Old 08-13-2015, 03:14 PM   #9199
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Originally Posted by Sojhinn View Post
Who did we lose?
@tyrantcf has the hots for a WRX as he's a Subie fanboy.
So technically it'll be a third owner situation.
The Following 2 Users Say Thank You to LucidMomentum For This Useful Post:
DAEMANO (08-13-2015), Sojhinn (08-13-2015)
Old 08-13-2015, 05:59 PM   #9200
tyrantcf
Drives: '16 WRX, CBR1000RR
Just got the call that the car arrived too, a week ahead of schedule.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
The Following 3 Users Say Thank You to tyrantcf For This Useful Post:
DAEMANO (08-13-2015), raven1231 (08-16-2015), Sojhinn (08-13-2015)
Old 08-13-2015, 06:51 PM   #9201
LucidMomentum
YES. I mean sorry to see you go, man. I mean crap I need to order a Procede...
The Following User Says Thank You to LucidMomentum For This Useful Post:
Old 08-13-2015, 07:53 PM   #9202
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
So it seems I will be getting a used ESC kit in the next few weeks. What's the best OFT and Procede maps for an A/T FR-S to go along with it?
Currently working on that. I got mine 2nd hand also on the 3rd, so I'm still trying things out. Turns out 2 PSI of boost at 2000 RPMs makes a wooshy noise but doesn't move the car much. I'm trialing and erroring to find out how much boost, and at what RPMs it should be to make the most power. The tune is pretty close now, but the boost map has a bit more to go. The goal is to seamlessly integrate the unboosted tune with the boost map so the transition to boost is undetectable to the wife/significant other. I'm able to shift pretty well with just the throttle pedal now in Drive mode. I can almost predict which gear it's going to shift down to when I tap it. My rule of thumb is "mild acceleration/cruise up to 2500 RPMs, with almost no boost, and real acceleration/showing off with up to full boost from about 3500 RPMs on up. I can send you what I have so far. What is your CAL ID? I hope it's A00D, otherwise I'll need to change like 20+ tables. I took the stage 2 91 Oct ESC tune, added @Wayno's additions, (except timing), massaged the AVCS normal and safe tables a bit, and called it good.
KoolBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post:
LucidMomentum (08-13-2015), Sojhinn (08-13-2015)
Old 08-13-2015, 10:04 PM   #9203
LucidMomentum
Yeah that sounds perfect. Just a bit of oomph to overcome the torque dip in the 2000-3000 rpm range, and then the boost for more fun.
Not sure yet haha. I'll be getting the OFT from Tyrant soon though, then I can get ya the info. I'll be using 91 octane since our town doesn't have better :/
Old 08-16-2015, 11:57 AM   #9204
j_Zer0
Drives: Asphalt FRS 2014
I'm finally installing my Procede today (been in transition / job change mode). I'm 6AT so I'll be very interested in your progress. For now though, is Sojhinn's Procede map 6AT friendly? Thanks.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 08-16-2015, 11:59 AM   #9205
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Should be 95% perfect.
Installed Mods:
Old 08-16-2015, 02:18 PM   #9206
KoolBRZ
KoolBRZ's Avatar
@Sojhinn's map has prespooling enabled, so it's not the best tune for an AT. When you take your foot off the throttle, you want that ESC completely off. Also , because the loads on AT's are different than on MT's, the boost has to come on later, at a higher RPM. Trying to boost at 2000 RPM is just that, trying. It makes a wooshy noise, but doesn't go any faster. I can get some acceleration at 2500, so I start boosting at 2250. I don't go above -50 at 2250, and only -25 at 2500. It really comes into the power above 3500. Even at full throttle, I don't go to 100% till I get to 4250 RPM. I'm still working on a custom OFT tune and throttle map, but you can try what I have now if you like. What is your CAL ID?
The Following User Says Thank You to KoolBRZ For This Useful Post:
Sojhinn (08-16-2015)
Old 08-16-2015, 02:41 PM   #9207
j_Zer0
I'm on B01D. Would love to try out your current map. Thanks man.
Old 08-16-2015, 02:45 PM   #9208
Sojhinn
Sojhinn's Avatar
@KoolBRZ do you mind sending me the procede map for at? Just want to look at it.
Installed Mods:
Old 08-16-2015, 03:53 PM   #9209
j_Zer0
Procede is all hooked up, but windows won't recognize it to install the driver. Suggestions? I'm following the instructions in the readme.
Old 08-16-2015, 04:11 PM   #9210
Sojhinn
Sojhinn's Avatar
Serial or usb? Also did you disable the wifi?
Installed Mods:
Old 08-16-2015, 04:17 PM   #9211
KoolBRZ
KoolBRZ's Avatar
My laptop didn't even flinch when I plugged mine in, but the port was showing in device manager, so I guess it installed without a hitch. Check device manager for the port, and make sure the COM is in range specified in the read me. If it is, open the Procede user software and click on the little connect icon.
Old 08-16-2015, 04:27 PM   #9212
KoolBRZ
KoolBRZ's Avatar
Procede throttle maps for power and economy
Here are the Procede maps I've developed so far. The "smooth-AT" map is for economy, and the "sport-AT" is for power. The power map is for a more advanced tune that has more overlap and AVCS tuning, so it might be a little too much boost for most other tunes, in the lower RPM range's.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
