| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: Asphalt FRS
| The Following User Says Thank You to Jolt182 For This Useful Post: | ajaxthebetter (07-26-2015) |
#16 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
You should look into Nitto Invo's I run those on 225/45R 17. They are veryquiet, dare I say more comfortable then OEM and have only slightly more grip. Iam really happy with them for a DD. I was hoping they would grip better, but Ialso like getting sideways so I feel these are a good middle ground. The one thing you might not like is the side wall seems a little soft IMO. |
#17 |
Drives: 2015 BRZ - sold & 2014 Legacy Sport
I'm on Tire Rack trying to find a good tire & Wheel package for my 2015 BRZ
I want to go 18" but was told that might slow the car down. I dont really mind that much but do y'all think 17 to play it safe? |
#18 | |
Drives: Subaru BRZ Limited
http://www.roadandtrack.com/car-cult...ransformation/ All in all, you probably wont see a huge difference between 17 and 18 according to the data, but (at least for me) there's a big difference between stock wheels and tires and lighter rims with higher traction tires. |
| The Following User Says Thank You to Ramster For This Useful Post: | mixedjuice (08-11-2015) |
#19 |
Country Boy 4 Life
MPSS.
Thread. |
| The Following User Says Thank You to Leonardo For This Useful Post: | Muaddib (08-23-2015) |
#20 |
Drives: 2022 BRZ Limited
for $100 a piece they're no brainer and can be also used for mild track/auto-x events
![]() Did I mention they're the best tires for wet (for street use of course)?
| The Following User Says Thank You to glamcem For This Useful Post: | mixedjuice (08-20-2015) |
#21 |
Drives: frs
#22 |
Country Boy 4 Life
Tire Rack has 225/45/17's for $141 each. And the 245/40/17 for $169.
![]() http://www.tirerack.com/tires/tires....150810224226:s There are cheaper tires that are good. But the Michelin is Great! I now have 22,000 on my fronts and 17,000 on my rears. I am just down to the wear bar. I have new ones ordered
| The Following User Says Thank You to Leonardo For This Useful Post: | mixedjuice (08-11-2015) |
#23 |
So if i was going to go 18" rims, what would be a solid tire measurement that requires no modifications?
Right now i wrote down 225/40/18, but it looks like i can even go 235/40/18... |
#24 |
How is the wet weather traction on those tires? I'm considering them as my next set.
#26 |
they used to be $100 and some change but now $118 a piece at here so still $20 a piece cheaper than TireRack, I've purchased tires from there before with no issues
http://www.discountedwheelwarehouse....9738&pID=25620
#27 |
Can anybody tell me on which set of tires to get for these 18" wheels i am getting?
MICHELIN/PILOT SUPER SPORT Size: 225/40ZR18 (92Y) XL vs. MICHELIN/PILOT SUPER SPORT Size: 225/40ZR18 88Y BMW What is the difference between the 92Y vs. the 88Y??? Also can i go any bigger for tires that 225/40 without rubbing? or is this a pretty good set up for stock suspension? |
#28 |
88y has a lower load rating than the other. I believe our factory tires are 84w so you should be good.
| The Following User Says Thank You to D_Thissen For This Useful Post: | mixedjuice (08-20-2015) |
| tire recommendations? | jarviz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 11-29-2013 04:51 PM |
| Tire brand recommendations | arashishozen | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 11-14-2013 10:12 AM |
| Tire recommendations | Shenks | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 09-24-2013 11:46 PM |
| Tire Recommendations | Re~Mix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 09-16-2013 11:06 PM |
| Need Tire recommendations please, non track use | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 01-03-2013 04:15 PM |
