall-070 by VictorN07, on Flickr
20130628-HomebrewOilCoolerInstall-132 by VictorN07, on Flickr
Few words. Lots of pictures. Install will come later.
Not pictured: -10 AN Aeroquip hose, Loctite 567 thread sealant, cooler mounting hardware.
Setrab 13 row oil cooler featuring Danbo
20130626-HomebrewOilCooler-010 by VictorN07, on Flickr
20130626-HomebrewOilCooler-017 by VictorN07, on Flickr
Danbo is full of wonder.
20130626-HomebrewOilCooler-021 by VictorN07, on Flickr
-10AN 22mm fittings
20130626-HomebrewOilCooler-024 by VictorN07, on Flickr
20130626-HomebrewOilCooler-028 by VictorN07, on Flickr
It's black
20130626-HomebrewOilCooler-034 by VictorN07, on Flickr
20130626-HomebrewOilCooler-038 by VictorN07, on Flickr
20130626-HomebrewOilCooler-040 by VictorN07, on Flickr
20130626-HomebrewOilCooler-041 by VictorN07, on Flickr
Mocal Thermostatic Sandwich plate
20130626-HomebrewOilCooler-043 by VictorN07, on Flickr
20130626-HomebrewOilCooler-044 by VictorN07, on Flickr
Instruciones
20130626-HomebrewOilCooler-047 by VictorN07, on Flickr
20130626-HomebrewOilCooler-048 by VictorN07, on Flickr
It comes apart easily.
20130626-HomebrewOilCooler-050 by VictorN07, on Flickr
This holds it all together
20130626-HomebrewOilCooler-053 by VictorN07, on Flickr
I love this picture
20130626-HomebrewOilCooler-056 by VictorN07, on Flickr
I think there are nicer gaskets out there
20130626-HomebrewOilCooler-061 by VictorN07, on Flickr
20130626-HomebrewOilCooler-062 by VictorN07, on Flickr
Spacer
20130626-HomebrewOilCooler-064 by VictorN07, on Flickr
Bottom of spacer. Danbo is angry at the gasket
20130626-HomebrewOilCooler-066 by VictorN07, on Flickr
All the fittings required
20130626-HomebrewOilCooler-073 by VictorN07, on Flickr
This is how I will use all the fittings
20130626-HomebrewOilCooler-075 by VictorN07, on Flickr
More documentation
20130626-HomebrewOilCooler-081 by VictorN07, on Flickr
Fin
F1point4 is offline   Reply With Quote
The Following 14 Users Say Thank You to F1point4 For This Useful Post:
bestwheelbase (07-08-2013), Bullnettles (06-27-2013), Calum (06-27-2013), cobrabyte (06-28-2013), continuecrushing (06-27-2013), DAEMANO (06-23-2015), jamesm (06-27-2013), sandman126 (06-27-2013), SloS14 (06-27-2013), Spartan65 (07-14-2013), Squishy (06-28-2013), suaveflooder (07-01-2013), Vracer111 (07-01-2013), whataboutbob (07-18-2013)
Old 06-27-2013, 02:21 AM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
nice shots! Info on price/item numbers?!
The Following User Says Thank You to continuecrushing For This Useful Post:
Eightysexy (06-30-2013)
Old 06-27-2013, 02:27 AM   #3
F1point4
Photo Specialist
F1point4's Avatar
Huh I just noticed that the colours on my Android Chrome look different than on the PC. It looks correct on my iPhone
Old 06-27-2013, 02:33 AM   #4
F1point4
Photo Specialist
F1point4's Avatar
Mocal Thermostatic Sandwich Plate with FA20 Spacer
Aeroquip Socketless Hose -10 AN
Mocal 90 degree Socketless Push Lock End -10AN 1 Pair
Mocal 45 degree Socketless Push Lock End -10AN 1 Pair
Mocal 1/2" BSP -10AN Fitting, 1 Pair
Setrab 22mm x -10AN fittings, 1 Pair
The Following 4 Users Say Thank You to F1point4 For This Useful Post:
continuecrushing (06-27-2013), DAEMANO (06-23-2015), michaelxchristopher (07-04-2018), whataboutbob (07-18-2013)
Old 06-27-2013, 02:46 AM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
will this be middle or side mount?
86_ZN6 is offline   Reply With Quote
Old 06-27-2013, 09:11 AM   #6
mad_sb
Drives: 2013 Asphalt FR-S
depending on what rom you are running there should be a color correction option set......
In for price info.. I was also looking at the setrab coolers...
The Following User Says Thank You to mad_sb For This Useful Post:
F1point4 (06-27-2013)
Old 06-27-2013, 09:36 AM   #7
brillo
Drives: 2013 Firestorm FR-S
Danbo needs an FT86 shirt.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
The Following User Says Thank You to brillo For This Useful Post:
Old 06-27-2013, 10:07 AM   #8
F1point4
Photo Specialist
F1point4's Avatar
Planning to mount it on the stiff black splash guard, but off center. It will be over to the driver side as much as possible. I already took off the air scoops around the FR-S/86 grill so there is more room.
Old 06-27-2013, 10:23 AM   #9
jamesm
nice! i'm looking to do a similar setup pretty soon. can't wait to see it mounted.
Old 06-27-2013, 10:32 AM   #10
F1point4
Photo Specialist
F1point4's Avatar
Ordered everything from RacerPartsWholesale. Here is an excerpt from my R&D spreadsheet.
20130627-HomebrewOilCooler by VictorN07, on Flickr
I am in no way responsible for any damage to your vehicle should you go this route. I feel comfortable working in my car so I opted to go this route to save some money.
With this you have to get creative and find your own mounting solution. Going with a kit means you won't have to do this, as well as getting support from the merchant and manufacturer if you get in a bind. In more or less words, I'm on my own.
Larger coolers (16 row, 19 row) will fit depending on desired placement. It's tight in my car with the Vortech Supercharger so I'm going with the smaller cooler.
I plan to take more pictures. DIY guide maybe.
charged86 (07-14-2013), DAEMANO (06-23-2015), SkAsphalt (05-23-2014), whataboutbob (07-18-2013)
Old 06-27-2013, 10:34 AM   #11
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
SloS14 is offline   Reply With Quote
The Following 2 Users Say Thank You to SloS14 For This Useful Post:
F1point4 (06-27-2013), number1Tango (06-27-2013)
Old 06-27-2013, 10:39 AM   #12
Bullnettles
Drives: Scion FR-S 2013
Are you in Houston (Victor on FB?) I've been looking to do something like this, but haven't finished installing the parts I have in my garage as-is... Anyway, if you're in Houston, I'd like to see this. How much was it out the door?
Bullnettles is offline   Reply With Quote
Old 06-27-2013, 10:53 AM   #13
F1point4
Photo Specialist
F1point4's Avatar
The price I showed above was it. No Tax and free shipping.
Old 06-27-2013, 10:54 AM   #14
ft_sjo
Drives: GT86
Can you/anyone please confirm if the oil filter thread is M18x1.5?
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 05:30 PM
Apexi Oil Temp Meter, and Setrab Oil Cooler Moto-P Scion FR-S / Toyota 86 GT86 General Forum 5 07-09-2013 02:58 PM
Mocal Oil Cooler swift996 Engine, Exhaust, Transmission 11 07-01-2013 05:00 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-22-2013 12:36 AM
