Old 08-10-2015, 01:41 PM   #253
DarkSunrise
DarkSunrise's Avatar
I changed mine with the Motul 300 stuff and didn't notice a huge difference to be honest. Maybe a bit more feedback going from gate to gate. It was routine track maintenance though, so regardless of feel, I'm happy for the additional protection/better oil.
My transmission drain plug was actually pretty clean when I drained it. Surprising because I had moderate initial grind going into 2nd when new (went away over time), and still have occasional grinds going into 3rd/5th. Expected to see more metal shavings.
2022 BRZ Build
2013 FR-S Build
Old 08-11-2015, 11:38 AM   #254
MoonieGT
MoonieGT's Avatar
Drives: '17 BRZ
Hmm, I changed my transmission fluid last Thursday night. When I went for a drive Thursday night and Friday morning, the shifts were super slick and nice. Friday afternoon, the shifts felt a bit more like with the OEM fluid? I'd say the shifts feel better than the OEM fluid now, but not as nice as those first two drives. Sometimes the shifs are pretty smooth, other times they're a bit notchy, clicky. Very odd. I guess I'll crawl back under there and triple check the fluid level. Otherwise, I wonder if I should drain out that new fluid and hope it helps flush out any remnants of the OEM fluid and start again with more $20 a bottle Motul?
'17 BRZ
MoonieGT is offline   Reply With Quote
Old 08-11-2015, 02:34 PM   #255
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by sato View Post
I just replaced mine at ~22k miles at the dealer. World of a difference
I'm no longer experiencing grinding in 2nd, but experiencing some entering 4th at high revs
sato is offline   Reply With Quote
Old 08-13-2015, 09:50 PM   #256
stevesnj
stevesnj's Avatar
So I did the trans. and Rear Diff and it is very very smooth. I have a Quick shift and it was notchy,but not terribly, after swapping in the MOTUL it is a total difference. Now I have 1535 miles on the car and since it is very smooth just after I put it in I will see how it feels in the next 1535. Good recommendations to swap the oils out. I got 4 quarts from CARiD for $75
My 2016 Build thread
Old 08-14-2015, 12:09 PM   #257
GirlRepellent
GirlRepellent's Avatar
Drives: Evo X FE/FRS 10 Series
I ended up switching to Redline. In the morning when the cars cold, its doesnt like to shift. Once its warmed up its silky smooth. Did diff fluid too.
I dont think you can go wrong with Motul, Redline, or OE, just change your fluid!
GirlRepellent is offline   Reply With Quote
Old 08-14-2015, 03:22 PM   #258
mhughett
Drives: 2015 Crystal White BRZ Limited
Price drop on the MOTUL. CARiD has it for $15.33/ltr. 4 liters + shipping was only $70. Best I've seen.
mhughett is offline   Reply With Quote
The Following User Says Thank You to mhughett For This Useful Post:
stevesnj (08-14-2015)
Old 09-05-2015, 10:01 PM   #259
504
504's Avatar
Drives: 2014 86 GTS
Just a HUGE public service announcement from my personal experience for any DIYers...
Whatever fluid you decide to choose, fill it with 2.2L exact. Dont bother with the "fill until it overfills" method as it is much harder to get a car absolutely level in a garage with jack stands. I changed out the fluid 3 times from redline to amsoil to now motul and was never content with the shifting at all. Crunchy or catchy shifts even when warm and had to consciously shift to avoid this. It really made the car painful to drive.
If you ever feel like the new fluid doesn't perform to expectations, try to ensure the exact amount is filled. (my crunch issues were due to a 200mL overfill only!)
overfill = synchro over lubrication = crunch
504 is offline   Reply With Quote
Old 09-06-2015, 07:56 AM   #260
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Interesting. What crunchy issues were you having? I'm having grind when shifting quickly into 5th above 3k rpm when car is hot, but I've heard people have this on stock fluid and the genesis coupe guys (same Asin 6MT box) have been unable to solve this grind since 2009 when their cars started using this transmission. Some say Redline Shockproof fixes it, but reports are mixed. With Valvoline, everything shifts like butter, but I do have that grind.
Thinking you may be onto something. Fluid levels would give inconsistent results between different people on the same fluids.
xxBrun0xx is offline   Reply With Quote
Old 09-06-2015, 02:38 PM   #261
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
My does the same thing above 3k while hot, trying to make a pass quickly into 5th. It's like it doesn't want to engage 5th and when it does, it feels forced. My car only has 1300 miles on it tho, so maybe it's just a tranny thing.
Rifle is offline   Reply With Quote
Old 09-16-2015, 06:16 PM   #262
Tekno Virus
Drives: 2015 Subaru BRZ Limited
Hi guys,
I just got done today changing my tranny and diff oils to Motul 300 and I must say, it's much much better than the donkey piss OEM fluid.
This was done at 600 miles on the odometer with no shavings seen on the magnetic plug of the tranny, but with significant shavings seen on the differential magnetic plug. I was expecting the other way around.
I am SO glad I switched the fluids out.
Tekno Virus is offline   Reply With Quote
Old 09-16-2015, 07:09 PM   #263
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
OEM fluid is probably just thicker for break-in period? Since I switch to mutol, I can put my gear into 1st without a fight as long as I rev match right & give it a bit of space/time. With oem fluid it was impossible to go in 1st any speed above 9 mile...
Old 09-16-2015, 07:24 PM   #264
chas3wba0
chas3wba0's Avatar
Drives: Yes
OEM fluid is not specially formulated for break-in. If that were the case, they would require a mandatory fluid flush after the break-in period.
Even the manual only recommends that you "Inspect" the fluid at 23,500 miles.
And you should be double-clutch rev-matching if you want to put it into 1st at any speed above a crawl.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
chaoskaze (09-16-2015)
Old 09-20-2015, 11:07 PM   #265
504
504's Avatar
Drives: 2014 86 GTS
ok guys I need some serious help...
My oem fluid shifted absolutely perfectly, I couldnt comprehend it when I read online people would grind with the clutch fully in; it was the dream transmission. For some reason I decided that I wanted to change the fluid to start on a clean page and remove all new car metal. This was done at 11k km
Fluid #1 Redline MTL: This is when shifting started to go meh. All my shifting woes are 2nd and third gear only. The feeling was that the synchros were too lubricated and wouldnt slow down enough to synchronise properly. I would get a clank or "really low rpm" grind occationally and it reduced shifting confidence for me.
Fluid #2: Amsoil synchromesh: was abit better not the best, got over it within a matter of 2 weeks
Fluid #3: Motul Gear 300. was ok still meh, worst performing when cold.
I then discovered that Fluid fill was a big variable in all this, I was never confident with how much I filled. I would put 2.2L.. nothing comes out, 2.3L.. still nothing then finally 2.4 just to be safe. so I refilled gear 300 to 2.2L EXACT. It was significantly better but still catchy sometimes. no soft grind anymore. I went back to the amsoil to 2.2L and its the best so far with the least frequency of catchy shifts but it still isnt what it used to be stock.
I know for a fact the transmission is in perfect condition based on the way I drive, how immaculate the fluids come out every single time and how much different it behaves with varying fluids. So now im completely out of ideas.
Any help is greatly appreciated
The Following User Says Thank You to 504 For This Useful Post:
Bonburner (10-27-2015)
Old 09-21-2015, 12:53 AM   #266
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
^ You might be onto something. When I fill the oil up to the full line on my motorcycle I'd struggle to find neutral at a stop light with the clutch in, but If I fill it somewhere halfway between the full and half way up the oil level sight glass it would shift perfectly.
Intent > Content
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
