Old 08-11-2015, 05:08 PM   #1
timmydatooth
Drives: Scion Frs
Need some help with some wiring
Im trying to hook up my led drl fog lights. But i have no idea how to connect these 2 red wires? Do i just shove the metal piece inside and put the clear plastic piece over it? It doesnt seem to fit when i try it. Thanks in advance
timmydatooth is offline   Reply With Quote
Old 08-11-2015, 05:32 PM   #2
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
Yep, its called a bullet connector. Push hard.
RustySocket is offline   Reply With Quote
The Following User Says Thank You to RustySocket For This Useful Post:
timmydatooth (08-11-2015)
Old 08-11-2015, 05:33 PM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
thats what she said....
The Following 4 Users Say Thank You to WhiteFRS69 For This Useful Post:
chas3wba0 (08-11-2015), Chimera (08-13-2015), RustySocket (08-11-2015), SlammedSilly (08-13-2015)
Old 08-11-2015, 05:38 PM   #4
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Penetrate the male end into the female end until it's so deep that you can't easily pull it out...and make sure it's wrapped tight with the rubber glove
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
The Following 7 Users Say Thank You to tiz22 For This Useful Post:
chas3wba0 (08-11-2015), jamies31 (08-11-2015), MisterSheep (08-11-2015), Porcupint (08-12-2015), RustySocket (08-11-2015), timmydatooth (08-11-2015), WhiteFRS69 (08-11-2015)
Old 08-11-2015, 05:40 PM   #5
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Instagram: trevor.parque
Old 08-11-2015, 05:45 PM   #6
timmydatooth
Drives: Scion Frs
Thank you so much! Now while i have your attention guys which one of these wire do i tap in to so that my fogs will be on when i turn on the parking lights? Theres red black and green. I was assuming red but maybe its green...
Old 08-11-2015, 06:14 PM   #7
Bergen23
Drives: '15 Halo FR-S
Test with a multimeter and see which one receives about 12VDC with the key on and the light switch in the desired position. . Tap into that one.
Bergen23 is offline   Reply With Quote
Old 08-11-2015, 06:17 PM   #8
timmydatooth
Drives: Scion Frs
Dont have access to a multimeter right now...any other way to test it?
Old 08-11-2015, 06:33 PM   #9
DAEMANO
Time Traveller
1. Turn key on
2. Put your tongue on it
KIDDING DONT!
Shitty 12v tester light from any auto parts store
Old 08-11-2015, 06:38 PM   #10
timmydatooth
Drives: Scion Frs
Im about to say screw it and tap into the red one...i doubt the power wire would be green...is that ever the case tho?
Old 08-11-2015, 07:03 PM   #11
Bergen23
Green is most often a ground
Old 08-11-2015, 07:07 PM   #12
Take the time find out what is right or pay the price! BCUs are not cheap as many here have found out. I don't know what is what but I do know that with the number of wires used in modern cars the "standard" colour references can go out the window. Red could very well be a ground in this case or maybe not but don't wire by guessing.
Old 08-11-2015, 07:24 PM   #13
timmydatooth
Drives: Scion Frs
Whats the worse that can happen if i tap into the wrong wire?
Old 08-11-2015, 07:28 PM   #14
Worst - Dead short, bad fuse, burned up car
Bad - Blown control module, very expensive
Moderate - Blow a 50 cent fuse, finding which is the fun part
Best - It works no issues
Porcupint (08-12-2015), Ultramaroon (08-11-2015)
How to use the OEM amp Wiring RandomHero Electronics | Audio | NAV | Infotainment 258 07-04-2024 12:34 PM
Wiring in IAT for SD mrk1 Software Tuning 13 04-14-2023 08:15 AM
Wiring for DRL Yap Cosmetic Modification (Interior/Exterior/Lighting) 2 01-19-2015 01:13 AM
LF VA Wiring Help OURO3OROS Mid-Atlantic 0 02-23-2014 08:24 AM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 01:02 PM
